Foam/air in master cylinder #257510
03/17/09 08:58 PM
03/17/09 08:58 PM
Townsville
3
3_wheelie Offline OP
Townsville
Attempted to bleed the brakes on my 67 dart tonight, but couldnt get a firm pedal. They're manual with a dual reservoir and the front disk swap.
No leaks through the system, but i was getting what appeared to be foam/air in the rear reservoir. I had the m/c cap on at all times unless i was refilling it.
Is my cap seal just bad (looked fine with no dry rot or swelling) or is it possible my M/C has an internal leak?
YutKillYut Grozny lives!
Re: brake bleeding troubles [Re: 3_wheelie] #257511
03/17/09 09:03 PM
03/17/09 09:03 PM
cheak the firewall behind the booster for fluid and check between the M/C and booster for fluid. the best way i found to bleed brakes is with a pump w/ resivoir and pump from the caliper up so the air pushes up threw the M/C. makes it a one person job and ensures no air. once you know your system is airless it will be easier to tell what causing your problem.
Re: brake bleeding troubles [Re: 3_wheelie] #257512
03/17/09 09:06 PM
03/17/09 09:06 PM
with (2) short pieces of tubing bleed the MC back into itself(bench bleeding) then hook up the regular brake lines & bleed them out. I also place a block of wood under the brake pedal so that I dont go past it's normal travel so the neoprene cups dont go past their normal wear area which(can) hasten their demise.
Re: brake bleeding troubles [Re: RapidRobert] #257513
03/18/09 03:45 PM
03/18/09 03:45 PM
Ohio
LS-300 Offline
LS-300  Offline
Ohio
You don't state why you needed to bleed the brakes. Did you replace parts or was the pedal just mushy? If it was just a musy pedal then I would say you have a leak thet is very small. This could be a rubber line or as you noted the master cylinder. Need more info.
1979 Chrysler 300 1968 Barracuda project
Re: brake bleeding troubles [Re: LS-300] #257514
03/18/09 07:08 PM
03/18/09 07:08 PM
Townsville
3
Townsville
Switched out my front drums for disks. new rubber lines up front to.
Re: brake bleeding troubles [Re: 3_wheelie] #257515
03/19/09 06:30 AM
03/19/09 06:30 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Are the disc bleeders facing up?Dont ask how I know.Rocky
Chrysler Firepower
Re: brake bleeding troubles [Re: therocks] #257516
03/19/09 04:44 PM
03/19/09 04:44 PM
Townsville
3
Townsville
ha yes they are. took extreme care to install everything correctly.
Re: brake bleeding troubles [Re: 3_wheelie] #257517
03/19/09 05:43 PM
03/19/09 05:43 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Pump slower. You need to allow the air to escape.
Re: Foam/air in master cylinder [Re: 3_wheelie] #257518
03/19/09 05:45 PM
03/19/09 05:45 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
Gravity bleed them
