Strange question- REAR WHEEL TORQUE for 440 #2563995
10/14/18 06:44 PM
10/14/18 06:44 PM
Canada
CrAzYMoPaRGuY Offline OP
Canada
We are trying an EFI setup for a 440 and one of the main parameters we have to enter is "rear wheel torque value".
440 - .030 with six pack pistons.
3906 heads that were cut .020 or .030 with steel gaskets.
MP .455 lift 272 duration hydraulic cam
Has headers, mandrel 2 1/2 out rear, Street Dominator intake
What's a decent guess at rear wheel torque???
THANKS!!!
CrAzYMoPaRGuY
Re: Strange question- REAR WHEEL TORQUE for 440 [Re: CrAzYMoPaRGuY] #2563996
10/14/18 06:44 PM
10/14/18 06:44 PM
Canada
Canada
I'm guessing 400 ft lbs??
CrAzYMoPaRGuY
Re: Strange question- REAR WHEEL TORQUE for 440 [Re: CrAzYMoPaRGuY] #2564045
10/14/18 08:37 PM
10/14/18 08:37 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Only if you're running a 1:1 rear end whistling
Multiply your 400 ft-lb by your rear gear ratio. Then divide by two since half goes to each wheel.
https://x-engineer.org/automotive-engine...-torque-engine/
Re: Strange question- REAR WHEEL TORQUE for 440 [Re: CrAzYMoPaRGuY] #2564047
10/14/18 08:40 PM
10/14/18 08:40 PM
Canada
Canada
It's got 3.91 gears and a 518 4 speed trans.
Asks for a rear wheel torque and says it defaults to mild Chevy 350 specs which it says is is 300 ft lb....
CrAzYMoPaRGuY
Re: Strange question- REAR WHEEL TORQUE for 440 [Re: CrAzYMoPaRGuY] #2564087
10/14/18 09:55 PM
10/14/18 09:55 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
A strange Q from a very strange dude in miniVancouver ? ... PERISH that tHoUgHt !!
oleHam rElEaSe him nOw ... Or is it visa vErSa ??!!
Re: Strange question- REAR WHEEL TORQUE for 440 [Re: dOrk !] #2564115
10/14/18 10:29 PM
10/14/18 10:29 PM
Canada
Canada
I'm hungry Doc. Let's go for lunch....?
Hours and hours, and not one guess. lol
We are using 400. Will see how it works
You pay for lunch btw. Mr DeEEEp poCKETs
CrAzYMoPaRGuY
Re: Strange question- REAR WHEEL TORQUE for 440 [Re: CrAzYMoPaRGuY] #2564161
10/14/18 11:28 PM
10/14/18 11:28 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
Yes cRaZy .., I'll buy but youz gotsta bring oleHam ! ... but after the end of the NHL season ! ... You can drink from THE CUP 'here in Tampa Bay !
Re: Strange question- REAR WHEEL TORQUE for 440 [Re: CrAzYMoPaRGuY] #2564248
10/15/18 04:12 AM
10/15/18 04:12 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Rear wheel torque would be flywheel torque times 1st gear ratio times rear gear ratio and would be a figure in the thousands. This is with a manual trans w an auto the torque converter would increase it even more....
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Strange question- REAR WHEEL TORQUE for 440 [Re: CrAzYMoPaRGuY] #2564339
10/15/18 12:04 PM
10/15/18 12:04 PM
Throw a number in it and go drive it, then change that number ONLY and see if it likes the change or not scope
TEST, test and test some more until your so happy you know you have it perfect up wrench grin
Watch the AFR output also carefully at part throttle and WOT scope You will know when it is making you very happy work thumbs
Re: Strange question- REAR WHEEL TORQUE for 440 [Re: Cab_Burge] #2564552
10/15/18 07:53 PM
10/15/18 07:53 PM
Canada
Canada
Thanks Cab!! We are doing what you said!!
No concrete figure and we HAVE to enter a number, drives us crazy....
CrAzYMoPaRGuY
Re: Strange question- REAR WHEEL TORQUE for 440 [Re: HemiRick] #2564557
10/15/18 08:06 PM
10/15/18 08:06 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Only if the program is expecting MAXIMUM torque at the wheels, and not the ratio in a direct (1:1) high gear. OP didn't specify. And don't forget to divide by 2 since half goes to each wheel.
Re: Strange question- REAR WHEEL TORQUE for 440 [Re: CrAzYMoPaRGuY] #2564574
10/15/18 08:37 PM
10/15/18 08:37 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Here's an article on 440 mods and dyno numbers to match the mods, compare to yours:
https://www.hotrod.com/articles/mopp-0301-mopar-440-engine/
Re: Strange question- REAR WHEEL TORQUE for 440 [Re: John_Kunkel] #2565225
10/17/18 03:55 AM
10/17/18 03:55 AM
Canada
Canada
Absolutely perfect. THANKS!!!!! up
CrAzYMoPaRGuY
