Page 3 of 3 1 2 3
Re: Tig welder recommendations [Re: RV2] #2572483
11/01/18 01:49 AM
11/01/18 01:49 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I used an ac/dc hobart buzz box, a simple air cooled tig torch and 75/25 gas for decades before I upgraded to my Lincoln 225 precision tig. There are high freq adapters that you can add to the buzz box for dirt cheap if you are on a serious budget, and it would weld 1/4" aluminum or 4130 all day long.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Tig welder recommendations [Re: Stanton] #2572785
11/01/18 10:20 PM
11/01/18 10:20 PM
Way North Idaho
1KoolBee Offline
1KoolBee  Offline
Way North Idaho
Originally Posted By Stanton
My first choice - before buying the Thermal Arc - was the Everlast. Made in China but to a very high standard. Also and inverter with all the bells and whistles. I went with the Thermal Arc because its a long established company.
I'm not at all a fan of Chicom tools, but Ditto on Everlast unless you have Big $ for Miller, ESAB, or Lincoln inverter. Loaded with features and adjustability. Chicom built, American design with Siemens Rectifiers, 5 yr warranty, great price, but not exactly inexpensive. Get upgraded CK Torch and pedal. I bought the 250EX inverter, less than 1/2 the cost of similar featured welder from Big Blue, and I'm definitely happy with it. Check out
https://www.youtube.com/watch?v=TjDSeY_SUpo
pretty interesting video. Everlast started out several years ago and quality control wasn't great at first, but they've steadily improved and now they are pretty solid. I believe Alpha run by the brother of the guy at Everlast, so there's probably some design overlap there.
Sometimes you can find good used American units but out on the welder's forums there's plenty of complaints about built-in-China board failures in name-brand "American" inverter welders. These boards are expensive unless you have a warranty....which most used units don't.
Really old Millers, ESAB, Lincoln, etc transformer welders are bulletproof, but they draw a ton of power and lack features like HF start and pulse. Sometimes you can get them with an external accessory box that adds those features, but unless you have 100 amp service in your garage, you won't be able to get full power out of them.
Also I second the recommendation to check out "Welding tips and Tricks". Also Tig Time on weld.com. Lots of great reviews of various TIG welders plus great pointers for newb's.
If you want a multi-Process machine(MIG/TIG/STICK):
https://www.youtube.com/watch?v=X7hnR-JHlzA
'68 Bee 383/TF/Factory Air...high school sweetheart
'67 GTX Clone project,500 six pack,Hemi4-speed,Dana
05 Dodge Viper, 505 V-10, 6-speed Tremec
Re: Tig welder recommendations [Re: 1KoolBee] #2572843
11/02/18 12:19 AM
11/02/18 12:19 AM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Originally Posted By 1KoolBee
...I bought the 250EX inverter, less than 1/2 the cost of similar featured welder from Big Blue, and I'm definitely happy with it. Check out
Impressive, one 11-minute long sentence.
ToT has a new Tig video for youtubers:
https://www.youtube.com/watch?v=HOL1bMC-UJQ
Re: Tig welder recommendations [Re: RV2] #2572881
11/02/18 02:59 AM
11/02/18 02:59 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I just seen the new videos of the Miller Multimatic 220 AC/DC multiprocess machine. Looks pretty nice for a easy setup entry level machine that has a bunch of options.
MIG (3/8"), Stick (3/8"), TIG AC/DC/Pulse (1/4"), connections for two shielding gasses (don't have to swap bottles when changing from Mig to Tig.)
Priced at $2,999 with free shipping and offer for free Miller Digital Helmet.
Looks like it comes with just about everything except the dual cylinder welder cart that is another $295.
https://www.weldingsuppliesfromioc.com/m...ChoCzm4QAvD_BwE
Millers YouTube videos:
https://www.youtube.com/user/nielsmiller/videos
Re: Tig welder recommendations [Re: RV2] #2572890
11/02/18 03:55 AM
11/02/18 03:55 AM
Way North Idaho
1KoolBee Offline
1KoolBee  Offline
Way North Idaho
In retrospect, if these new multiprocess machines existed when I bought my TIG, I would have ditched my millermatic and bought one of these. Here's a comparison chart I ran across. Any of them would be great machines
Attached PDF document
Re: Tig welder recommendations [Re: 1KoolBee] #2572951
11/02/18 11:31 AM
11/02/18 11:31 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I have read a lot here, about some machines needing a "ton" of power. Somebody explain to me, I thought conservation of energy applied to Chinese welders also. I got an old school transformer Tig machine and it weighs in the neighborhood around 800lbs. If I put the pedal down if sure puts out a lot juice to the tig electrode, and expectedly draws a lot of current. The machine internally does NOT give off any real noticeable/excessive heat. Therefore I assume it is reasonably efficient in converting the building power to welding power, conservation of energy and all. So other then the new inverters being magnitudes lighter, how exactly are they reportedly magnitudes more efficient in this process?
My Miller welder at 500A draws 205 Amps at 208V, a Miller inverter at 500A draws 136 Amps at 208V, that means to me there is a loss (wasted heat inside machine) of nearly 70amps at 208V, that is a lot of energy.
Re: Tig welder recommendations [Re: jcc] #2572978
11/02/18 12:20 PM
11/02/18 12:20 PM
moparx Online content
moparx  Online Content
my old 200a airco machine has ac/dc/stick/tig with a brand new, still in the box, 175a scratch start tig torch i have never tried. at my age, i will most likely never do much tig work, that is, if i ever teach myself how to in the first place. biggrin
beer
Re: Tig welder recommendations [Re: jcc] #2573005
11/02/18 01:12 PM
11/02/18 01:12 PM
Way North Idaho
1KoolBee Offline
1KoolBee  Offline
Way North Idaho
Lincoln's website explains pretty well:
https://www.lincolnelectric.com/en-us/support/process-and-theory/pages/inverter-power-detail.aspx
Smaller transformers used with big transistors and big capacitors. Same reason that audio amplifiers used to weigh a ton just to get 100W RMS into 2 channels, now you can get 135W RMS into 7 channels in the same sized box.
Re: Tig welder recommendations [Re: RV2] #2578999
11/16/18 01:09 AM
11/16/18 01:09 AM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
I bought the Lincoln square wave 200
Re: Tig welder recommendations [Re: RV2] #2579007
11/16/18 01:24 AM
11/16/18 01:24 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Get back to us when you can weld a cut in half leak proof beer can back together. laugh2 up
Re: Tig welder recommendations [Re: RV2] #2579023
11/16/18 02:40 AM
11/16/18 02:40 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I don't recall the brand of big welder but a guy I knew years ago showed me that he could weld 2 paper staples together and also the pop can.
Re: Tig welder recommendations [Re: RV2] #2579028
11/16/18 03:02 AM
11/16/18 03:02 AM
CA
crackedback Offline
crackedback  Offline
CA
I always liked my Miller Syncrowave 250 before it walked away...
Solid old school unit.
Re: Tig welder recommendations [Re: RV2] #2579086
11/16/18 12:01 PM
11/16/18 12:01 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Let us know how you like it. up Be sure to check out the trucolor helmets.
Page 3 of 3 1 2 3
