Page 3 of 4 1 2 3 4
Re: Nodular 8.75 case , how much stronger [Re: B3422W5] #2567823
10/22/18 02:11 PM
10/22/18 02:11 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Mine broke just as my car broke into the 10s. I was lucky and caught it as it got noisey but it had a broken tooth laying in the bottom of the housing when I did. Granted it was an old gear set with lots of miles and passes but I need reliability so I immediately started down the Dana Path, and it has been working great.
68 Barracuda Formula S 340
Re: Nodular 8.75 case , how much stronger [Re: StealthWedge67] #2567860
10/22/18 03:40 PM
10/22/18 03:40 PM
an8sec70cuda Offline
Originally Posted By StealthWedge67
For all those that call the modifications “band-aids”; the 9” units that most run are not stock Ford units, they’re full of aftermarket stuff also. For that matter, most Dana’s in this conversations are likely S60’s outfitted with Spools, aluminum covers, and aftermarket axles.
But once you've done those modifications to a Dana or a 9", you have a nearly bulletproof rearend.
Do whatever you want to an 8.75 and you're gonna still kill ring and pinions.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Nodular 8.75 case , how much stronger [Re: B3422W5] #2567965
10/22/18 07:54 PM
10/22/18 07:54 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I ran...
742 case
All new bearings w/ new Richmond 4.10s
MW steel caps for both bearings
Fresh & tight clutch-type Sure-Grip
Moser axles
Small brace on E-body diff housing
Seemed to be doing fine w/ mid-1.4 60s foot-braking at 3700++ #s (mid 10s).
Even so, there's a Strange S-60 w/ an S-Track diff under the car now for peace of mind.
The 8.75's 3rd member is in somebody's no-traction street car. The old housing is laying on the floor of my garage getting dusty and will probably end up going to the local metal recycler.
Re: Nodular 8.75 case , how much stronger [Re: BradH] #2567977
10/22/18 08:05 PM
10/22/18 08:05 PM
Tucson AZ,
MadMopars Offline
MadMopars  Offline
Tucson AZ,
Just let me know how much for bearing ends when you go to scrap it. I'll put them to good use when I narrow another Dana. sawzall up
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: Nodular 8.75 case , how much stronger [Re: B3422W5] #2568045
10/22/18 10:15 PM
10/22/18 10:15 PM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
Don, talk to Andre (68shifter) on here. He built my S60 put ladder bar brackets on and powder coated it for a great price. I just took him my old housing and he took care of the rest.
Re: Nodular 8.75 case , how much stronger [Re: J_BODY] #2568084
10/22/18 11:15 PM
10/22/18 11:15 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Originally Posted By J_BODY
Originally Posted By an8sec70cuda
Originally Posted By Thumperdart
Been running the Dr Diff unit for 2+ years and it is awesome imo and a bit heavier but beefier with forged caps and stout adjusters.........of course my stock unit lasted 16+ years........... boogie drive
Come on Dom, we all know you go to the track for a couple passes like once every 2 years. laugh2
Beating on it on the street will never duplicate the traction/stress it will see at the track. Lots of weak parts can live a long life w/ no traction.
Thank you!
but Jay I know for a fact Thumper has put twice as many passes on his car this year Then you did.. I think you're just jealous because his 727 trans. Actually stays together for an entire pass.. popcorn
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Nodular 8.75 case , how much stronger [Re: B3422W5] #2568106
10/22/18 11:40 PM
10/22/18 11:40 PM
MI
68shifter Offline
68shifter  Offline
MI
I recently put a 9” in my Duster. Fab housing I built notched for shocks, thru bolt 3.25” case and axles and what not from Cass. I probably have 16/1700 in it including the $75 disc brake kit from Summits clearance shelf.
Re: Nodular 8.75 case , how much stronger [Re: WHITEDART] #2568155
10/23/18 01:02 AM
10/23/18 01:02 AM
aZLiViN
J_BODY Online rolleyes
J_BODY  Online Rolleyes
aZLiViN
Thank you!
