Eldebrock RPM valve keepers.
#2575072
11/06/18 10:19 PM
11/06/18 10:19 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Could use some help, does anybody have any spare keepers for the BB eldebrock RPM heads? Was changing some springs and one went flying. Look at Summits site and you have to buy the whole pack, cant get just one. So it may end up being a $55 mistake, thought I would check here first before I pulled the trigger on a Full set. Thanks, Mike
Re: Eldebrock RPM valve keepers.
[Re: Sport440]
#2575300
11/07/18 01:36 PM
11/07/18 01:36 PM
fast68plymouth
So. Burlington, Vt.
BB rpm and e street heads still use machined locks.
Just put a set together recently.
The “issue”’with 7 deg machined locks is...... seems like every brand has a slightly different installed height.
I can tell you for certain that Crane(not sure about the latest incarnation), Comp, Edelbrock, and the ones I get from my local engine parts warehouse are all slightly different, and provide slightly different installed height.
I don’t like to use “one” lock from another batch. If I lose one, I get another “pair” to install on one valve.
[Re: Sport440]
#2575581
11/07/18 11:12 PM
11/07/18 11:12 PM
Posts: 43,287 Bend,OR USA
Cab_Burge
