Batter Charger and Tender #2572776
11/01/18 10:04 PM
11/01/18 10:04 PM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
Hi! I am looking to buy a battery charger and tender for a 1970 Plymouth GTX. Any good recommendations for a decent price? Sorry, if this is in the wrong section. It's going to be a long winter. penguinhat
Working on cars teaches you patience... and every curse word imaginable.
1970 Plymouth GTX -- A true gentleman's coupe, but a serious muscle machine.
Re: Batter Charger and Tender [Re: GTXKARL] #2572786
11/01/18 10:22 PM
11/01/18 10:22 PM
Andrewh Online content
Andrewh  Online Content
it kind of depends on what battery you are running.
like agm would be slightly different than a standard wet cell battery.
I used to like batery tender brand, but found that when they don't work the company charges you to send it in and back to yourself under warranty work.
so I switched to schumaker brand.
for agm battery I use ctek brand chargers for that kind of battery.
but it is 20 to 30 for the shumaker brand and 100 for the ctek.
Re: Batter Charger and Tender [Re: GTXKARL] #2572797
11/01/18 10:50 PM
11/01/18 10:50 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
I bought TWO diff chargers ... One with a fast charge for activating the battery WITH like a 10 and 5 amp setting THEN one as a tender only. The digital one at Wally World is a good one there.
Re: Batter Charger and Tender [Re: GTXKARL] #2572812
11/01/18 11:23 PM
11/01/18 11:23 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
WE did use Battery Tenders but have switched to Optimate smart chargers. They charge all types of batteries. Optimate 3 is the least expensive and basic. We also have a couple of Optimate 6's.
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: Batter Charger and Tender [Re: GTXKARL] #2572827
11/01/18 11:45 PM
11/01/18 11:45 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
We had 1 Battery Tender short out internally and actually melted its case..
We called Battery Tender and reported this event, they sent me a new one no charge. Then 2 weeks later they called me back and said their engineers wanted the defective unit back for investigation.. Too late already thrown into the dumpster.
Anyway after that dangerous incident with Battery Tender I found a device called Battery Minder, works much better than the Battery Tender. Plus it has an instantaneous high-voltage spike charge to burn off the sulphate than can form on the cells and destroy a battery..
I highly recommend the Battery Minder, I use (3) of them no problems..
Here is the link if interested..
https://www.amazon.com/BatteryMINDer-Model-1500-SmarTECHnology-Motorcycles/dp/B00D7HZ6FC
Just my $0.02... wink
Re: Batter Charger and Tender [Re: GTXKARL] #2572866
11/02/18 01:28 AM
11/02/18 01:28 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'm using the Schumacher battery tenders. I have 2 types, one will charge both conventional and AGM batteries. Cost is mid $20s.
Several of them are 3-5 years old & still working perfectly; I've had the Black & Decker units but they didn't last as long.
Re: Batter Charger and Tender [Re: GTXKARL] #2572880
11/02/18 02:48 AM
11/02/18 02:48 AM
WA
tman Offline
tman  Offline
WA
I have been using the Batt Tender Plus for 20 yrs. My first one wore out after 11 yrs. Now Im on my second one. I have this connected during the entire winter and when its parked in the garage in the spring/summer. I like it and it does charge agm or gel batt. I do use a Ctek for my Honda generator. I like them both. Im sure the others mentioned are good to. Don't get a cheap one. Lots of reviews if you check online on other units mentioned.
Re: Batter Charger and Tender [Re: GTXKARL] #2572913
11/02/18 08:41 AM
11/02/18 08:41 AM
A certified culture free zone.
74RALLYE Offline
74RALLYE  Offline
My Craftsman "microprocessor controlled" 12V charger fried 2 batteries before I junked it. One was an Optima and the other was a regular lead/acid 12V battery. Charging overnight left batteries sizzling by morning. Expensive lesson. My Schumacher works fine.
Re: Batter Charger and Tender [Re: GTXKARL] #2573477
11/03/18 03:01 PM
11/03/18 03:01 PM
5thAve Offline
5thAve  Offline
i don't trust any kind of tender. Way too much chance of something inside going bad and causing problems. For years I've disconnected my batteries and charge them once or twice over winter.
Re: Batter Charger and Tender [Re: GTXKARL] #2573483
11/03/18 03:18 PM
11/03/18 03:18 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
I run both cars about a half hour every 5/6 weeks,never need a charger or tender and both reproduction batteries are over 7 yrs old,one is actually 10.
Re: Batter Charger and Tender [Re: GTXKARL] #2573876
11/04/18 02:18 PM
11/04/18 02:18 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
The Deltran brand battery tender is good, we sell them at work and have had no complaints.
I also like the Optima Battery Charger. I have the smaller version and it works very well on any type of battery.
68 Barracuda Formula S 340
Re: Batter Charger and Tender [Re: Sinitro] #2573978
11/04/18 05:31 PM
11/04/18 05:31 PM
Illinois
StrkrDart69 Offline
StrkrDart69  Offline
Illinois
Battery Minder works. I have used Battery Tender, Schumacher. And others. Then I found this one. The desulfator works. My last Battery Tender was junk. Car would sit for a month or 2 on the Tender and I still had to charge Battery. Found Battery Minder and no more problems. I threw out the junk Tender and started using the Minder, same Battery and never had a problem again. Going on 3 years same Battery.
Re: Batter Charger and Tender [Re: GTXKARL] #2574000
11/04/18 06:08 PM
11/04/18 06:08 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
I have Mac tools maintainer/charger. It will do 6 or 12 volt, agm or standard batteries. It seems to work good. I started just using it for a day every couple weeks if I don't run the car instead of leaving it on all the time.
Re: Batter Charger and Tender [Re: GTXKARL] #2574138
11/04/18 11:12 PM
11/04/18 11:12 PM
WA
tman Offline
tman  Offline
WA
More info is google "Top 10 battery maintainers." This can help with research. Then consider what's on top on most of these articles.
The Battey Minder looks pretty good based on their website and sellers. Not much in any of these articles though. I would not mind trying Battery Minder, but only after my Battery Tender wears out. Im on a Repro Mopar agm batt by Turbostart I have owned since 2010 and battery is doing great on the Tender.
Only other charger I like is my Ctek that I use on my generator. It has a selector for the smaller M/C batt. My generator has a wet cell unit and so far that batt is 6 yrs old.
Re: Batter Charger and Tender [Re: GTXKARL] #2574147
11/04/18 11:21 PM
11/04/18 11:21 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Xtreme brand works great as a charger and desulfates the plates..it has restored alot of batteries I have normally thrown out.
Re: Batter Charger and Tender [Re: GTXKARL] #2574209
11/05/18 01:09 AM
11/05/18 01:09 AM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
I have been using DelTran battery tenders for years with good results and no issues. I always keep one on my Harley and my play cars while they are parked.
Scott
1969 Super Bee, 383/4 speed
Re: Batter Charger and Tender [Re: StukaJU87] #2574289
11/05/18 10:18 AM
11/05/18 10:18 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
how do you bench test these battery minders.i have 2 brand new ones that dont seem to work.
