Page 1 of 3 1 2 3
69 charger disk brake questions #2567719
10/22/18 10:47 AM
10/22/18 10:47 AM
Finally a HUSKER again
Moparnut426 Offline OP
Got Dads 69 charger back, well he put some conversion kit on the front from a newer cordoba, or something cause the calipers are not where near correct, and the brake hoses make a nasty 180 degree bend and hit the front shocks.
does anyone know from a casting number if I have the correct spindles to put the correct 69 front brakes on it?
Re: 69 charger disk brake questions [Re: Moparnut426] #2567720
10/22/18 10:48 AM
10/22/18 10:48 AM
is 69-70 C body stuff the same?
Re: 69 charger disk brake questions [Re: Moparnut426] #2567763
10/22/18 12:04 PM
10/22/18 12:04 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Post some pictures of the spindles, calipers, that you have.
Factory 66-69 B body disc brakes are BENDIX 4 piston calipers.
NO, C body brakes are NOT the same.
69, 70, C body would be Kelsey Hayes single piston disc brakes.
Totally different manufactures and designs.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: 69 charger disk brake questions [Re: Moparnut426] #2567802
10/22/18 01:27 PM
10/22/18 01:27 PM
AndyF Offline
AndyF  Offline
Post a picture if you can. The late model brakes can be made to work but you'll need the correct caliper and hose combination. Doctor Diff can set you up with what you need if you don't want to do the leg work yourself.
Typically the best setup is to have the calipers rear hung then use late model FMJ calipers which were designed to be rear hung and then use a custom hose that has the correct ends and the correct length.
Re: 69 charger disk brake questions [Re: Moparnut426] #2567896
10/22/18 05:00 PM
10/22/18 05:00 PM
raleigh, NC
mcmopar1 Offline
mcmopar1  Offline
raleigh, NC
Andy F, are you making the ported water neck extension? Sorry to pirate the post, but I can’t get a response from you or your dealers.
Phil
Re: 69 charger disk brake questions [Re: Moparnut426] #2567905
10/22/18 05:14 PM
10/22/18 05:14 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
69 Imp also used the 4 piston calipers.Ihave a set from the 69 I scraped.Rocky
Chrysler Firepower
Re: 69 charger disk brake questions [Re: therocks] #2567983
10/22/18 08:07 PM
10/22/18 08:07 PM
hemi71x Offline
hemi71x  Offline
Yes, that's true.
The Imperial carried over the 4 piston caliper brakes to the 1969 model year.
But The Imperial brakes are BUDD disc brakes.
Still totally different from the B body BENDIX brakes.
Don't think the Imperial line of cars, was ever designated as a "C" body, anyway.
Re: 69 charger disk brake questions [Re: Moparnut426] #2568140
10/23/18 12:33 AM
10/23/18 12:33 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Calipers should be in the front of the spindle..if mounted in the rear, the hose will be bent..
Re: 69 charger disk brake questions [Re: AARCONV] #2568194
10/23/18 03:09 AM
10/23/18 03:09 AM
AndyF Offline
AndyF  Offline
Calipers need to be rear hung on the OP car to clear the anti-sway bar. The FMJ calipers are designed to be rear hung so they'll work just fine.
I covered all of this in my B body book.
Re: 69 charger disk brake questions [Re: Moparnut426] #2568243
10/23/18 10:28 AM
10/23/18 10:28 AM
We would like to put the correct 4 piston stuff on the car, if anyone has the kit, spindles, and brackets, i would be interested. ill buy new calipers.
Re: 69 charger disk brake questions [Re: Moparnut426] #2568256
10/23/18 10:45 AM
10/23/18 10:45 AM
I cant load my pictures off my phone cause they are in the wrong format. I will retake them and load them.
Re: 69 charger disk brake questions [Re: Moparnut426] #2568339
10/23/18 01:50 PM
10/23/18 01:50 PM
AndyF Offline
AndyF  Offline
The correct Bendix stuff is super hard to find. Ram Man is making a one piece rotor to replace the original two piece and Hoffman has reproduced a bracket or two. I'm not aware of any source for the calipers though. Wheel bearings wouldn't be an issue but I'm not sure about the inner seal. I think Inline Tube makes the cross over brake line and I'm sure you can buy the correct hoses. Not sure about the pads.
If you're serious about using the original Bendex setup then you should start a thread in the Restoration area. Oh, and check the balance in your savings account too!
Re: 69 charger disk brake questions [Re: AndyF] #2568464
10/23/18 05:35 PM
10/23/18 05:35 PM
hemi71x Offline
hemi71x  Offline
Getting parts for the Bendix disc brake systems isn't that difficult anymore in this day and age.
Just gotta know where to look to purchase the parts.
Piston rebuild kits, individual pistons, are available from ebay, and Amazon vendors.
Rock auto too.
As far as complete calipers, again check Rock Auto, and any parts store that carries the Centric line of auto parts.
You can rebuild your own existing calipers, or send them out to the professional vendors that advertise, doing that type of work.
As far as rotors, there a couple of vendors that sell a reproduction one piece rotor, and another sells a original two piece rotor that you reuse your existing hub that you remove from the old and reinstall onto the new.
Repop caliper hard lines are available from the companies that sell fuel, and brake lines.
Repop caliper hose brackets are available.
Calipers bolt directly to the spindle, so no bracketry is neeeded for that.
If the OP needs original 66-69 Bendix disc brake spindles they come up for sale from time to time on the internet web sites, or placing your own wanted ad.
Buy yes, some of this stuff is expensive, $$$$$$$$$ dollar wise, depending on which way that you want to go, but all is available.
Re: 69 charger disk brake questions [Re: Moparnut426] #2568487
10/23/18 06:06 PM
10/23/18 06:06 PM
NAPA on line sells a rebuilt caliper. I think after talking with a few companies today im going to do a A body swap kit...
Re: 69 charger disk brake questions [Re: Moparnut426] #2568492
10/23/18 06:16 PM
10/23/18 06:16 PM
hemi71x Offline
hemi71x  Offline
Well, what type of brakes are on the car right now?
You ever want to know, figure that out, anymore?
Re: 69 charger disk brake questions [Re: Moparnut426] #2568498
10/23/18 06:25 PM
10/23/18 06:25 PM
VA
dragon slayer Offline
VA
So who makes a repopped single piece rotor for 66-69 Bendix? I have only see the rotor that requires and original hub to mate too it.
Re: 69 charger disk brake questions [Re: dragon slayer] #2568502
10/23/18 06:37 PM
10/23/18 06:37 PM
hemi71x Offline
hemi71x  Offline
There is this wonderful thing on the internet, called GOOGLE.
Do your own search, and homework.
Ever think of ebay, too?
Re: 69 charger disk brake questions [Re: hemi71x] #2568847
10/24/18 01:21 PM
10/24/18 01:21 PM
Its harvest time so I have been in the field. I snapped a couple JPEG potos last night quick when I finished up the corn.
Hope these are good enough.
Re: 69 charger disk brake questions [Re: Moparnut426] #2568849
10/24/18 01:22 PM
10/24/18 01:22 PM
sorry guys Im not the greatest with pics hope these help
Re: 69 charger disk brake questions [Re: Moparnut426] #2568854
10/24/18 01:26 PM
10/24/18 01:26 PM
AndyF Offline
AndyF  Offline
Looks like you already have the late model brakes on there so no point in doing an A body swap. You just need to change the calipers so the hose comes out the bottom instead of the top. Whoever did that swap used the wrong calipers for that application. You need the late model FMJ calipers and then new hoses. I think I already told you this in a previous post.
Page 1 of 3 1 2 3
