Dana 60 - where to get? #2574039
11/04/18 07:35 PM
11/04/18 07:35 PM
MarkZ Offline OP
Worthy
MarkZ  Offline OP
Worthy
Looking for a Dana 60 housing and I don't know what vehicles I should look at. I'm not worried about it being machined for a snubber since the car will have Caltracks. Are there any differences I need to worry about with later housings from the 90's? Looks like a couple mid 90's Ford F-250 trucks in the local you-pick-it yard.
Thanks...
Re: Dana 60 - where to get? [Re: MarkZ] #2574100
11/04/18 10:20 PM
11/04/18 10:20 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
late 80's f250 vans
Re: Dana 60 - where to get? [Re: MarkZ] #2574115
11/04/18 10:55 PM
11/04/18 10:55 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Mid 90 fords F250's do not have Dana rear axles. They are the 10.25" and rarely fail so nobody buys them. Did you look under them? Do you know what a Dana 60 cover looks like?
Re: Dana 60 - where to get? [Re: MarkZ] #2574118
11/04/18 10:57 PM
11/04/18 10:57 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
I've seen a few D200 Dodge pickups for sale cheap with D60's under them.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Dana 60 - where to get? [Re: MarkZ] #2574131
11/04/18 11:05 PM
11/04/18 11:05 PM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
Pretty much any '60s to '80 3/4 ton truck dana 60 will work.
The one i put in my diplomat came out of a '79 Ford F250, and i built it to '68-'70 b body specs.
Re: Dana 60 - where to get? [Re: MarkZ] #2574139
11/04/18 11:13 PM
11/04/18 11:13 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
The best one I found was in a mid 60's Ford halfton and it had a power lock in it. I just had to change the sidegears to 35 and narrow it. I think 70's 3/4 ton pickups are the best source but they're getting harder to find in junkyards.
Sheldon
Re: Dana 60 - where to get? [Re: MarkZ] #2574206
11/05/18 01:04 AM
11/05/18 01:04 AM
All Dana rear ends,27,30,44,60 series and so on are mark with the casting number of that housing on the passenger side bottom rear axle brace scope
Dana 60 rear and front axles came with several different axle tube outside diameters, 2.5,3.0, 3 1/8, 3 1/4 and as large as 3 1/2 inch O.D. shruggy
Look for a Dana 60 housing with the 3.0 O.D. axle tubes to use with stock 8 1/4, 8 3/4 and 9 1/4 inch Mopar car rear ends that had the same size U bolts to hold the rear end onto the leaf springs scope
Re: Dana 60 - where to get? [Re: MarkZ] #2574461
11/05/18 04:08 PM
11/05/18 04:08 PM
MarkZ Offline OP
Worthy
MarkZ  Offline OP
Worthy
I appreciate the input everyone. Reason I'm looking at the local pick yard is I can get housings for $100. There isn't anything wrong with my 8.75", so I can take my time looking for one. With this being a rust belt State anything older than 90's is extremely slim. I was unaware that 90's Fords no longer had Dana axles. I also didn't think about the axle tube diameter. Thanks again guys!
Re: Dana 60 - where to get? [Re: MarkZ] #2574467
11/05/18 04:17 PM
11/05/18 04:17 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
A ford van is an E250 and they did have Dana 60's in the 80's. Look on the cast iron center from the rear and you will see 60 or 70 cast in there. You don't want a Dana 70. And you do want the 3" axle tubes. Good thing you have time to find the right one.
Re: Dana 60 - where to get? [Re: NANKET] #2574474
11/05/18 04:28 PM
11/05/18 04:28 PM
dogdays Offline
dogdays  Offline
I believe Ford vans also had Dana 61s under them, as did Dodge.
R.
Re: Dana 60 - where to get? [Re: MarkZ] #2574532
11/05/18 06:54 PM
11/05/18 06:54 PM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
Around '87 Ford started using the Sterling rears in trucks, but I've seen vans with Dana 60s into the '90s.
Re: Dana 60 - where to get? [Re: MarkZ] #2574901
11/06/18 04:15 PM
11/06/18 04:15 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
More like they started in 1984 or1985. I own and 86 and look at 85 and 86 fords in wrecking yards, they ALL have the 10.25 axles.
1983's still have danas.
Re: Dana 60 - where to get? [Re: MarkZ] #2582502
11/24/18 07:25 PM
11/24/18 07:25 PM
MarkZ Offline OP
Worthy
MarkZ  Offline OP
Worthy
Just an update: I found a D60 that was pulled out of an 1983 F250 on Craigslist and got it for $150. Already dropped if off at the shop to start work. Thanks again guys!
Re: Dana 60 - where to get? [Re: MarkZ] #2583471
11/27/18 12:00 AM
11/27/18 12:00 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Since the wrecking yard will only have 3/4 ton truck stuff. Have you considered a new S60. There are many advantages with this route.
Re: Dana 60 - where to get? [Re: MarkZ] #2583547
11/27/18 02:53 AM
11/27/18 02:53 AM
AndyF Online content
AndyF  Online Content
This is going in your 5th Ave? You might be the first guy to have a Dana 60 in a 5th Ave!
Re: Dana 60 - where to get? [Re: AndyF] #2584850
11/29/18 08:45 PM
11/29/18 08:45 PM
MarkZ Offline OP
Worthy
MarkZ  Offline OP
Worthy
Heh, maybe for a 5A, but not an M. There is guy on here with one in a Diplomat. I've been wanting to change axle ratios back to 3.5x and the D60 thread on here got me thinking about the porker of a car I have with Caltracks and drag radials. Figured better safe than sorry.
I need to figure brakes out now. From what I've read since I'm having the housing shortened I should use Ford ends and Explorer disk brakes. I'll go yard hunting soon for caliper brackets.
This forum has been an absolute wealth of knowledge.
Re: Dana 60 - where to get? [Re: MarkZ] #2584912
11/29/18 10:55 PM
11/29/18 10:55 PM
Talk to Doctor Diff on the brakes. I'm sure he will recommend going with Ford ends and some sort of Ford brake system but he also has classic Mopar stuff if you want that. Might as well put disc brakes out back while you're doing all the work.
Re: Dana 60 - where to get? [Re: MarkZ] #2584941
11/29/18 11:35 PM
11/29/18 11:35 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
I would go with the ford ends and explorer brakes.You used to be able to buy complete explorer brake kits for reasonable price.
Re: Dana 60 - where to get? [Re: JAMESDART] #2584947
11/29/18 11:51 PM
11/29/18 11:51 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
iagree
that is what i did
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Dana 60 - where to get? [Re: astjp2] #2608560
01/18/19 01:37 PM
01/18/19 01:37 PM
MarkZ Offline OP
Worthy
MarkZ  Offline OP
Worthy
Just an update: got a housing from a 1983 F-250 off of Craigslist right before Christmas and had it rebuilt using parts from Doctor Diff. Power Loc, 3.54 and Ford Explorer discs. Can't wait to install it. Thanks again everyone.
