Re: 70-71 Cuda Shaker Hood Carb Height 383 [Re: mccannix] #2013716
02/17/16 02:26 AM
02/17/16 02:26 AM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
pretty sure the 340 and 383 base plates are 3/8" in height diff. just traded with mike ross .. he was careful to be sure it was in fact a 340 plate I had ... the adapter looks like it is about 3/8" to me ? just a thought ..
Re: 70-71 Cuda Shaker Hood Carb Height 383 [Re: ek3] #2013728
02/17/16 02:47 AM
02/17/16 02:47 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
When you say "base plates", I'll assume you mean the actual Shaker base/carb plate", and the adapter you saw? did you have it, or Mike Ross?
here's the Shaker base chart
Re: 70-71 Cuda Shaker Hood Carb Height 383 [Re: mccannix] #2563354
10/13/18 12:48 PM
10/13/18 12:48 PM
Norway
The Norwegian Offline
Norway
Hi
Would be nice to have contact data to this gentleman who made this rods.
Arne
71 Challenger Shaker
Re: 70-71 Cuda Shaker Hood Carb Height 383 [Re: The Norwegian] #2563390
10/13/18 02:14 PM
10/13/18 02:14 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Chris from Ny who used to make these rods sold his last one two years ago and has no plans to make more.
Try Tommy Chryco who advertises and contributes here.
He was talking about manufacturing a run of these.
Re: 70-71 Cuda Shaker Hood Carb Height 383 [Re: The Norwegian] #2563672
10/14/18 12:43 AM
10/14/18 12:43 AM
Woodbridge
Tommy The Chryco Offline
Woodbridge
Originally Posted By The Norwegian
Hi
Arne
Will have them available next month!
Fight the Good Fight- Elastomeric Bumpers and The Better "Shaker kits"
Re: 70-71 Cuda Shaker Hood Carb Height 383 [Re: Tommy The Chryco] #2563821
10/14/18 12:56 PM
10/14/18 12:56 PM
California
biggE Online content
biggE  Online Content
California
Very interesting information. I have a 383 base and never knew what the front hole was for.
Re: 70-71 Cuda Shaker Hood Carb Height 383 [Re: Tommy The Chryco] #2565406
10/17/18 03:25 PM
10/17/18 03:25 PM
MN
Droop69 Offline OP
Droop69  Offline OP
MN
That's awesome! I never could get a hold of the guy that made the 1st run of reproductions.
You have to wonder how rare of a part the factory original support rods are? I have never seen a factory original one on a car or at a swap meet.
Re: 70-71 Cuda Shaker Hood Carb Height 383 [Re: Droop69] #2567464
10/21/18 08:52 PM
10/21/18 08:52 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
The only original support I have seen was broken off in the block, bet that was common.
Re: 70-71 Cuda Shaker Hood Carb Height 383 [Re: 4406bbl] #2568297
10/23/18 12:34 PM
10/23/18 12:34 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
Scott at Harms Auto has the correct base spacer, which is not the 108-18 that Terry mentions. It is an aluminum one that was on all cars with a Holley 4bbl, in 1970 and 1971. It would have come with an asbestos top and bottom, which are not on Scott's spacer, as that type of material is no longer available. But he does have other suggestions for something comparable that would work the same as the asbestos.
