2011 RAM 5.7 hesitation from stop to full throttle
#2568943
10/24/18 03:44 PM
10/24/18 03:44 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
I sure that this has been addressed, but I don't get to this part of the forums very often, so please bare with me. I have a low mileage 2011 4 X 4 Ram with a 5.7. It runs great. Good gas mileage, good performance. Only issue that I have and have had since I bought it new, is the throttle response from a dead idle to full throttle. Very bad lag or dead spot. If I load the converter a bit it will take off pretty good. Any suggestions???
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: 2011 RAM 5.7 hesitation from stop to full throttle
[Re: Rhinodart]
#2569068
10/24/18 07:42 PM
10/24/18 07:42 PM
68LAR
South Park, Pa.
So this is the only option????? There isn't any adjustment that I can do without buying something??? That sux...
[Re: sportfury70]
#2569719
10/26/18 12:50 PM
10/26/18 12:50 PM
68LAR
South Park, Pa.
My 2011 doesn't have a delay in gas pedal. Now my 2014 T&C on the other hand- you dont want to pull out in front of somebody in that thing. Terrible lag. I can give the pedal a quick "blip" & the engine rpms wont even raise. If I drive mine normally, as I do 99.9% of the time, you would never think that there was anything wrong. That .1% when I'm at a stop light and punch it from an idle is when there is a dead spot. If I load the converter a bit ( a few rpm above idle), the engine responds normally. I've lived with it for the past 7 years. Maybe I'll continue to just live with it??? I really don't want to spend money on something that I will use one time and not need anymore.. Thanks for all the replies..
