Correct brakes and driveshaft 1970 GTX
#2570250
10/27/18 03:55 PM
10/27/18 03:55 PM
Posts: 382 Delta BC, Canada
Baller
Delta BC, Canada
Hey all. I purchased a '70 GTX a few years ago. After running the numbers on the Dana 60, it tells that it came from a '69 charger with 3.54 gears. My GTX is a A32 axle package car. The driveshaft also has '69 charger written on it with paint like you'd see from a junkyard. The car is not running at the time. So, I wonder if the drums are correct (they are 11" inside diameter) and if the driveshaft will work. I have put it in the local CL for trade, but there are not too many Mopars around here. [img][IMG] http://i68.tinypic.com/adkva8.jpg[/img][/img]
1970 GTX, work in progress...
Re: Correct brakes and driveshaft 1970 GTX
[Re: 6bblgt]
#2570267
10/27/18 04:36 PM
10/27/18 04:36 PM
Baller
Delta BC, Canada
Thanks. I'll get those numbers and post shortly. I don't know why the image doesn't show...
[Re: Baller]
#2570270
10/27/18 04:48 PM
10/27/18 04:48 PM
Baller
Delta BC, Canada
Ok, now for the numbers:
5 29 C1 6 56 B 602957 2.
Mods, can someone move this to the restoration section please?
[Re: Baller]
#2570343
10/27/18 08:29 PM
10/27/18 08:29 PM
Posts: 5,949 ohio
ruderunner
ohio
If A32 included front disc then the Dana would have 10" brakes.
Angry white pureblood male
