How can one ID a Keith Black Trans Am engine? #2569821
10/26/18 05:04 PM
10/26/18 05:04 PM
SC
V194 Offline OP
V194  Offline OP
SC
Is there a stamping or casting on them?
Re: How can one ID a Keith Black Trans Am engine? [Re: V194] #2569822
10/26/18 05:08 PM
10/26/18 05:08 PM
AndyF Online content
AndyF  Online Content
If it was paid for but never delivered then it is a genuine Keith Black engine.
Re: How can one ID a Keith Black Trans Am engine? [Re: V194] #2570018
10/26/18 11:46 PM
10/26/18 11:46 PM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
Can't exactly say that now Andy
eBay-cdwmotorsports
Re: How can one ID a Keith Black Trans Am engine? [Re: V194] #2570044
10/27/18 12:55 AM
10/27/18 12:55 AM
P
Porter67 Offline
Porter67  Offline
P
Its not that hard, is it still complete?
Re: How can one ID a Keith Black Trans Am engine? [Re: Porter67] #2570053
10/27/18 01:15 AM
10/27/18 01:15 AM
SC
V194 Offline OP
V194  Offline OP
SC
Well yes I guess. Not sure if it has been apart or not. I was told it was original. Trying to verify.
Where they based on 318's or 340TA or standard 340 blocks? What type of heads? Numbers? Any stamping s or castings that I need to look for?
Re: How can one ID a Keith Black Trans Am engine? [Re: V194] #2570055
10/27/18 01:17 AM
10/27/18 01:17 AM
P
Porter67 Offline
Porter67  Offline
P
These may help.
Look at the head pic of the odd outer head bolt and the valve retainers, ive seen these in person before.
Re: How can one ID a Keith Black Trans Am engine? [Re: V194] #2570059
10/27/18 01:19 AM
10/27/18 01:19 AM
P
Porter67 Offline
Porter67  Offline
P
more
Notice the W2 style rockers, stands, ect but in 71.
Re: How can one ID a Keith Black Trans Am engine? [Re: Porter67] #2570062
10/27/18 01:23 AM
10/27/18 01:23 AM
SC
V194 Offline OP
V194  Offline OP
SC
more
I see but obviously not W2 as it was not released until 74 or 76. Nor does it have the W@ oval ports. 273 adjustable arms or just aftermarket?
Re: How can one ID a Keith Black Trans Am engine? [Re: V194] #2570064
10/27/18 01:24 AM
10/27/18 01:24 AM
P
Porter67 Offline
Porter67  Offline
P
Block will have TA on it, if by chance its a later KB build and says 318 look for the big X on the front and rear cast in.
Re: How can one ID a Keith Black Trans Am engine? [Re: V194] #2570065
10/27/18 01:26 AM
10/27/18 01:26 AM
P
Porter67 Offline
Porter67  Offline
P
Look at the rockers, they are offset for the moved over push rod.
The rockers were also factory T/A 340 units.
See how the intake rocker looks like a BB rocker and the ex looks like the oem.
Re: How can one ID a Keith Black Trans Am engine? [Re: Porter67] #2570066
10/27/18 01:27 AM
10/27/18 01:27 AM
SC
V194 Offline OP
V194  Offline OP
SC
Yes it says TA. Heads are different however and might have been worked or replaced at some time? Anything is possible I guess.
Re: How can one ID a Keith Black Trans Am engine? [Re: V194] #2570067
10/27/18 01:29 AM
10/27/18 01:29 AM
P
Porter67 Offline
Porter67  Offline
P
See the offset rocker for the moved over pushrod location.
Factory Mopar.
Re: How can one ID a Keith Black Trans Am engine? [Re: V194] #2570068
10/27/18 01:31 AM
10/27/18 01:31 AM
P
Porter67 Offline
Porter67  Offline
P
Its not uncommon to have different heads. If its not apart for inspection, low ball them, ive paid 1k for two different ones unopened.
One was perfect one had blue main webs going 1.5 inch up and was junked.
Re: How can one ID a Keith Black Trans Am engine? [Re: V194] #2570069
10/27/18 01:34 AM
10/27/18 01:34 AM
P
Porter67 Offline
Porter67  Offline
P
Also if its really a 305 T/A motor and will turn over you can use a screwdriver to tell the short stroke if you test a 3.31 motor before you go look at it.
It could as well be a std street t/a motor which might be better for you depending on your needs.
Re: How can one ID a Keith Black Trans Am engine? [Re: Porter67] #2570074
10/27/18 01:42 AM
10/27/18 01:42 AM
SC
V194 Offline OP
V194  Offline OP
SC
Good idea. Im going to run a camera into as well it just to look around to see if anything jumps out. I read somewhere that these little engines had super high compression like 14 to 1? Did i read that correctly?
Re: How can one ID a Keith Black Trans Am engine? [Re: V194] #2570084
10/27/18 02:10 AM
10/27/18 02:10 AM
P
Porter67 Offline
Porter67  Offline
P
Id not doubt it, Ive seen a couple that even had more of the valve notches cut out way past the forging and it wasnt pretty but functional.
Re: How can one ID a Keith Black Trans Am engine? [Re: V194] #2570095
10/27/18 04:02 AM
10/27/18 04:02 AM
When Ma Mopar pulled the plug on the 1971 Trans Am program John Dianna went to KB and got all of the existing inventory on heads and blocks left shruggy
He helped develop the original W2 heads from the OEM stock 916 TA castings, Ed Hamburger was his counterpart on the east coast on the SB drag race program.
A friend of mine ended up with the last set of Johns TA heads that had been welded up and ported to the W2 heads along with a tunnel ram and 660 center squirters carbs that John Bauman had done for John Deanna shruggy
Not sure if he still has them or not work
