W5 vs new Edelbrock heads #2570009
10/26/18 11:31 PM
10/26/18 11:31 PM
Kentucky
71blackdemon Offline OP
Kentucky
I have a 422 cubic inch small block with W5 heads that made 700 horsepower at the flywheel I was told the new Edelbrock small block heads would make more horsepower just asking for your opinions my heads the W5 Flowed 330 @ 700 can I make more horse power with the Edelbrock Victor heads
Re: W5 vs new Edelbrock heads [Re: 71blackdemon] #2570104
10/27/18 06:54 AM
10/27/18 06:54 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
I would say yes.
Edit: i hope you are talking about Victor heads..
Re: W5 vs new Edelbrock heads [Re: 71blackdemon] #2570111
10/27/18 07:19 AM
10/27/18 07:19 AM
Easton, PA
68DART360 Offline
68DART360  Offline
Easton, PA
Are you talking about Performer RPM heads or Victor heads? Hughes Engines Shows their Big Mouth RPM's flowing 322@700. I had mine CNC ported by Modern Cylinder Head. Don't have my flow sheet in front of me but I think they were not that much somewhere in the 310-3320 range. I don't know anything about the Victor's if that's what you are looking at. I know my buddy runs the same cubic inches with the W5's and has run 9.70@136
Re: W5 vs new Edelbrock heads [Re: 71blackdemon] #2570306
10/27/18 06:36 PM
10/27/18 06:36 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
Shady Dells give flow rates for most of the various Mopar heads.
http://www.shadydellspeedshop.com/cylheads.htm
They put the W5 in the 320-330 area which is similar to the INDY 360-1. The Victor isn't listed by them on the website but my impression is that it is closer to the W7 which is in the 350-370 class. I bet if you called they would have an answer.
Re: W5 vs new Edelbrock heads [Re: gzig5] #2570312
10/27/18 07:10 PM
10/27/18 07:10 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Plan on getting new pistons for the new Victor heads.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: W5 vs new Edelbrock heads [Re: pittsburghracer] #2570481
10/28/18 04:15 AM
10/28/18 04:15 AM
Kentucky
Kentucky
Why do I have to get new Pistons
Re: W5 vs new Edelbrock heads [Re: 71blackdemon] #2570497
10/28/18 07:26 AM
10/28/18 07:26 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Different valveangle is the obvious answer,possibly location aswell.
Re: W5 vs new Edelbrock heads [Re: 71blackdemon] #2570503
10/28/18 09:04 AM
10/28/18 09:04 AM
Guitar Jones Offline
16* vs 18*
Re: W5 vs new Edelbrock heads [Re: 71blackdemon] #2570753
10/28/18 10:00 PM
10/28/18 10:00 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
Victor head is capable of well over 800 horsepower. WAY more thani a W5.
They are capable of flowing 380+ and have a good bit bigger valve than a W5.
Guy i posted about( local to me) made 737 horse at a national dyno competition with a set on a stock stroke 360. And made even more power at bigher rpm than the contest limited the guys to. And that was under 12 to 1 per the contest rules.
I used to have a stout 422 W5 motor than ran well into the 9’s at 3350 pounds. Victor is lot bigger and better head
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: W5 vs new Edelbrock heads [Re: B3422W5] #2570788
10/28/18 11:11 PM
10/28/18 11:11 PM
Kentucky
Kentucky
I would love to put a set on my 422 cubic-inch W5 motor but they're saying I need to change the piston everything I read says they was a direct bolt-on to a stock engine
Re: W5 vs new Edelbrock heads [Re: 71blackdemon] #2570860
10/29/18 05:15 AM
10/29/18 05:15 AM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
Wow. Didn't know the victor head was that good. Why isn't everybody running em?
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: W5 vs new Edelbrock heads [Re: mopardude318] #2570930
10/29/18 12:08 PM
10/29/18 12:08 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
In my opinion because they are expensive, take unique rocker gear and perhaps new pistons.
That being said they may be the best 59 degree head available when properly ported.
Re: W5 vs new Edelbrock heads [Re: mopardude318] #2571010
10/29/18 02:30 PM
10/29/18 02:30 PM
Washington
madscientist Offline
Washington
Just like 340cuda said. The Chrysler guys are too cheap to buy anything other than stock wrecking yard blocks and stock rockers.
It's silly. I never ever EVER once had a Chevy customer [censored] about buying rockers. Not one single time.
Every time I told a customer you need to find some W-2 heads for this stroker at the minimum I would hear the inevitable whining, crying, bitching, moaning and all the other crap. By the end of an hour of that [censored] I'd say piss on it, buy some edelbrocks and continue on leaving big power on the table so you don't have to buy rockers.
Same [censored] every day. For decades.
Re: W5 vs new Edelbrock heads [Re: 71blackdemon] #2571021
10/29/18 02:53 PM
10/29/18 02:53 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Frankly, the whole proposition is expensive enough that I wouldn’t expect pistons to be the deal breaker.
Of course, I doubt I’d bother putting them on a stock block either........ then building it with a good block gets really expensive real fast.
Re: W5 vs new Edelbrock heads [Re: 71blackdemon] #2571034
10/29/18 03:20 PM
10/29/18 03:20 PM
Earth
Rob C Offline
Rob C  Offline
Earth
71blackdemon;
Considering the level of the Victor head, building a street or race car with them in a stock block seems kind of silly. As is also NOT taking advantage of there abilities. Now that your at the cross roads of wanting to go faster with a better head, is finding out the limits of a stock block worth the expense when it breaks? After all the money is spent on a stock block, the price of a Ritter block starts to look pretty darn good.
IMO, start a new engine from scratch. You will be way ahead of the game in taking this route.
Beefier block with the new odd angled valve reliefs slugs for a fresh start, sounds like a home run to me. I know it is a lot of money. But if and when you break the stock block, what else goes south with it?
Re: W5 vs new Edelbrock heads [Re: 71blackdemon] #2571318
10/29/18 10:53 PM
10/29/18 10:53 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Maybe the fact that they took 4 years to get from the catalog into people’s hands. AND.... in that time our blocks went away. I sold off my W5 stuff and was ready to go all in, and NOTHING! Stumbled into a W8 top end and went that direction.
