Re: BB roller cam recommendations
[Re: rick4106]
#2570082
10/27/18 02:02 AM
10/27/18 02:02 AM
Posts: 43,259 Bend,OR USA
Cab_Burge
[Re: BradH]
#2570152
10/27/18 11:26 AM
10/27/18 11:26 AM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Max Wedge or standard ports?
What's the peak RPM the engine sees on the track?
What's the converter stall speed? And, what rockers arms...... and what ratio?
[Re: rick4106]
#2570236
10/27/18 03:21 PM
10/27/18 03:21 PM
Posts: 84 La.USA
rick4106
La.USA
Hs 1.5 harland sharps and max wedge port. Only made couple of passes with .650 lift 290@.050 old comp solid. 6.35@108.9.97@131 in 1/4.
[Re: rick4106]
#2570257
10/27/18 04:14 PM
10/27/18 04:14 PM
Posts: 31,060 Oregon
AndyF
290@050 is way too big for your combination. That cam is killing the torque and slowing you down. Sometimes bigger is not better. I think the 292 street roller would work or you could go one size bigger with a 260@050 intake lobe.
Looks like you're crossing the stripe at roughly 7000 rpm with those gears. With a better cam you should be going faster so you most likely will need to drop the rear gear down to 4.56 or even a 4.30.
A 440 with ported EZ heads and 12:1 compression should make 650 to 700 hp if you have a good intake manifold. That would put you into the low 9's at 140+ mph if the chassis is decent. So I'd gear the car to go 7000 rpm at 145 and then pick a cam that puts peak power around 6800 rpm. 260 @ 050 should be in the ballpark. Probably need 5000+ stall on the converter but I'm no expert there.
[Re: rick4106]
#2570263
10/27/18 04:18 PM
10/27/18 04:18 PM
Thumperdart
State of confusion
Hs 1.5 harland sharps and max wedge port. Only made couple of passes with .650 lift 290@.050 old comp solid. 6.35@108.9.97@131 in 1/4. I run an Isky solid roller in my 470 low deck with home ported rpm's and .680-.660 and 276-281 @ .050 and it has many street miles and a few passes with a 6.15 @ 112+ so far on crap QTP's.............
[Re: rick4106]
#2570268
10/27/18 04:41 PM
10/27/18 04:41 PM
Posts: 570 UK
rb446
UK
My mate's 440 Dart made 600hp with 320cfm Eddy's, old .590 sft purple@12.5:1, 1050 Dom etc. Working on your no's, 2811lbs/9.97@131 your only making 560hp, something wrong, you should be up in the 640+hp range with those speccs, I don't think its the .290@.050 cam personally....I made 530hp with that cam@9.8:1 an 850DP and 260cfm 906's back in the day.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: rick4106]
#2570333
10/27/18 08:08 PM
10/27/18 08:08 PM
BradH
Hs 1.5 harland sharps and max wedge port. Only made couple of passes with .650 lift 290@.050 old comp solid. 6.35@108.9.97@131 in 1/4. My perspective is a bit simplistic, but MW ports, that much duration, and only 450-ish cubes is killing your torque. Add my vote to those who are suggesting you should try something 20 to 30 degrees smaller. If you're going to switch to a roller, you might even be able to pick up some lift, too.
[Re: rick4106]
#2570406
10/27/18 11:11 PM
10/27/18 11:11 PM
fast68plymouth
So. Burlington, Vt.
While I’ve never been a big fan of the 650/290 solid, it did have its place. But imo that place isn’t MW sized Indy heads on a 440.
That being said, I think the xr292r is too much of a step in the other direction. Sure, it’ll work okay......... but I don’t feel that cam in that combo is going to make the best use of a roller set up in a 12:1 bracket car with decent heads.
[Re: AndyF]
#2570638
10/28/18 04:15 PM
10/28/18 04:15 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Looks like it's laying down after the first 1/8...mph is down alot compared to the 1/8 mph.
What does it 60ft.? Fuel system?
Brian Hafliger
