Re: Nodular 8.75 case , how much stronger
[Re: B3422W5]
#2567823
10/22/18 02:11 PM
10/22/18 02:11 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Mine broke just as my car broke into the 10s. I was lucky and caught it as it got noisey but it had a broken tooth laying in the bottom of the housing when I did. Granted it was an old gear set with lots of miles and passes but I need reliability so I immediately started down the Dana Path, and it has been working great.
68 Barracuda Formula S 340
[Re: StealthWedge67]
#2567860
10/22/18 03:40 PM
10/22/18 03:40 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
For all those that call the modifications “band-aids”; the 9” units that most run are not stock Ford units, they’re full of aftermarket stuff also. For that matter, most Dana’s in this conversations are likely S60’s outfitted with Spools, aluminum covers, and aftermarket axles. But once you've done those modifications to a Dana or a 9", you have a nearly bulletproof rearend. Do whatever you want to an 8.75 and you're gonna still kill ring and pinions.
[Re: J_BODY]
#2568084
10/22/18 11:15 PM
10/22/18 11:15 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Been running the Dr Diff unit for 2+ years and it is awesome imo and a bit heavier but beefier with forged caps and stout adjusters.........of course my stock unit lasted 16+ years........... Come on Dom, we all know you go to the track for a couple passes like once every 2 years. Beating on it on the street will never duplicate the traction/stress it will see at the track. Lots of weak parts can live a long life w/ no traction. Thank you! but Jay I know for a fact Thumper has put twice as many passes on his car this year Then you did.. I think you're just jealous because his 727 trans. Actually stays together for an entire pass..
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#2568155
10/23/18 01:02 AM
10/23/18 01:02 AM
Posts: 13,198 aZLiViN
J_BODY
aZLiViN
Been running the Dr Diff unit for 2+ years and it is awesome imo and a bit heavier but beefier with forged caps and stout adjusters.........of course my stock unit lasted 16+ years........... Come on Dom, we all know you go to the track for a couple passes like once every 2 years. Beating on it on the street will never duplicate the traction/stress it will see at the track. Lots of weak parts can live a long life w/ no traction. Thank you! but Jay I know for a fact Thumper has put twice as many passes on his car this year Then you did.. I think you're just jealous because his 727 trans. Actually stays together for an entire pass.. Other than the pump gear breaking at MaTS.... I didn’t miss a round of racing that year due to the many issues I had! Who the L breaks a pump gear?!?! ....and I don’t think he has 8 passes on it Keep piling it on brother... I’m trying to care about it again!! ....and now that the 727 from L is healthy, I pulled it for a 904 :j
[Re: WHITEDART]
#2568325
10/23/18 01:24 PM
10/23/18 01:24 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Been running the Dr Diff unit for 2+ years and it is awesome imo and a bit heavier but beefier with forged caps and stout adjusters.........of course my stock unit lasted 16+ years........... Come on Dom, we all know you go to the track for a couple passes like once every 2 years. Beating on it on the street will never duplicate the traction/stress it will see at the track. Lots of weak parts can live a long life w/ no traction. Thank you! but Jay I know for a fact Thumper has put twice as many passes on his car this year Then you did.. I think you're just jealous because his 727 trans. Actually stays together for an entire pass.. And hundreds of street romps testing carbs........ My stuff lives for many years and will still wax his "race car"...........
[Re: 68shifter]
#2568353
10/23/18 02:03 PM
10/23/18 02:03 PM
Posts: 22,696 Bitopia
jcc
Bitopia
I recently put a 9” in my Duster. Fab housing I built notched for shocks, thru bolt 3.25” case and axles and what not from Cass. I probably have 16/1700 in it including the $75 disc brake kit from Summits clearance shelf. Stating the obvious, those needed pictured notches are brutally counterproductive to original point of adding a back brace. Other then that, it is pretty.
[Re: Thumperdart]
#2568557
10/23/18 08:48 PM
10/23/18 08:48 PM
WHITEDART
bean town ....Ca
[/quote] Thank you! [/quote] but Jay I know for a fact Thumper has put twice as many passes on his car this year Then you did.. I think you're just jealous because his 727 trans. Actually stays together for an entire pass.. [/quote] And hundreds of street romps testing carbs........ My stuff lives for many years and will still wax his "race car"........... [/quote] sounds like a magical match race in the making well I can no longer pick on Jay he might let the air out of my tire when we pit next to each other
[Re: Cab_Burge]
#2568707
10/24/18 02:02 AM
10/24/18 02:02 AM
WHITEDART
bean town ....Ca
. So let's get this straight Jay wants to race in Mexico and thumper wants to race on the street. So he don't break the 8 and 3/4. Sounds like the brawl in Barona.. sorry j but my money's on thump
[Re: J_BODY]
#2568858
10/24/18 01:31 PM
10/24/18 01:31 PM
Thumperdart
State of confusion
We can race here in Hesperia, plenty of roads brother......... If I had a truck n trailer I'd go to Kingman first to take out their fastest guy(Nova small block on spray goes 10.20's)then meet up with yall.........
[Re: Thumperdart]
#2568878
10/24/18 01:59 PM
10/24/18 01:59 PM
Posts: 1,237 North Central, Indiana
Roughbird72
We can race here in Hesperia, plenty of roads brother......... If I had a truck n trailer I'd go to Kingman first to take out their fastest guy(Nova small block on spray goes 10.20's)then meet up with yall......... 10.20s with spray is their fastest?!
72 Plymouth Roadrunner 11.08@123.25
[Re: B3422W5]
#2568879
10/24/18 01:59 PM
10/24/18 01:59 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
In these parts there are many very fast street cars,,,,,several low 8 second cars at that! So I'm not that fast...........
[Re: Roughbird72]
#2568892
10/24/18 02:28 PM
10/24/18 02:28 PM
Thumperdart
State of confusion
We can race here in Hesperia, plenty of roads brother......... If I had a truck n trailer I'd go to Kingman first to take out their fastest guy(Nova small block on spray goes 10.20's)then meet up with yall......... 10.20s with spray is their fastest?! Apparently............lol
[Re: Thumperdart]
#2568908
10/24/18 02:53 PM
10/24/18 02:53 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
In the spirit of how this thread started I will bet on the Dana and the small block
"Just a Bracket car dressed up like a streetcar"
