Need to strip a K-frame #2572676
11/01/18 05:32 PM
11/01/18 05:32 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Has anyone stripped their K-frame of paint to weld the re-inforcement kit? I'd love to bring it to someone locally (Northern Ohio)to have tanked in whatever would work.
It's been painted recently by the previous owner and he did too good a job to try and weld without stripping completely.
Thanks, Joe
Re: Need to strip a K-frame [Re: jlatessa] #2572707
11/01/18 06:53 PM
11/01/18 06:53 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
There may be a better way to do it, but I had mine glass bead-blasted. It came out pretty clean. You just need to hit it with compressed air, to blow out all the dust and media particles. Then clean the metal with some SEM pre-paint prep or similar.
Re: Need to strip a K-frame [Re: jlatessa] #2572748
11/01/18 08:41 PM
11/01/18 08:41 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Mine was blasted but dipping it in something would get in there...but then you certainly want to dip it to top coat it as well.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Need to strip a K-frame [Re: jlatessa] #2572759
11/01/18 09:14 PM
11/01/18 09:14 PM
Kirkland, Washington
Pacnorthcuda Offline
The down and dirty method is simple.
Get a can or two or engine cleaner, go to the local DIY car wash. Wear dirty clothes. Spray the K frame all over and let sit 10 minutes or so.
Load up the machine and blast away with their engine cleaner setting.
Rinse.
Re: Need to strip a K-frame [Re: Pacnorthcuda] #2572764
11/01/18 09:26 PM
11/01/18 09:26 PM
IN
ahy Offline
ahy  Offline
IN
Hot tank (like an engine block) and sandblast works well. Hot tank gets the grease and paint off and sand blast gets the rust off.
Just avoid silica sand on weld areas. Or if silica is used, sand the weld areas. Silica residue contributes to weak porous welds.
Re: Need to strip a K-frame [Re: jlatessa] #2572774
11/01/18 09:57 PM
11/01/18 09:57 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
i blast lots of k members but you cant get inside good enough to get all the grease out. hot tank is your best bet for perfect. i would tank, replair/weld then blast to prep for paint.
Re: Need to strip a K-frame [Re: jlatessa] #2572781
11/01/18 10:12 PM
11/01/18 10:12 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
And don't be surprised if more cracks show up after blasting.
Have a great day
Iowan
"obsolete is neat"
Re: Need to strip a K-frame [Re: jlatessa] #2572855
11/02/18 12:58 AM
11/02/18 12:58 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I had one years ago that was greasy as hell everywhere...it didn't rust at all but I never thought I'd get the oil off of it enough to weld it up and paint it.
Washed everything off as well as I could at the car wash and then ended up using a rosebud tip on a torch up through the middle and baking all the crap out of it...cleaned up a lot easier...
It still only has primer on it...I'm not painting it until everything is ready to be assembled...
...FAFO...
Re: Need to strip a K-frame [Re: jlatessa] #2572875
11/02/18 02:06 AM
11/02/18 02:06 AM
Australia
dodgy Offline
dodgy  Offline
Australia
I recently cut mine open and the amount off crud left inside after I had hit it with degreaser and pressure washer was eye opening, I cut it open to knock out dents, add a gusset and mod some scallops to clear my oil pan.
Re: Need to strip a K-frame [Re: jlatessa] #2572879
11/02/18 02:44 AM
11/02/18 02:44 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Take it to a radiator shop.
Re: Need to strip a K-frame [Re: jlatessa] #2572931
11/02/18 10:00 AM
11/02/18 10:00 AM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
This frame is clean as a whistle, so oil/grease is not a problem.
The local radiator shop said they didn't think their tank would strip the paint.
Wow, Dodgy, I've never seen a frame dismantled like that, quite a job!!
Anyhow, I think I'll take to the sandblast place I've had do other large parts
and go from there.
I know they can't do anything about the the paint that migrated into the cracks around the perimiter, so welding on the seams will be problematic.
i'll resign myself to do the gusseting with the kit and leave it at that.
Thanks for all the ideas, Joe
Re: Need to strip a K-frame [Re: jlatessa] #2572946
11/02/18 11:15 AM
11/02/18 11:15 AM
Milan Ohio
ct440rod Offline
ct440rod  Offline
Milan Ohio
Where you at in Northern Ohio . . I had my rims dipped in sandusky ohio
Re: Need to strip a K-frame [Re: jlatessa] #2573014
11/02/18 01:34 PM
11/02/18 01:34 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
I'm East of Cleveland, CT, an hour away.
I'd appreciate a contact # , I'll give them a call and see...Thanks, Joe
Re: Need to strip a K-frame [Re: jlatessa] #2573184
11/02/18 07:50 PM
11/02/18 07:50 PM
Milan Ohio
ct440rod Offline
ct440rod  Offline
Milan Ohio
American Quality Stripping / 419-625-6288
You can look up website http://americanqualitystripping.com/
Re: Need to strip a K-frame [Re: jlatessa] #2573252
11/02/18 10:31 PM
11/02/18 10:31 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Thanks CT, I requested a quote on line.
Appreciate the help, Joe
Re: Need to strip a K-frame [Re: jlatessa] #2573705
11/04/18 01:08 AM
11/04/18 01:08 AM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
I had mine baked at the local machine shop all the grease and oil has burned off
NS1AAR
Re: Need to strip a K-frame [Re: jlatessa] #2573881
11/04/18 02:28 PM
11/04/18 02:28 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Oven cleaner smokes the built up crud, just keep it off you and anything that has nice paint on it.
Carl Kessel
