Page 29 of 32 1 2 27 28 29 30 31 32
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #2576978
11/11/18 01:16 AM
11/11/18 01:16 AM
new jersey
Black 69 Beeper Offline OP
new jersey
The dash is installed and everything hooked up as well as the steering column.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #2576981
11/11/18 01:18 AM
11/11/18 01:18 AM
new jersey
new jersey
The doors were put on for the final time and aligned.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #2576983
11/11/18 01:21 AM
11/11/18 01:21 AM
new jersey
new jersey
A little day 2 touch. These are covering some deep scratches that would not polish out. If anyone has nice clear rear side glass and will ship please let me know. Also I make these stickers if interested.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #2577008
11/11/18 03:03 AM
11/11/18 03:03 AM
Superfreak
Superfreak
You can buy that glass from AMD.
Re: my 69 rr black, pewter int and pewter painted roof [Re: ] #2577088
11/11/18 01:29 PM
11/11/18 01:29 PM
new jersey
new jersey
I have heard and seen there are issues with the new glass from AMD. Its thicker and causes a lot of issues with the weatherstripping and the windows going up and down properly. I don't mind spending money but I want the parts to be usable with as little problems as possible. Plus all i need is the rear side glass, my other glass is fine. Aside from the new windshield.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #2577112
11/11/18 02:20 PM
11/11/18 02:20 PM
JERSEY
RJS Online work
RJS  Online Work
JERSEY
Mike my 71 Super Bee AMD windshield and driver door glass with zero issues. The one big tell for me is they don't date code and the inscription is larger than Chrysler would have done.
If you want a date code and perfect inscriptions than ECS is the only place to call.
Ron
Re: my 69 rr black, pewter int and pewter painted roof [Re: RJS] #2597976
12/28/18 02:05 PM
12/28/18 02:05 PM
new jersey
new jersey
Rear glass all polished and all the stainless molding completely polished. Glass also installed.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #2597977
12/28/18 02:07 PM
12/28/18 02:07 PM
new jersey
new jersey
Passenger side door side glass all polished, rebuilt, assembled, regulators, and vent windows installed. The chrome vent windows from Tony's parts worked out nicely and look great.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #2598049
12/28/18 04:44 PM
12/28/18 04:44 PM
west palm beach, florida
modelmakerinc Offline
It is looking really sweet.
Is there any particular reason you are reassembling the car before it is finish painted, seems that there will be a good amount to be masked for color and hard to put the cat whiskers in and other details with the glass installed.
Just curious to know your order of build and why
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: my 69 rr black, pewter int and pewter painted roof [Re: modelmakerinc] #2598526
12/29/18 08:38 PM
12/29/18 08:38 PM
new jersey
new jersey
Most of the car is made up of reproduction parts. They can be test fit 10 times and still have to be messed with. Everything is edged in and put together and made to fit and work. The engine will also go in and be running as well as brakes and front end alignment before the car is painted. I would rather have all that finished then lean on fresh body and paint work and take the necessary steps when masking to prevent any damage to the body and paint work. Plus what is seen on some of these tv shows isn't always as simple as metal work, paint work, body work, paint, and assemble. It requires a lot of room. This car is being done in a home garage with the use of a spray booth from a shop. Thats a very logical question, its just the way I do things. When its finished you won't know how or why I did it this way.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #2601414
01/04/19 12:49 PM
01/04/19 12:49 PM
KY
65pacecar Offline
65pacecar  Offline
KY
Beautiful work. The glass looks great, what process did you use to polish it?
Re: my 69 rr black, pewter int and pewter painted roof [Re: 65pacecar] #2601630
01/04/19 07:07 PM
01/04/19 07:07 PM
new jersey
new jersey
I used a dual action polisher with 3m compound super duty compound on a wool pad, then a foam waffle polish pad w 3m micro-fine glaze and finally a black waffle foam pad w 3m glaze. It was a process. As for the moldings, I purchased a pneumatic Ingersol-Rand headlight polish kit. It had a wool pad, and 3 different foam polish pads. I used Mothers aluminum mag wheel polish on the polisher and the moldings came right up. Unbelievable they look new.. Again, it was a process over a couple of weekends but it makes all the difference.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #2602936
01/07/19 02:32 PM
01/07/19 02:32 PM
KY
65pacecar Offline
65pacecar  Offline
KY
The results are outstanding. I have some spare glass that I will practice on before trying it on my good stuff. Thanks.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #2603017
01/07/19 05:16 PM
01/07/19 05:16 PM
Kentucky
fc7freak Offline
fc7freak  Offline
Kentucky
I really enjoy watching your Roadrunner going back together. Check for it every day!
Re: my 69 rr black, pewter int and pewter painted roof [Re: fc7freak] #2605325
01/12/19 11:13 AM
01/12/19 11:13 AM
new jersey
new jersey
Thank you guys! The main thing that I'm trying to get out there is what materials work for me and how to do this stuff. Also it can be done at home. I'm not sure any of this can be on a budget and I will say I have a lot into this car. Even with me doing all the work, I have more than it will probably be worth. But, at the end of the day I'll know what I have and that its been done right.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #2605351
01/12/19 12:58 PM
01/12/19 12:58 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
That's the best reason to do your own car. up
Re: my 69 rr black, pewter int and pewter painted roof [Re: moparpollack] #2625071
02/23/19 01:21 PM
02/23/19 01:21 PM
new jersey
new jersey
Finally got a windshield installer to do the windshield. I didn't want to do the install because, well if it broke. Simple as that. I ended up calling about 15 shops that I work with and everyone who's left in this hobby. All the shops who do collision work said," man I wouldn't trust my guys to do that" and if I did find someone who would even speak with me they had no clue at the end of the day about the rubber windshield seal. IT WAS PAINFUL! The hobby is in the same trouble as everyone else, no one is doing this anymore. Anyway enjoy and if your in NEW JERSEY and need a guy let me know. thanks
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #2627848
03/02/19 12:11 PM
03/02/19 12:11 PM
new jersey
new jersey
Short block is all together. Motor should be complete for pick up in about 2 weeks. I'll get it painted up and bring it back to be dyno-ed.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #2629411
03/05/19 10:34 PM
03/05/19 10:34 PM
Superfreak
Superfreak
Are you still going to be able to install the chrome trim?
Re: my 69 rr black, pewter int and pewter painted roof [Re: ] #2629420
03/05/19 10:58 PM
03/05/19 10:58 PM
new jersey
new jersey
Yeah that's easy. The roof is not finished yet. There is one spot I am not happy with so it will be fixed and re sprayed. I didn't want the moldings on yet because of that.
