Re: Feedback using Evapo-Rust Wanted [Re: vinnyd76] #2572972
11/02/18 12:09 PM
11/02/18 12:09 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
How does the evaporust compare to using vinegar? I have had good luck with vinegar removing rust, however if left too long the acid in it will eat metal as well. I stripped the chrome off something with it.
Re: Feedback using Evapo-Rust Wanted [Re: DaytonaTurbo] #2573105
11/02/18 04:47 PM
11/02/18 04:47 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Evaporust won't eat metal, although it will eave an etch line if anything sticks up above it.
Re: Feedback using Evapo-Rust Wanted [Re: Neil] #2573123
11/02/18 05:35 PM
11/02/18 05:35 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
I would have to agree with that also.
Everything that i have thrown into a Evaporust pail for the past 10 years of using the product, has come out a ok.
Never had any problems of "eating" any of the metal away.
And i have forgotten to take things out, many times, after putting them in the pail.
But the great majority of parts that i soak out are brake parts, suspension parts, engine parts, nuts and bolts.
What kind of parts would people be thinking of, getting "eaten"? shruggy
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Feedback using Evapo-Rust Wanted [Re: vinnyd76] #2573125
11/02/18 05:48 PM
11/02/18 05:48 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Are 'etch' and 'eaten' really two different things?....molecularly thinking here...
Re: Feedback using Evapo-Rust Wanted [Re: PurpleBeeper] #2573254
11/02/18 10:36 PM
11/02/18 10:36 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Evaporust contains acid. Acid will eat rust first, but will also start to eat metals after that.
For me personally, I would have no problem at all using it on the outside of a rear end "pumpkin". Since the cast iron is so thick, it wouldn't hurt a thing. I would also soak the gears inside the pumpkin, but not leave it in the Evaporust too long (maybe an hour or two) so that I didn't eat away very much of the important metal inside the pumpkin. My 2-cents.
No acid in Evaporust, from their website:
BIODEGRADABLE
Evapo-Rust® rust remover is safe on skin and all materials except rust! It's also biodegradable and earth-friendly. Water soluble and pH-neutral, Evapo-Rust® is non-toxic, non-corrosive, non-flammable, and contains no acids, bases, or solvents. Evapo-Rust® is simply the safest rust remover.
Re: Feedback using Evapo-Rust Wanted [Re: vinnyd76] #2573350
11/03/18 10:06 AM
11/03/18 10:06 AM
nj
JAMESDART Offline
JAMESDART  Offline
nj
I tried evaporated, it works great but it’s expensive. I then used the vinegar salt recipe a member came up with on here. It works great also but yes it will eat a part of left too long. I had to clean and dry really well after or it would flash rust instantly. I used to keep it in a black plastic tote out in the sun and it seemed to work year round, but definitely better when hotter. When I finally dumped it out there was about 6” of rust sitting on the bottom of the tote. There was a guy on one of the forum that put his connecting rods in evaporust overnight. When he went to assemble his engine the pins slipped right through, no more press fit.
Re: Feedback using Evapo-Rust Wanted [Re: vinnyd76] #2573417
11/03/18 12:44 PM
11/03/18 12:44 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Keep in mind that rust is the corrosion of metal, if the rust is removed, the rusty part will then become smaller.
Re: Feedback using Evapo-Rust Wanted [Re: ScottSmith_Harms] #2573536
11/03/18 06:23 PM
11/03/18 06:23 PM
A727Tflite Offline
A727Tflite  Offline
Smaller on the OD and larger on the ID.
Re: Feedback using Evapo-Rust Wanted [Re: A727Tflite] #2573563
11/03/18 07:26 PM
11/03/18 07:26 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I've had some small parts in it soaking for quite some time, (months).
After reading this, I want to rinse 'em off and see how they look.
What do you folks recommend to rinse?
I have mechanical Aptitude.
I can screw up anything.
Re: Feedback using Evapo-Rust Wanted [Re: vinnyd76] #2573690
11/04/18 12:34 AM
11/04/18 12:34 AM
nj
JAMESDART Offline
JAMESDART  Offline
nj
Yeah I get that. He claimed they weren’t rusty and there was no rust in the pin bores. I don’t know I didn’t witness it, he seemed like a reputable guy. I’m just putting it out there, i wouldn’t uae it on something with precision machine surface.
Re: Feedback using Evapo-Rust Wanted [Re: vinnyd76] #2573693
11/04/18 12:38 AM
11/04/18 12:38 AM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
I love evaporust. Just don't let it evaporate with a part in the solution. Creates a real mess.
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: Feedback using Evapo-Rust Wanted [Re: vinnyd76] #2573775
11/04/18 09:45 AM
11/04/18 09:45 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
I have been very impressed with Evaporust’s mild affect on everything but the rust.
It is pH neutral, neither acid like vinegar, or basic like lye.
Moparts has a long thread on this:
https://board.moparts.org/ubbthreads/ubbt...tml#Post2260350
I usually have to lightly stainless steel brush the surfaces every 12 hours.
I still suspect old Evaporust could be recycled by adding either strong acid (or strong base) to get the “chelated iron” to release into liquid and drop to the bottom of a container, then neutralize back to a pH of 7. Strong magnets might help do this quicker.
I have not tried Evaporust in a small ultrasonic bath yet, but intend to.
I also have a
Tide/ Black&Decker “Buzz” brand ultrasonic probe
I intend to use in combination with Evaporust in a larger tank.
https://www.ebay.com/i/123165492683?chn=...195a6a0fff9bad1
I bought a one gallon jug of 4:1 concentrate Safest Rust Remover but have not used it yet.
I intend to pump it as a spray against the underside of a pickup and catch the drippings in a kiddie swimming pool for recycle to the pump.
I bought some “Washing Soda” and intend to try Electrolosis rust removal in a plastic container using a 12 volt 1.6/2/10/50 amp battery charger.
Re: Feedback using Evapo-Rust Wanted [Re: vinnyd76] #2573868
11/04/18 01:44 PM
11/04/18 01:44 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I recently cleaned up some original A-body rear drums with Evaporust, first pic is one before and one after. That is original red paint on both. Overnight soak and a rinse in lacquer thinner followed by some light scrubbing with a 0000 steel wool pad to remove the black residue and these are the results.
Re: Feedback using Evapo-Rust Wanted [Re: ScottSmith_Harms] #2573944
11/04/18 04:30 PM
11/04/18 04:30 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
My hardware came out great.
I just cleaned 'em of with a rag and sprayed with silicone based lubricant.
