Re: 1972 b body mirror plate
[Re: RJS]
#2570419
10/27/18 11:53 PM
10/27/18 11:53 PM
Posts: 356 NE
moparpoolman
NE
Are you referring to these? Ron Yes, I am referring to those mounting plates, the question is do they get screwed or bolted to the door first to hold the plate in place so that if the mirror screws were taken out the plate won't fall into the door? If yes what hardware is used to do so? Thanks
[Re: moparpoolman]
#2570516
10/28/18 10:23 AM
10/28/18 10:23 AM
Posts: 6,224 JERSEY
RJS
JERSEY
Are you referring to these? Ron Yes, I am referring to those mounting plates, the question is do they get screwed or bolted to the door first to hold the plate in place so that if the mirror screws were taken out the plate won't fall into the door? If yes what hardware is used to do so? Thanks Going by memory I think either riveted or a plastic push in plug hold them in place. Ron
