727 shield
#2559387
10/05/18 01:29 PM
10/05/18 01:29 PM
Posts: 1,467 Martinsville, IN
cdwmotorsports
Martinsville, IN
Anyone have suggestions on what to get and what to stay away from?
eBay-cdwmotorsports
Re: 727 shield
[Re: SportF]
#2559586
10/05/18 06:49 PM
10/05/18 06:49 PM
cdwmotorsports
Martinsville, IN
I like a blanket 'cause I personally saw a shield turn into a yellow ball of yarn that did NOTHING to prevent fragments from coming through the floor. Driver almost lost his foot.
Many of you heard me tell that above story before.
The drivers foot and toes basically turned black, and the doctor was prepping to remove a large part of it when he brushed across the toes. The patient groaned when that happened, and then the doctor did it again.
At this point the driver said why did you do that again? Doctors reply, you can feel that? Well, then, we need a different approach...… Do you have trans. temp issues with Blanket? I'm not opposed to a blanket aside from the temp issue
eBay-cdwmotorsports
Re: 727 shield
[Re: cdwmotorsports]
#2559631
10/05/18 08:40 PM
10/05/18 08:40 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
I run a blanket . Have not seen any temp issues , daily driven with a 5800 stall . I do run a short blanket .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: 727 shield
#2559659
10/05/18 09:43 PM
10/05/18 09:43 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
At this point the driver said why did you do that again? Doctors reply, you can feel that? Well, then, we need a different approach...… Do you have trans. temp issues with Blanket? I'm not opposed to a blanket aside from the temp issue NO! That's is not to say you won't have any heating issues though My current bracket car with a glide that now stalls around 5600 RPM against the brake runs under 150 F all the time at the track, I have to warm the tranny up against the brake to get heat into the fluid
Re: 727 shield
#2560749
10/08/18 10:43 AM
10/08/18 10:43 AM
Posts: 13,404 Marion, South Carolina [><]
an8sec70cuda
I run the CSR shield. I had one on my cuda's 727 when it exploded 10 years ago and it did it's job protecting me. No complaints here.
Basically your only options are the CSR shield or a blanket in a stock body car. I prefer the shield.
Re: 727 shield
[Re: moparx]
#2561390
10/09/18 01:35 PM
10/09/18 01:35 PM
Posts: 9,883 MI, usa
dvw
MI, usa
doug, are you talking about the bolt together shield made of 1/4" aluminum plate ? Yes
Re: 727 shield
[Re: dOc …]
#2561501
10/09/18 05:36 PM
10/09/18 05:36 PM
dvw
MI, usa
Let me throw a Q in here .. Why does an alum shield have to be recerted if it is not damaged ? uNless it is all about just THEM dipping into OUR WALLET again !! Nobody ever checks them. Doug
