Mopar Hood Scoop Question #2569332
10/25/18 01:00 PM
10/25/18 01:00 PM
Cannelton, IN
mike337 Offline OP
mike337  Offline OP
Cannelton, IN
I am starting a restomod on a 79 Ramcharger, and since there are no aftermarket hoods that can bolt on without some serious modifications, I thought that maybe I should add some hood scoops from Mopars of the past.
I found that RPS has repops of the scoops I am interested in, but has at least 4 different part numbers for different applications.
71-72 Demon, 67-76 Dart, 69-70 Superbee, and 69-70 Coronet.
Did these cars all have the same scoops, or where there different lengths for different hoods/cars?
Can anyone provide some measurements from an existing car(s)?
Re: Mopar Hood Scoop Question [Re: mike337] #2569568
10/25/18 11:12 PM
10/25/18 11:12 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Check truck hoods up to 1993
Re: Mopar Hood Scoop Question [Re: mike337] #2569626
10/26/18 03:26 AM
10/26/18 03:26 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
The scoops you show were used only on the 69 and 70 Coronet & SuperBee and the 70 Dart Swinger 340 cars and the 71 Demon's as far as I remember. The only Dart to use them dual scoops was the 70 and the only Demon was the 71. I dont remember them on the 72 Demon as it use the single scoop that was the one that looked like a dual snorkel scoop. Oh and I think the 71 Duster Twister also used them which was only a 318 car. The 340 Duster never used the dual scoops like that. Ron
Re: Mopar Hood Scoop Question [Re: mike337] #2569647
10/26/18 09:08 AM
10/26/18 09:08 AM
SE Indiana
K
kowalski440 Offline
kowalski440  Offline
K
SE Indiana
You're right in that they were used by the factory in those years you quoted, but I took the catalog listing to mean they could be used on any of the years and they would fit fine.
I think a '67 SS RO/WO scoop would look good on those trucks, also, myself.
Re: Mopar Hood Scoop Question [Re: kowalski440] #2569688
10/26/18 11:31 AM
10/26/18 11:31 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Many years ago there was a Ramcharger running around here with a set of the twin scoops on it. Looked ok.
Re: Mopar Hood Scoop Question [Re: mike337] #2570023
10/27/18 12:00 AM
10/27/18 12:00 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Does a 79 still have the birdbath hood? (I just can't remember any more.)
I think those scoops would look pretty goofy on the birdbath hood. Gene
Re: Mopar Hood Scoop Question [Re: poorboy] #2572923
11/02/18 09:22 AM
11/02/18 09:22 AM
Cannelton, IN
mike337 Offline OP
mike337  Offline OP
Cannelton, IN
My truck just has the flat hood with the raised center. No bird bath.
