Mystery Bolt #2570313
10/27/18 07:15 PM
10/27/18 07:15 PM
New Mexico
Scott440 Offline OP
Scott440  Offline OP
New Mexico
A while back, the engine builder fastened the valley tray with these unusual bolt heads (capscrews). They have a sunburst head -- like a kind of inverse torx head. I'm having trouble finding the right tool that removes them. Is there a name for these? Thanks in advance.
[img]https://lh3.googleusercontent.com/4mX7tk...2g=w825-h485-no[/img]
Re: Mystery Bolt [Re: Scott440] #2570316
10/27/18 07:22 PM
10/27/18 07:22 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Looks like a simple 12 point to me....
Re: Mystery Bolt [Re: Scott440] #2570321
10/27/18 07:28 PM
10/27/18 07:28 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yeah, the correct term is "12-point Flange Bolt" yours appears to be Grade 8.
Re: Mystery Bolt [Re: Scott440] #2570328
10/27/18 07:52 PM
10/27/18 07:52 PM
AndyF Offline
AndyF  Offline
A 12 point wrench or socket will remove them. Looks like you'll need a 5/16 wrench.
Re: Mystery Bolt [Re: Scott440] #2570334
10/27/18 08:09 PM
10/27/18 08:09 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Many header bolts are like that. The idea is lighter weight and more clearance.
Re: Mystery Bolt [Re: Scott440] #2570357
10/27/18 08:57 PM
10/27/18 08:57 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
They are 1/4-20 12 point bolts
Re: Mystery Bolt [Re: Scott440] #2570360
10/27/18 09:03 PM
10/27/18 09:03 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
!2 point socket. Useful for tight clearances, trans pans, intakes, headers, even head bolts.
Re: Mystery Bolt [Re: Sammy] #2570361
10/27/18 09:04 PM
10/27/18 09:04 PM
They may be 12 point 11/32 head size scope
The 12 point nuts on 1/4 inch studs I use for valve covers use that size shruggy
Re: Mystery Bolt [Re: Scott440] #2570366
10/27/18 09:13 PM
10/27/18 09:13 PM
Cincinnati, Ohio
Cincinnati, Ohio
Every bolt and nut on my brad hemis are 12 point. Actually there are no bolts on my hemis, all studs except for the 12 point rod bolts. Every bolt and nut are 12 points on my dragster chassis, some are titanium. Many racing/aircraft fasteners are cut down for clearance and mostly light weight.
Many are aircraft grade like some in this picture and are a one time use. I got a buddy who works at GE aircraft engines and gave me piles of trick fasteners.
Re: Mystery Bolt [Re: Cab_Burge] #2570372
10/27/18 09:36 PM
10/27/18 09:36 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
All Indy valley trays and intake tops use only 1/4-20 12 point bolts
Re: Mystery Bolt [Re: Sammy] #2570383
10/27/18 09:57 PM
10/27/18 09:57 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Not mine. lol. I make my stuff easy to work on so for applications like that hex head bolts work great.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Mystery Bolt [Re: Scott440] #2570387
10/27/18 10:02 PM
10/27/18 10:02 PM
New Mexico
Scott440 Offline OP
Scott440  Offline OP
New Mexico
I have that socket..I never used it before so I assumed this was something exotic. I can see how these would be ideal for headers. Thanks.
