Re: Hemi oil consumption [Re: fast68plymouth] #2571831
10/30/18 10:12 PM
10/30/18 10:12 PM
Tennessee
Hemi ragtop Offline OP
Tennessee
Originally Posted By fast68plymouth
Fundamentally I agree with Chip.
It’s probably an oil control issue with the rings....... for one reason or another.
That being said, I’d swap out the intake seals first to rule that out before pulling the motor.
But honestly, I wouldn’t expect it to use a qt in 125 miles even if it had no valve seals.
As for worn guides....... I freshened and ported a set of iron hemi heads off a MP crate motor that had 70,000 miles on it........ the guides were still perfect. I was shocked...... but miracles happen every now and then.
Of course, I also went through a set that only had the dyno time on them...... that had a few ex guides with .009 clearance, and the tightest intake was about .005.
Hey thanks. This is the type of info that I needed! Two days of struggling to just get the header bolts loose on the passenger side. I think I will pull the engine just to check out the lower end. I would hate to go through this again!
Re: Hemi oil consumption [Re: Hemi ragtop] #2571833
10/30/18 10:13 PM
10/30/18 10:13 PM
Tennessee
Tennessee
So, what should I shoot for in valve guide clearance!
Re: Hemi oil consumption [Re: Lee446] #2571852
10/30/18 10:42 PM
10/30/18 10:42 PM
Tennessee
Tennessee
It has taken three nights just to take 9 header bolts loose on one side. I sure don't want to do this again. So I think I will pull the engine and check EVERYTHING!
Re: Hemi oil consumption [Re: Lee446] #2571890
10/30/18 11:42 PM
10/30/18 11:42 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Originally Posted By Lee446
Dwayne, whar guide clearance do you usually go for? And what seals do you recommend?
I don’t have tons of hemi experience to draw upon....... but the trend seems to be that they run more clearance than what would be typical for that stem diameter..... at least for a street duty motor.
I don’t think the ex guides get lubed very well because of the angle they’re on.
The valve stems themselves are quite small too for “5/16” ...... typically .307 ex, .308 int.
If the guides were small enough to get there, I’d run .0015 int, .0025 ex clearance.
Steel jacketed viton seals, and I’d leave the chimney spring off on the ex side.
Re: Hemi oil consumption [Re: fast68plymouth] #2571940
10/31/18 01:59 AM
10/31/18 01:59 AM
[quote=Lee446]
I was told years ago by several different 426 Hemi motor SO CA really good machine shops to run the intake to guide clearances tighter than normal, .0015 or less and on the exhaust to use .0017 to .0022 max on new guides and valves for street use, less on a drag race motor shruggy
Both Larry Shepard and Tom Hoover verified those number as good to use in one of the old Mopar drag race seminars I attended several years later shruggy
Re: Hemi oil consumption [Re: Cab_Burge] #2571977
10/31/18 07:55 AM
10/31/18 07:55 AM
Tennessee
Tennessee
Thanks, this is the info that I hoped for when I posted here.
Re: Hemi oil consumption [Re: Hemi ragtop] #2572396
10/31/18 10:49 PM
10/31/18 10:49 PM
Tennessee
Tennessee
So what do you think of the valve train geometery? Do I need roller rockers to ease the guide wear?
Re: Hemi oil consumption [Re: Hemi ragtop] #2572423
10/31/18 11:39 PM
10/31/18 11:39 PM
So. Burlington, Vt.
So. Burlington, Vt.
You don’t know if there is any guide wear.
Re: Hemi oil consumption [Re: Hemi ragtop] #2572434
10/31/18 11:53 PM
10/31/18 11:53 PM
I'm going to challenge you to check the lift at all 16 valves first on your motor before deciding to buy new rocker arms scope
The stock Mopar OEM rocker vary a bunch on the actual ratio at the valve tips shruggy scope
Let us know what you find on your set up grin whistling
When you look at the rocker arm to the valve stem angles on almost any American made Hemi motor it makes the SB LA Mopar valve train look good whistling grin
