Re: Engine hard to start after driving
[Re: ROADRCR]
#2561592
10/09/18 08:43 PM
10/09/18 08:43 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
You don't mention what your ignition setup is but when the engine is hot and "barely turns over" unplug the coil (no spark is what you want), that will eliminate ignition as an issue if it still barely turns over.
If it turns over normal then it's an ignition related issue.
[Re: Supercuda]
#2561597
10/09/18 08:56 PM
10/09/18 08:56 PM
RapidRobert
^^^ agreed, unplug & GROUND the coil wire & if no change you might put a 1&1/4" socket on the crank & see how much torque it takes to turn it & you might check the cranking voltage at the starter. Keep us updated. EDIT seperate the dist pickup zigzag connector to disable the ign (be sure to not let the metal (male) tip of the body half of the connector touch ground!)
[Re: hemirdrnnr]
#2561793
10/10/18 08:21 AM
10/10/18 08:21 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
mine did the same thing.it was the ground.i added another and it worked instantly.my headers are only 1/4 in. away from starter.its just a JY mini.
[Re: Supercuda]
#2562024
10/10/18 05:05 PM
10/10/18 05:05 PM
DaytonaTurbo
Manitoba, Canada
Yup, this is the first place to start. I did an engine build and then by coincidence my voltage regulator went at the same time. Battery was getting a low charge and engine wouldn't restart hot.
