Torsion bars and allignment #256886
03/17/09 11:28 AM
03/17/09 11:28 AM
minnesota
Kirby Offline OP
Kirby  Offline OP
minnesota
I just switched the t-bars, and had the car aligned. I'd like to crank them up some more. How far, if at all, can I turn them without affecting the alignment?
Re: Torsion bars and allignment [Re: Kirby] #256887
03/17/09 11:34 AM
03/17/09 11:34 AM
La Grange, Ky
70rrclone Offline
70rrclone  Offline
La Grange, Ky
if you move them at all it will affect the alignment.
if you must move them have it re aligned
shane
Re: Torsion bars and allignment [Re: 70rrclone] #256888
03/17/09 11:49 AM
03/17/09 11:49 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You can raise them an inch or so and not affect the alignment enough to notice.
Re: Torsion bars and allignment [Re: stumpy] #256889
03/17/09 12:13 PM
03/17/09 12:13 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
My guess is that even if YOU won't notice...your tires will. Have it re-aligned.
Re: Torsion bars and allignment [Re: burdar] #256890
03/17/09 02:31 PM
03/17/09 02:31 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I've been doing alignments for 10 yrs now and can assure you that the above statment is true.
When I do alignments on these babies I always make sure the customer/owner can hang around long enough to get the ride hight set before I adjust anything else.
Re: Torsion bars and allignment [Re: Kirby] #256891
03/17/09 05:21 PM
03/17/09 05:21 PM
Odessa, Tx.
cudarex Offline
cudarex  Offline
Odessa, Tx.
Raising car will give it positive camber(top of tire will toe out). Not good for cornering.
Re: Torsion bars and allignment [Re: cudarex] #256892
03/18/09 10:26 AM
03/18/09 10:26 AM
minnesota
Kirby Offline OP
Kirby  Offline OP
minnesota
Thanks guys- guess I wasted some bucks on the first alignment. But I had to switch the T-bars- the front end was so squatted that I could have plowed my driveway with it-
