Re: 472 or 528
[Re: HEMIDOG 70]
#257329
03/17/09 07:09 PM
03/17/09 07:09 PM
Posts: 10,144 A Red State
SNK-EYZ
A Red State
All I can say is "Cubic inches rule!" The Hemi I'm building was started out being planned as a 528 and is now going to be a 572 thanks to a 4.5 stroke Keith Black crank.
Re: 472 or 528
[Re: ahy]
#257334
03/18/09 04:36 AM
03/18/09 04:36 AM
Posts: 470 Big Chicago
amixon
Big Chicago
528 for sure! Do you already have the crank? Bigger is better in this case, just make sure your drop top is braced and tied! You should be able to get better than 8 mpg, and a once 'radical' cam will be tame in the bigger engine. Build for torque if it is a cruiser and keep your rpm range realistic and you should be able to pull this off with no problem!
Re: 472 or 528
[Re: HEMIDOG 70]
#257337
03/18/09 05:42 AM
03/18/09 05:42 AM
Posts: 4,687 VA
69 Road Runner
VA
The Tim Banning built 528 Hemi in my RR vert is very streetable and gets 10 mpg on the highway if I go easy.
I also have 3.23 gears and tall rear tires.
69 Road Runner Vert
Re: 472 or 528
[Re: quickd100]
#257339
03/18/09 08:22 AM
03/18/09 08:22 AM
Posts: 4,923 new berlin wisconsin
Mr T2U
go 572. or better yet even more. see HEMIVIPERS triple black 71 charger listed in the B bodies for sale section.this was my buddies old car. 612ci runs on pump gas, low gears and LOTS of torque so the low gears won't slow you down. when my friend had 2.76 gears in the rear i think he got over 10 on the highway with the A/C on. and that's with a dominator carb.
perception is 90% of reality
