440-6 timing??
#257057
03/17/09 02:24 PM
03/17/09 02:24 PM
I know I am driving you guys crazy and I am trully sorry but I did not get a clear answer yesterday on setting my timing. Totally restored 1970 440-6 rebuilt by a pro with 175 miles on it. When I set the timing to 10 degrees BTDC the car tends to run labored and backfires once in a while. Yesterday I put a vacuum gauge on the intake and it read 14 and was at the bottom of the late ign. timing area so I moved the dist. until I got up to 18 and in the green normal area and the car ran perfect so I got out the timing light and low and behold I had moved the mark on the balancer 20 degees. It was now 10 degrees oppisite. What is wrong here? I id this with the vacuum advance hooked up, is that wrong? Is there anything wrong with setting an engine with a vacuum gauge and forget the timing light. If it starts easy, does not ping thigs should be fine or am I missing something.
Re: 440-6 timing??
#257061
03/17/09 04:03 PM
03/17/09 04:03 PM
Posts: 4,084 Indiana
W5Duster436
Indiana
I have my 440+6 locked at 22 initial w/no vacuum advance and 14 degrees of mechanical advance. I just put a cap on the vacuum advance module and put the hose over it to appear that it's hooked up. :-)
'70 Duster - SDSS 436 W5 4spd (Gone) '71 Dodge D100 '70 Dodge W100
Re: 440-6 timing??
[Re: RT_6_PakShaker]
#257062
03/17/09 04:26 PM
03/17/09 04:26 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I had similar problems last year tuning my fresh 440-6 pack, to make a long story short it ended being the outer ring on my harmonic balancer had spun almost 90* You may want to start over by doing the initial timing just to verify that your balancer is still zeroed.
same thing happend to a buddy's hemi. We tried to time it they only way it'd run was if you had 60* initial
Re: 440-6 timing??
#257063
03/17/09 04:32 PM
03/17/09 04:32 PM
RapidRobert
Since the eng is running well I'd pull & plug the dist vac line & see what you have now for initial for reference. As a general rule you want your total(without vac adv) on a BB to be ~36-38 degrees & enough initial to where it idles good(a wilder cam needs more initial) & the right slot length for both ends(initial & total) to be right and the right springs for no detonation(from initial to total) when you get on it and if it does not ping(from too much timing) then no damage is being done only that there may be power being left on the table if it can be further advanced(w no pinging)(within those timing guidelines).
Re: 440-6 timing??
[Re: ph23vo]
#257064
03/17/09 04:47 PM
03/17/09 04:47 PM
thats what I am thnking, was hoping to find someone to agree with me.
Re: 440-6 timing??
#257065
03/17/09 05:35 PM
03/17/09 05:35 PM
Mr.Yuck
Brookeville, Md
SHOOT RUN IT AT 40* IF IT WILL TAKE IT...LOL
Re: 440-6 timing??
[Re: Mr.Yuck]
#257066
03/17/09 05:38 PM
03/17/09 05:38 PM
RapidRobert
swingin/72, lighten up you are going to get him confused
Re: 440-6 timing??
[Re: RapidRobert]
#257067
03/17/09 08:01 PM
03/17/09 08:01 PM
Mr.Yuck
Brookeville, Md
hey man I'm funnin' and FWIW I had a 383 that loved about 41* total
