Need Steel Wheel ID Help #2564041
10/14/18 08:35 PM
10/14/18 08:35 PM
New Jersey
P
Powerflow Offline OP
P
New Jersey
I found this pair of steel wheels in my basement and am curious about what they fit. The edge of the wheel is stamped 14x5-1/2 JJ K1 over 81 and there is '5 <<valve hole>> 5' stamped on the face of the rim.
Any help appreciated!
Re: Need Steel Wheel ID Help [Re: Powerflow] #2564099
10/14/18 10:06 PM
10/14/18 10:06 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Looks like 1966-earlier Mopar. Did you check the bolt pattern?
They would hold the larger dog-dish caps - for 1967 & earlier cars. Look familiar? http://www.classicchambered.com/rims/1455.jpg
Re: Need Steel Wheel ID Help [Re: Powerflow] #2564154
10/14/18 11:20 PM
10/14/18 11:20 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
14 x 5.5 wheels came on 66/67 Hemi cars, 67 440 cars, some 66 383 cars, and all 66/67 Bbody wagons. 66 wheels and early 67 wheels have the 5 lug holes and 5 holes in between like yours have. Post some pictures of the stampings you found
Re: Need Steel Wheel ID Help [Re: Powerflow] #2564171
10/14/18 11:40 PM
10/14/18 11:40 PM
New Jersey
P
P
New Jersey
I attached the one picture of the numbers near the valve stem hole I took earlier today.
Re: Need Steel Wheel ID Help [Re: Powerflow] #2564192
10/15/18 12:21 AM
10/15/18 12:21 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Have any pics of the inside rim numbers?
Re: Need Steel Wheel ID Help [Re: ScottSmith_Harms] #2564272
10/15/18 08:28 AM
10/15/18 08:28 AM
New Jersey
P
P
New Jersey
Not yet. Will try to get one after work tonight.
Re: Need Steel Wheel ID Help [Re: Powerflow] #2564319
10/15/18 11:30 AM
10/15/18 11:30 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
What's the bolt pattern? These could be A-Body wheels too.
Re: Need Steel Wheel ID Help [Re: Sunroofcuda] #2564573
10/15/18 08:34 PM
10/15/18 08:34 PM
blewbyu Offline
blewbyu  Offline
Those are not A Body wheels as they do not have the little holes
Re: Need Steel Wheel ID Help [Re: Powerflow] #2564602
10/15/18 09:38 PM
10/15/18 09:38 PM
New Jersey
P
P
New Jersey
I took these pictures as it was getting dark (with a little help from my HF 27-LED flashlight). These were the only numbers I found on the edge of the rim. I also found a 'KH' on the face of the wheel; must be Kelsey-Hayes.
Re: Need Steel Wheel ID Help [Re: Powerflow] #2564678
10/16/18 12:30 AM
10/16/18 12:30 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Well, it's 5.5" wide not 5".
