Split Mono-leaf and driveshafts.
#2574792
11/06/18 12:39 PM
11/06/18 12:39 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
I'm about to start working on my Super Bee to have it ready to go for spring of 2019. One of the first needs is a driveshaft. I plan on changing the Super Stock springs out for a pair of mono-leafs before it hits the road again. My question is, should I wait until I change the springs before I order the driveshaft? I had never thought about it, but someone mentioned to me that I should wait to install the springs before I order.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
Re: Split Mono-leaf and driveshafts.
[Re: OhioMopar]
#2574801
11/06/18 12:49 PM
11/06/18 12:49 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I would for sure wait until the springs are in.
68 Barracuda Formula S 340
[Re: OhioMopar]
#2574809
11/06/18 01:08 PM
11/06/18 01:08 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
If you order the springs with the same front segment measurement you don't have to do springs first. Are you going with caltracs?
JAKES AUTOMOTIVE
[Re: JAKE68]
#2574821
11/06/18 01:18 PM
11/06/18 01:18 PM
OhioMopar
Mt.Gilead, Ohio
My thought is Caltrac springs and Assassin Bars.
[Re: OhioMopar]
#2574824
11/06/18 01:22 PM
11/06/18 01:22 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Personally I would wait but I use driveline service in Pittsburgh and if I call today I usually pick up my driveshaft tomorrow. I had one shortened once and picked it up the same day
[Re: OhioMopar]
#2574871
11/06/18 03:07 PM
11/06/18 03:07 PM
Posts: 610 Boise
Moparteacher
Boise
Cal trac mono's and assassin bars? Why the mismatch? Why not the whole shebang from Cal trac? Just curious. I ordered mine as a package, got free shipping and a discount, and it all works together. http://4secondsflat.com/CalTracs.htmlYa' I see now. The assassin bars look like a better build, more adjust ability.
[Re: Moparteacher]
#2575046
11/06/18 09:46 PM
11/06/18 09:46 PM
OhioMopar
Mt.Gilead, Ohio
Adjustability is what I was interested in. But I want the lighter spring than the heavy Super Stocks I have now.
[Re: BradH]
#2575101
11/06/18 11:04 PM
11/06/18 11:04 PM
OhioMopar
Mt.Gilead, Ohio
The wider range of adjustability is great, if you know how the various changes affect the way the car works. Otherwise, simpler is better and reduces the risk of getting lost in the process of getting the suspension dialed in. Good point. I still like the Smith Racecraft bars better.
[Re: OhioMopar]
#2575106
11/06/18 11:26 PM
11/06/18 11:26 PM
BradH
The wider range of adjustability is great, if you know how the various changes affect the way the car works. Otherwise, simpler is better and reduces the risk of getting lost in the process of getting the suspension dialed in. Good point. I still like the Smith Racecraft bars better. What is your ET goal?
[Re: OhioMopar]
#2575113
11/06/18 11:39 PM
11/06/18 11:39 PM
Posts: 4,457 Washington
madscientist
Washington
Adjustability is what I was interested in. But I want the lighter spring than the heavy Super Stocks I have now. How much lighter are the split mono's? My springs are marginal. Not sure if the cost difference is worth the weight savings.
[Re: BradH]
#2575117
11/06/18 11:44 PM
11/06/18 11:44 PM
OhioMopar
Mt.Gilead, Ohio
The wider range of adjustability is great, if you know how the various changes affect the way the car works. Otherwise, simpler is better and reduces the risk of getting lost in the process of getting the suspension dialed in. Good point. I still like the Smith Racecraft bars better. What is your ET goal? Absolutely as fast as I can get out of it. I have handicaps involved(heavy, clutch, 3.54 gear), but I'd like to hit 11.00's, then upgrade the top end of the engine.
[Re: madscientist]
#2575130
11/07/18 12:17 AM
11/07/18 12:17 AM
OhioMopar
Mt.Gilead, Ohio
I don't have a number in front of me, but the weight is significant, from what I understand. I'm sure someone here knows.
[Re: OhioMopar]
#2575338
11/07/18 02:51 PM
11/07/18 02:51 PM
Posts: 860 lancaster,california
johnnycuda
The Split Mono springs are roughly 52lbs per pair, which is about what one SS spring weighs.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: johnnycuda]
#2575353
11/07/18 03:20 PM
11/07/18 03:20 PM
madscientist
Washington
The Split Mono springs are roughly 52lbs per pair, which is about what one SS spring weighs. About half the weight. I'm surprised. Thanks for the info.
[Re: OhioMopar]
#2575422
11/07/18 04:32 PM
11/07/18 04:32 PM
BradH
Absolutely as fast as I can get out of it. I have handicaps involved(heavy, clutch, 3.54 gear), but I'd like to hit 11.00's, then upgrade the top end of the engine. The fact that it's a stick car means the clutch type & setup is another variable into the whole track-tuning process. You're not taking the easy route, that's for sure. BTW, my first Mopar was a '69 Super Bee 383 4-speed car. Wow, that was a loooooooooooooong time ago.
[Re: OhioMopar]
#2575424
11/07/18 04:35 PM
11/07/18 04:35 PM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
I'd wait until you have the springs installed and measure to be sure.
