Bad Vibrations, Chicago Fury saga
#2563496
10/13/18 06:30 PM
10/13/18 06:30 PM
Posts: 2,255 IL
furious70
IL
I can't figure this out. Flex plate tightened, all mounts tight, u joints feel good and are pretty new, pig is tight. Vibration is rpm dependent it seems, not speed. I've got 2 videos I'll link here. You can see the speedo and the tach. Around 55-60mph it's a very cyclical vibration comes and goes every 1-2 seconds. When I accel it'll jump to every 1/2 sec then smooths out when I'm going 65mph or so and 3300rpm. Then repeats the cadence on decel. On the video it sounds a bit like an exhaust leak, but that's actually the vibration noise. I feel it in the front, don't feel it in my butt or from the rear at all, which makes sense since its rpm related. I get a bit of the vibes as it gets to the top of the rev band before shifting as well. Anytime it's doing it if I flip OD on it instantly goes away on the shift. This engine had been together for decades hooked to a 727 in this car and hooked to the a500 for 10yrs. The First engine with the a500 did not do this that I remember. It developed blow by and I stuck this engine back in. This setup has done it for years, but I'm just getting the car back out from a slumber of 2yrs Any thoughts? https://www.youtube.com/watch?v=EXHfeZko0nAhttps://www.youtube.com/watch?v=elas8Yz5hgk
70 Sport Fury 68 Charger 69 Coronet 72 RR
Re: Bad Vibrations, Chicago Fury saga
[Re: furious70]
#2563542
10/13/18 08:27 PM
10/13/18 08:27 PM
Posts: 2,255 IL
furious70
IL
I had started to wonder that. Every combo I've had in the car is supposed to be internally balanced. I've been concerned cuz this block has an 'E' stapmed on the pad and is a 71, not original to the car but was in the car when I got it with 43k in it. Engine has been rebuilt by a cheap house back in the day, had a reman tag on it. It'd be sad that if it's always had a cast crack in it and in 21 years of ownership I didn't realize it. This would be the first one I've mismatched, do they normally act up in only 1 rpm range?
[Re: furious70]
#2563596
10/13/18 10:24 PM
10/13/18 10:24 PM
RapidRobert
Anytime it's doing it if I flip OD on it instantly goes away on the shift. Any thoughts? This may be WAY too simple but I'd think internal trans related (or at least I would try & figure out what is changed/different when it goes into OD)
[Re: furious70]
#2563708
10/14/18 01:49 AM
10/14/18 01:49 AM
Posts: 20,631 in a cattle trailer down by th...
Guitar Jones
What changes when it shifts into O/D? The engine RPM changes that's what. If the vibration is there in park or neutral then you know it's an engine balance issue.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: furious70]
#2563721
10/14/18 02:21 AM
10/14/18 02:21 AM
Posts: 1,996 s. e. pa.
calrobb2000
s. e. pa.
hi
you have too much timing advance .
disconnect any vac advance and test drive it.
if it still does it back off timing or slow the advance rate.
[Re: calrobb2000]
#2563798
10/14/18 11:57 AM
10/14/18 11:57 AM
RapidRobert
I would get in the same RPM range where it is vibrating & get it there both in & out of OD & see if it vibrates both times, if so that would for sure point to an eng balance issue.
[Re: furious70]
#2564121
10/14/18 10:38 PM
10/14/18 10:38 PM
Posts: 2,255 IL
furious70
IL
Timing was an interesting idea, a few taps of the keyboard ruled that out. Moved it from 38* to 32 to 28* made no difference. It does it parked, first, and second gear but way more pronounced in drive for some reason.
[Re: furious70]
#2564187
10/15/18 12:10 AM
10/15/18 12:10 AM
Posts: 89 Cedar Rapids, IA
69Mcode440
Cedar Rapids, IA
Check the rear bushing in the transmission. Mike
Mike 69 440 Cuda 71 Dart drag car 70 Duster drag car Best et 9.32, 145.9 mph 2019 Ram 2500 4x4
[Re: 69Mcode440]
#2564274
10/15/18 08:31 AM
10/15/18 08:31 AM
Posts: 2,255 IL
furious70
IL
Check the rear bushing in the transmission. Mike Can I do that with it in the car?
[Re: furious70]
#2564287
10/15/18 09:54 AM
10/15/18 09:54 AM
Guitar Jones
Check the rear bushing in the transmission. Mike Can I do that with it in the car? If you have the vibration sitting still it is not in the driveline. It only seems worse in drive because of the load it's under.
[Re: furious70]
#2564546
10/15/18 07:33 PM
10/15/18 07:33 PM
Posts: 2,255 IL
furious70
IL
I'll check the dampner to make sure nothing goofy has happened there, but after that, pull the pan to see what the crank is?
[Re: furious70]
#2564790
10/16/18 12:28 PM
10/16/18 12:28 PM
Posts: 2,255 IL
furious70
IL
interesting. cheap flex fan on this one. I did pay attention to the accessories this weekend, didn't notice anything out of whack with them.
[Re: furious70]
#2572443
11/01/18 12:11 AM
11/01/18 12:11 AM
Posts: 6,561 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
This engine had been together for decades hooked to a 727 in this car and hooked to the a500 for 10yrs. The First engine with the a500 did not do this that I remember. This setup has done it for years, but I'm just getting the car back out from a slumber of 2yrs
I'm a little confused on the timeline but which transmission has it vibrated with, the 727, the A500 or both? If it shook with both, then it's in the engine. If it didn't shake with whichever trans was in it first but it does with what's in there now, it could be in the front of the transmission, whatever spins internally in neutral either directly or thru sympathetic motion. I don't know if it was covered already but do you know the build history on the engine or did you get it the way it is? If it had say a cast crank and sixpak rods or a mix and match of LY's in it and it wasn't balanced, it would definitely have a shake. A cast crank and neutral balancer and flexplate could do it or any combination of the above. Kevin
