Re: 8 1/4" Sure-grip interchange?
[Re: pyp1000]
#256632
03/17/09 05:04 PM
03/17/09 05:04 PM
Posts: 2,265 ILLINOIS
volaredon
ILLINOIS
for that kind of money, wouldn't it be easier and cheaper to install a sure grip in the existing axle?
I believe that was the point of the post taking the SG out of the Dakota and putting it into the Duster rear; also the spline count change was 97+, so you should be OK to use that SG. (though IDK if it was a "mid year" change, so that one would be too close to the cutoff to say for certain, w/o actually counting the splines)
[Re: Jim_Lusk]
#256635
03/17/09 07:49 PM
03/17/09 07:49 PM
volaredon
ILLINOIS
One more thing, the ring gear must have a tone ring for the ABS. If Jeff wants to run these gears will there be any problem?
You may have to slightly grind the old case for clearance. but you can remove the tone ring with no issues, too.
[Re: 80mirada]
#256636
03/17/09 08:56 PM
03/17/09 08:56 PM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
Have you seen the price on sure-grips for an 8.25 lately?
Yep:
Mopar Performance P4529273 $313.95
For the same price, I'd go with a new one and be done with it. It'll drop right in and you know it'll last a while. How long will a used SG last?
[Re: Quikshft]
#256638
03/18/09 12:14 AM
03/18/09 12:14 AM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
You can still count, and I can still grind.
Works for me. I'll let you know when I yank an axle, which is a whole lot better than yankin' yer chain..........
[Re: Jim_Lusk]
#256639
03/18/09 09:44 AM
03/18/09 09:44 AM
Posts: 1,396 Mass
dgc333
Mass
The tone ring is a seperate piece that sandwiches between the carrier and ring gear, easy enough to leave out if you are swapping the differential.
