SB Victor head exhaust flanges, anybody need a set? #2565822
10/18/18 10:54 AM
10/18/18 10:54 AM
CJD AUTOMOTIVE Offline OP
Getting ready to run a few sets of header flanges for the SB Victor head. Anybody interested in a set?
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: SB Victor head exhaust flanges, anybody need a set? [Re: CJD AUTOMOTIVE] #2565836
10/18/18 11:28 AM
10/18/18 11:28 AM
Earth
Rob C Offline
Rob C  Offline
Earth
That looks cool.
Can you make/do you have W5 flanges?
Is it possible to make a dual mounting flange?
Re: SB Victor head exhaust flanges, anybody need a set? [Re: Rob C] #2565840
10/18/18 11:32 AM
10/18/18 11:32 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Can you message me a price. Just kinda window shopping now but who
Knows. May be time to upgrade my 360-1’s
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: SB Victor head exhaust flanges, anybody need a set? [Re: Rob C] #2565965
10/18/18 03:05 PM
10/18/18 03:05 PM
Originally Posted By Rob C
That looks cool.
SDPexhaust already makes a CNC W5 flange, I think.
http://www.spdexhaust.com/MoparB.html#
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: SB Victor head exhaust flanges, anybody need a set? [Re: CJD AUTOMOTIVE] #2565968
10/18/18 03:10 PM
10/18/18 03:10 PM
If enough people wanted a cheaper flange, I can have them water jet cut. Same profile, but not chamfered and pretty like milling them.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: SB Victor head exhaust flanges, anybody need a set? [Re: CJD AUTOMOTIVE] #2566009
10/18/18 04:41 PM
10/18/18 04:41 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Shonfield also makes W5 header flanges
Re: SB Victor head exhaust flanges, anybody need a set? [Re: scottb] #2566042
10/18/18 05:35 PM
10/18/18 05:35 PM
PA.
"Little"John
"Little"John
PA.
Pretty does nothing for me. I kinda like cheap and fast. lol 😂
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: SB Victor head exhaust flanges, anybody need a set? [Re: CJD AUTOMOTIVE] #2570897
10/29/18 11:19 AM
10/29/18 11:19 AM
So I tweaked the design slightly. I got the print from Edelbrock for the head, but turns out it's the print for the gasket. This is the same print that the Stainless Headers flange is made from. While the bolt hole and port locations are all correct, it uses a round port on the D shaped port. I've scanned the port and enlarged it by the wall thickness of the tube material (.070). Now the stub can be formed to the shape with an almost perfect transition to round. The port area is slightly smaller than 1-7/8" ID tubing, and slightly larger than 1-3/4" ID tubing in 16 gauge. I'm having some 304 SS flanges water jet cut this week. Will post them when I get them.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: SB Victor head exhaust flanges, anybody need a set? [Re: CJD AUTOMOTIVE] #2570900
10/29/18 11:22 AM
10/29/18 11:22 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
That looks cool.
Its not listed on the site that they do.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: SB Victor head exhaust flanges, anybody need a set? [Re: CJD AUTOMOTIVE] #2571184
10/29/18 07:38 PM
10/29/18 07:38 PM
I'm calling these good for water jet. I can make more, but need a few sets to be worth while and all need to be the same, 3/8", 1/2", etc...
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: SB Victor head exhaust flanges, anybody need a set? [Re: CJD AUTOMOTIVE] #2571199
10/29/18 08:07 PM
10/29/18 08:07 PM
California
slowfab Offline
slowfab  Offline
California
I am in the market for a set in Stainless for a turbo setup.
Re: SB Victor head exhaust flanges, anybody need a set? [Re: slowfab] #2571217
10/29/18 08:27 PM
10/29/18 08:27 PM
The ones pictured are 1/2" 304 SS for a turbo application. I'm machining a set, so will sell these when done using them for mockup.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: SB Victor head exhaust flanges, anybody need a set? [Re: CJD AUTOMOTIVE] #2571774
10/30/18 08:46 PM
10/30/18 08:46 PM
So going to turn this into my header build!
The water jet left me a nice insert piece that is the correct port shape:
I decided to make a forming tool from it. I reduced the profile by about .050" to account for the tubing diameter, and rounded the edge where it will go into the tube. Sanded and polished the edge to keep it from grabbing, drilled a hole and added a handle:
I formed the tube with the tool, slid it into the flange, and formed it again:
Repeat 8 times...
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: SB Victor head exhaust flanges, anybody need a set? [Re: CJD AUTOMOTIVE] #2571775
10/30/18 08:47 PM
10/30/18 08:47 PM
Pretty happy with the transition:
Okay, lets lay out some headers!
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: SB Victor head exhaust flanges, anybody need a set? [Re: CJD AUTOMOTIVE] #2571786
10/30/18 09:04 PM
10/30/18 09:04 PM
PA.
"Little"John
"Little"John
PA.
Very nice work
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: SB Victor head exhaust flanges, anybody need a set? [Re: CJD AUTOMOTIVE] #2576396
11/09/18 03:33 PM
11/09/18 03:33 PM
Thanks.
I have played this out about 10 times now! Got to clear a 335" front tire at full lock, steering, A-arm, coil over, let me remove valve covers, access spark plugs,....and need it to come out between the firewall and tire to mate with the turbo, all with very long primaries... The "lego's" definitely earned there money.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: SB Victor head exhaust flanges, anybody need a set? [Re: CJD AUTOMOTIVE] #2576586
11/09/18 11:46 PM
11/09/18 11:46 PM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
CJD, tell us about that Stef's oil pan...those "legos" are pretty cool. Where do you get those. Very nice work.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: SB Victor head exhaust flanges, anybody need a set? [Re: mopardude318] #2580770
11/20/18 08:53 PM
11/20/18 08:53 PM
Sorry, just saw this. The kits are available from Summit, Jegs, Trick-tools, etc. Summit and a coupon is your friend on these!
The Stef's pan is a dry sump I had them built. The 3 scavenges are on the P-side. That fitting on the drivers, in the pic, is the turbo oil drain. I had Stef's build it because they were the only ones putting piston oilers in the pan. Got it back, and no oilers. Said they don't do that anymore. Very pissed. Put the BLP jets in the block instead.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: SB Victor head exhaust flanges, anybody need a set? [Re: CJD AUTOMOTIVE] #2581138
11/21/18 04:20 PM
11/21/18 04:20 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Very nice work!
Re: SB Victor head exhaust flanges, anybody need a set? [Re: Biginchmopar] #2581215
11/21/18 07:08 PM
11/21/18 07:08 PM
Originally Posted By Biginchmopar
Very nice work!
Thanks, and already changed the layout again! Couldn't fit the support bar for the coil overs with the previous setup (the piece of scrap in the pic showing location). So this is number 10 or something?!
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
