Re: 440 stroker?
[Re: 70charger512]
#2581641
11/22/18 06:48 PM
11/22/18 06:48 PM
Posts: 4,213 New York
polyspheric
New York
Cam around 240@.050 As I said (50 years ago?), that narrows it down to perhaps 20 or 30 cams. What nominal duration? What LSA? What installed ICL? Single or dual pattern?
The reason being is to try and keep some quinch in the combustion chambers THIS^^^ Ideally, the dish would be close to a mirror image of the chamber outline (and flush under the head's quench ledge). IMHO the floor need not be flat if you have enough dome thickness - deeper under the intake position @ .200".
Boffin Emeritus
Re: 440 stroker?
[Re: 70charger512]
#2581662
11/22/18 07:53 PM
11/22/18 07:53 PM
Posts: 6,571 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
You might want to consider using a deep reverse dome piston with 24.0 CC instead of a shallow full dish piston with 24.0 CC. The reason being is to try and keep some quinch in the combustion chambers Thats what I was thinking, and I actually emailed 440 source about whether or not theyre dish or reverse dome, and I will ask if theres a way to get reverse dome with their kit. My 440/493 kit from 440Source used Ross pistons so it was a while ago. It was a custom 34cc reverse dome that with OOTB 84cc RPM heads, zero deck and a .039 gasket put me at 8.97:1 IIRC. It makes 600 ft/lbs on 87 regular. In the time it took Ross to finally make the pistons, (3 months. Nice customer service) Brandon had enough orders to make it a shelf stocking piston so I got the custom up charge $$ back. If they still do this piston maybe they can change the pin height for a small fee. Kevin
Re: 440 stroker?
[Re: Twostick]
#2581665
11/22/18 08:06 PM
11/22/18 08:06 PM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
You might want to consider using a deep reverse dome piston with 24.0 CC instead of a shallow full dish piston with 24.0 CC. The reason being is to try and keep some quinch in the combustion chambers Thats what I was thinking, and I actually emailed 440 source about whether or not theyre dish or reverse dome, and I will ask if theres a way to get reverse dome with their kit. My 440/493 kit from 440Source used Ross pistons so it was a while ago. It was a custom 34cc reverse dome that with OOTB 84cc RPM heads, zero deck and a .039 gasket put me at 8.97:1 IIRC. It makes 600 ft/lbs on 87 regular. In the time it took Ross to finally make the pistons, (3 months. Nice customer service) Brandon had enough orders to make it a shelf stocking piston so I got the custom up charge $$ back. If they still do this piston maybe they can change the pin height for a small fee. Kevin Oh ok thank you, so they do offer custom kits, that helps alot. Im not gonna go that low on compression though, im thinking 10-10.5, maybe 11 if i have to for some reason.
Re: 440 stroker?
[Re: 70charger512]
#2581701
11/22/18 09:55 PM
11/22/18 09:55 PM
Posts: 2,879 Pattison Texas
CSK
Pattison Texas
yes the 440 source 24cc pistons have a guinch area.
Re: 440 stroker?
[Re: 70charger512]
#2581747
11/23/18 12:01 AM
11/23/18 12:01 AM
polyspheric
New York
Be sure to keep those sharp machined edges exactly as they left the mill, just like jewelry!
Boffin Emeritus
Re: 440 stroker?
[Re: 70charger512]
#2581757
11/23/18 12:38 AM
11/23/18 12:38 AM
BradH
Another thing: alot of people were saying I would need a 2"+ compression height piston, but these are 1.867. How much does compression height matter after all of the other things have been worked out? Read... the... books... If you don't understand the implications of compression heights, you shouldn't be building anything. I'm done with this.
Re: 440 stroker?
[Re: 70charger512]
#2581789
11/23/18 02:15 AM
11/23/18 02:15 AM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
Daily driver that gets 7 miles per gallon, sure.
Have a great day Iowan
"obsolete is neat"
Re: 440 stroker?
[Re: polyspheric]
#2581795
11/23/18 02:54 AM
11/23/18 02:54 AM
CSK
Pattison Texas
Be sure to keep those sharp machined edges exactly as they left the mill, just like jewelry! Absolutely LOL
Re: 440 stroker?
[Re: BradH]
#2581969
11/23/18 04:34 PM
11/23/18 04:34 PM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
Another thing: alot of people were saying I would need a 2"+ compression height piston, but these are 1.867. How much does compression height matter after all of the other things have been worked out? Read... the... books... If you don't understand the implications of compression heights, you shouldn't be building anything. I'm done with this. Ok then bye. But im clearly not building this myself. Hollis Page will be. I apologize for asking questions on a website meant for questions...
Re: 440 stroker?
[Re: 70charger512]
#2581985
11/23/18 05:09 PM
11/23/18 05:09 PM
Posts: 4,457 Washington
madscientist
Washington
Another thing: alot of people were saying I would need a 2"+ compression height piston, but these are 1.867. How much does compression height matter after all of the other things have been worked out? Read... the... books... If you don't understand the implications of compression heights, you shouldn't be building anything. I'm done with this. Ok then bye. But im clearly not building this myself. Hollis Page will be. I apologize for asking questions on a website meant for questions... It's hard to communicate via the interweb, especially when the topic is as detailed as what you want. On top of that, you are like a fart in a skillet. You are all over everywhere. I'm old enough to tell you've I've seen this before. You want to know it all, and know it now. It doesn't work that way. When you struggle with what compression distance is (nothing more that stroke length/rod length/ deck height) and mix things together, no one has any idea if you are actually teaching with what you are being told, or you are getting more confused. You need to slow down and realize you won't learn this [censored] in a year. Or a decade. It's a lifetime of learning and it only stops when you quit or die. You need to take this like eating an elephant...you do it one bite at a time. What you are doing is trying to take a sip from a fire hose. Read everything you can. Then reread it. It takes a lifetime.
Re: 440 stroker?
[Re: 70charger512]
#2581986
11/23/18 05:11 PM
11/23/18 05:11 PM
Iowan
Lost in Time
Questions were answered repeatedly very thuroly, its to bad the answers could not be comprehended. This is what hotroding has come to, just assembling parts, you dont have to know what your doing just open a catalog or two and buy parts. I think guys with small block chevys have been doing it for years.
"obsolete is neat"
