Re: overcharging
[Re: maxwedge1]
#2563649
10/14/18 12:11 AM
10/14/18 12:11 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Battery voltage should match alternator output stud voltage. If it doesn't then the wiring between the alternator output and the battery and anything inline with it such as an ammeter is suspect. Is your fusible link good?
Re: overcharging
[Re: maxwedge1]
#2563684
10/14/18 01:00 AM
10/14/18 01:00 AM
Andrewh
what supercuda says is true, you should be looking at wiring issues between the battery and the vr.
it passes through the bulkhead from the battery to the amp meter, to the ignition and then back out the bulkhead again.
Also be sure you are using the same reference for ground, as that can change your readings too. in case that doesn't make sense, if you are checking the vr, don't use the battery as ground. use the bolt holding it on the firewall as ground, unless you added a ground strap.
or voltage at the alt, field wire, use the alt case as the ground for that voltage.
In theory this should not change the reading. in practice bad grounds will cause different voltages, especially at the vr.
But that is nearly a 1 volt drop, which will screw with your charging system.
Re: overcharging
[Re: maxwedge1]
#2563691
10/14/18 01:10 AM
10/14/18 01:10 AM
RapidRobert
run an 8 ga jumper line from batt positive terminal to the alt "batt" threaded stud & see what you get at the battery at a fast idle. EDIT (much) easier yet, hook your large "regular" jumper cables from the batt pos/neg posts over to the alt "batt" stud/housing case (have a helper hold the ends at the alt) & fire it up & see what you get at the batt & the alt. 15+ is way too high for a charged battery. You might even get a handfull of HF mini jumpers with alligator clips & feed the reg/alt field circuits including ground paths & see what develops. this takes everything out of the picture exc the hard components: alt/reg/batt.
Re: overcharging
[Re: maxwedge1]
#2563800
10/14/18 12:01 PM
10/14/18 12:01 PM
Supercuda
About to go away
About to go away
up yours
The voltage on the blue line should be the same as at the battery + and the alternator output stud. That;s what the VR uses to determine the required alternator output. If it is reading low then it will try to run the alternator harder to bring the voltage up. Probably dirty/loose connections in that line. I usually remove, clean, tighten and reinstall them.
Re: overcharging
[Re: maxwedge1]
#2563812
10/14/18 12:20 PM
10/14/18 12:20 PM
RapidRobert
Yes the blue wire (ign1) out from the bulkhead feeds the alt (blue wire) field terminal/reg top triangle blue wire connector/upstream side of ballast/ECU power in terminal likely red if OE/blue yellow on MP ECU connector pigtail/even elec choke if used. Grab your meter!
Re: overcharging
[Re: maxwedge1]
#2563830
10/14/18 01:22 PM
10/14/18 01:22 PM
Andrewh
When I finally gave up on chasing the drop, I used that line to feed a relay instead to power directly from the battery to the vr. but yeah, grab a meter and start checking to see when you get a change working your way back. http://www.mymopar.com/index.php?pid=28at least the diagrms.
Re: overcharging
[Re: maxwedge1]
#2564069
10/14/18 09:30 PM
10/14/18 09:30 PM
Supercuda
About to go away
About to go away
up yours
I would use a relay controlled by a switched feed and use the relay to send the blue line voltage from the battery.
Re: overcharging
[Re: maxwedge1]
#2564072
10/14/18 09:39 PM
10/14/18 09:39 PM
RapidRobert
battery 12.4 down a bit from testing and 12.3 at the field terms and output running 13.6-14. at a fast idle the batt is 12.4/12.3 & the alt large batt terminal is 13.6-14, correct? post everything what you have jumped/fed/bypassed.
Re: overcharging
[Re: maxwedge1]
#2564591
10/15/18 09:09 PM
10/15/18 09:09 PM
Supercuda
About to go away
About to go away
up yours
By "at rest" do you mean engine not running? Because your descriptions are confusing. The idle numbers look good, did that fix what you were seeing?
