CLUTCH TORQUE SHAFT #257636
03/17/09 11:27 PM
03/17/09 11:27 PM
Central PA
Howard Offline OP
Howard  Offline OP
Central PA
on the clutch torque shaft for an A body should the arm holding the clutch adjusting rod angle toward the bell housing or be straight like the arm that connects to the clutch pedal? The bracket that is welded to the outside of the frame came loose and I think it may have bent the arm. I tried taking a picture of it but couldn't get it on this computer.
Howard
Re: CLUTCH TORQUE SHAFT [Re: Howard] #257637
03/18/09 04:38 AM
03/18/09 04:38 AM
Spring Hill, Fl.
tecmopar Offline
tecmopar  Offline
Spring Hill, Fl.
They both should be straight, good luck.
