Re: 69 charger disk brake questions
[Re: Moparnut426]
#2567763
10/22/18 12:04 PM
10/22/18 12:04 PM
Posts: 5,366 Rancho Cordova, California (Sa...
hemi71x
Post some pictures of the spindles, calipers, that you have. Factory 66-69 B body disc brakes are BENDIX 4 piston calipers. NO, C body brakes are NOT the same. 69, 70, C body would be Kelsey Hayes single piston disc brakes. Totally different manufactures and designs.
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: Moparnut426]
#2567905
10/22/18 05:14 PM
10/22/18 05:14 PM
Posts: 21,086 Niles , Ohio
therocks
Niles , Ohio
69 Imp also used the 4 piston calipers.Ihave a set from the 69 I scraped.Rocky
Chrysler Firepower
[Re: therocks]
#2567983
10/22/18 08:07 PM
10/22/18 08:07 PM
hemi71x
69 Imp also used the 4 piston calipers.Ihave a set from the 69 I scraped.Rocky Yes, that's true. The Imperial carried over the 4 piston caliper brakes to the 1969 model year. But The Imperial brakes are BUDD disc brakes. Still totally different from the B body BENDIX brakes. Don't think the Imperial line of cars, was ever designated as a "C" body, anyway.
[Re: AARCONV]
#2568194
10/23/18 03:09 AM
10/23/18 03:09 AM
Posts: 31,088 Oregon
AndyF
Calipers should be in the front of the spindle..if mounted in the rear, the hose will be bent.. Calipers need to be rear hung on the OP car to clear the anti-sway bar. The FMJ calipers are designed to be rear hung so they'll work just fine. I covered all of this in my B body book.
[Re: AndyF]
#2568464
10/23/18 05:35 PM
10/23/18 05:35 PM
hemi71x
Getting parts for the Bendix disc brake systems isn't that difficult anymore in this day and age. Just gotta know where to look to purchase the parts. Piston rebuild kits, individual pistons, are available from ebay, and Amazon vendors. Rock auto too. As far as complete calipers, again check Rock Auto, and any parts store that carries the Centric line of auto parts. You can rebuild your own existing calipers, or send them out to the professional vendors that advertise, doing that type of work. As far as rotors, there a couple of vendors that sell a reproduction one piece rotor, and another sells a original two piece rotor that you reuse your existing hub that you remove from the old and reinstall onto the new. Repop caliper hard lines are available from the companies that sell fuel, and brake lines. Repop caliper hose brackets are available. Calipers bolt directly to the spindle, so no bracketry is neeeded for that. If the OP needs original 66-69 Bendix disc brake spindles they come up for sale from time to time on the internet web sites, or placing your own wanted ad. Buy yes, some of this stuff is expensive, $$$$$$$$$ dollar wise, depending on which way that you want to go, but all is available.
[Re: Moparnut426]
#2568492
10/23/18 06:16 PM
10/23/18 06:16 PM
hemi71x
NAPA on line sells a rebuilt caliper. I think after talking with a few companies today im going to do a A body swap kit...
Well, what type of brakes are on the car right now? You ever want to know, figure that out, anymore?
[Re: dragon slayer]
#2568502
10/23/18 06:37 PM
10/23/18 06:37 PM
hemi71x
So who makes a repopped single piece rotor for 66-69 Bendix? I have only see the rotor that requires and original hub to mate too it. There is this wonderful thing on the internet, called GOOGLE. Do your own search, and homework. Ever think of ebay, too?
[Re: hemi71x]
#2568847
10/24/18 01:21 PM
10/24/18 01:21 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
Well, what type of brakes are on the car right now? You ever want to know, figure that out, anymore? Its harvest time so I have been in the field. I snapped a couple JPEG potos last night quick when I finished up the corn. Hope these are good enough.