Other than the pump gear breaking at MaTS.... I didn’t miss a round of racing that year due to the many issues I had! Who the L breaks a pump gear?!?!
....and I don’t think he has 8 passes on it smile
Keep piling it on brother... I’m trying to care about it again!!
....and now that the 727 from L is healthy, I pulled it for a 904 :j
Re: Nodular 8.75 case , how much stronger [Re: WHITEDART] #2568325
10/23/18 01:24 PM
10/23/18 01:24 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Thank you!
And hundreds of street romps testing carbs........ My stuff lives for many years and will still wax his "race car"........... beer
Re: Nodular 8.75 case , how much stronger [Re: 68shifter] #2568353
10/23/18 02:03 PM
10/23/18 02:03 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Stating the obvious, those needed pictured notches are brutally counterproductive to original point of adding a back brace.eek twocents
Other then that, it is pretty. up
Re: Nodular 8.75 case , how much stronger [Re: Thumperdart] #2568557
10/23/18 08:48 PM
10/23/18 08:48 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
[/quote]
Thank you! [/quote] but Jay I know for a fact Thumper has put twice as many passes on his car this year Then you did.. I think you're just jealous because his 727 trans. Actually stays together for an entire pass.. popcorn [/quote]
And hundreds of street romps testing carbs........ My stuff lives for many years and will still wax his "race car"........... beer [/quote] sounds like a magical match race in the making well I can no longer pick on Jay he might let the air out of my tire when we pit next to each other smoke
Re: Nodular 8.75 case , how much stronger [Re: B3422W5] #2568687
10/24/18 01:02 AM
10/24/18 01:02 AM
aZLiViN
aZLiViN
My “race car” has current AZ tags.... is this an invitation to Mexico???
Re: Nodular 8.75 case , how much stronger [Re: J_BODY] #2568699
10/24/18 01:36 AM
10/24/18 01:36 AM
Dominic knows where Bullhead city is work grin stirthepot devil
I want to watch up
Re: Nodular 8.75 case , how much stronger [Re: Cab_Burge] #2568707
10/24/18 02:02 AM
10/24/18 02:02 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I want to watch up
. So let's get this straight Jay wants to race in Mexico realcrazy and thumper wants to race on the street. So he don't break the 8 and 3/4. Sounds like the brawl in Barona.. sorry j but my money's on thump
Re: Nodular 8.75 case , how much stronger [Re: B3422W5] #2568714
10/24/18 02:55 AM
10/24/18 02:55 AM
aZLiViN
aZLiViN
I wouldn’t bet on my azz in those settings either! laugh2 sure be fun to giver a whirl though...
Re: Nodular 8.75 case , how much stronger [Re: J_BODY] #2568858
10/24/18 01:31 PM
10/24/18 01:31 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
We can race here in Hesperia, plenty of roads brother......... biggrin drumhit If I had a truck n trailer I'd go to Kingman first to take out their fastest guy(Nova small block on spray goes 10.20's)then meet up with yall.........
Re: Nodular 8.75 case , how much stronger [Re: Thumperdart] #2568878
10/24/18 01:59 PM
10/24/18 01:59 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
10.20s with spray is their fastest?!
72 Plymouth Roadrunner 11.08@123.25
Re: Nodular 8.75 case , how much stronger [Re: B3422W5] #2568879
10/24/18 01:59 PM
10/24/18 01:59 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
In these parts there are many very fast street cars,,,,,several low 8 second cars at that! So I'm not that fast...........
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Nodular 8.75 case , how much stronger [Re: Roughbird72] #2568892
10/24/18 02:28 PM
10/24/18 02:28 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Apparently............lol
Re: Nodular 8.75 case , how much stronger [Re: Thumperdart] #2568908
10/24/18 02:53 PM
10/24/18 02:53 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
In the spirit of how this thread started I will bet on the Dana and the small block
"Just a Bracket car dressed up like a streetcar"
Page 3 of 4 1 2 3 4
