Exhaust size #2561524
10/09/18 06:21 PM
10/09/18 06:21 PM
NC
70charger512 Offline OP
#1 Thread Starter
#1 Thread Starter
NC
I asked this on the q&a section but only got 2 responses. If I am running a 440 with around 500-550 hp, should I go with a 2.5" or 3" exhaust? I want optimal flow, not just bigger because it might sound better, either way it will sound great. Im also planning on getting 1 3/4" headers.
Re: Exhaust size [Re: 70charger512] #2561536
10/09/18 06:44 PM
10/09/18 06:44 PM
Colorado front range
BcudaChris Offline
BcudaChris  Offline
Big block guys will correct me if I'm wrong, but conventional thinking would be 3" and think about 1 7/8" headers for max power. At your displacement/power target, I think the 2.5" would hold you back and with 1 3/4 headers you would be trading high RPM power for low end torque.
What are your goals though? Packaging, cost and weight would be the down sides of bigger tubes. Maybe noise too, depending on your goals.
Re: Exhaust size [Re: 70charger512] #2561538
10/09/18 06:47 PM
10/09/18 06:47 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
For a street car I like 3" from the headers to the mufflers and 2.5 tailpipes. It will flow nearly as good as a full 3" system but will not be nearly as obnoxious.
Getting old just means you were smarter than some and luckier than others.
Re: Exhaust size [Re: 70charger512] #2561544
10/09/18 07:00 PM
10/09/18 07:00 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
1 7/8", 3" (min.), decent free flowing mufflers.
Re: Exhaust size [Re: CMcAllister] #2561552
10/09/18 07:16 PM
10/09/18 07:16 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I run 3" to the rear axle with turndowns. Walker Dynomax Ultraflow. No drone and very quiet in the car until you mash the loud pedal!
'63 Dodge 330
11.19 @ 121 mph
Re: Exhaust size [Re: BcudaChris] #2561607
10/09/18 09:17 PM
10/09/18 09:17 PM
jersey
Spaceman Spiff Offline
jersey
F.A.S.T. Class is restricted to 2 1/2in exhaust. Several of those cars are in the 9's at well over 130mph. I doubt you'd feel any difference between 2.5 and 3 inch.
I know on my 526, there was no noticeable gain going to 3 inch.
However, going from a 850 and an rpm intake, to a M1 and a "1000" cfm carb, picked up A LOT.
Every combination is different. 3 inch WILL make it louder.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Exhaust size [Re: Spaceman Spiff] #2561628
10/09/18 10:19 PM
10/09/18 10:19 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Is there a point where you "need" a 3" exhaust? Like, say 600 HP - up? Would a 2.5" exhaust be enough to support that kind of power?
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Exhaust size [Re: 70charger512] #2561657
10/09/18 11:05 PM
10/09/18 11:05 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Prosport' Duster runs mid 10's with a 500' engine and 1 3/4" headers. Tests have proven that you don't need as big pipe after the muffler as the exhaust gasses have cooled and at that point don't need the larger pipe.
Re: Exhaust size [Re: dannysbee] #2561663
10/09/18 11:17 PM
10/09/18 11:17 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I ran that combination on my Challenger when it was going 11.0s. It was frequently the quieter of two cars going down the track, even when it was the faster car, too.
I did upgrade to a full 3" system when the car started going about 1/2 second quicker. However, it's nowhere as subtle from a noise perspective with the bigger pipes.
Re: Exhaust size [Re: 70charger512] #2561665
10/09/18 11:17 PM
10/09/18 11:17 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
From the other post, it seems to me the combination is undercammed, undercarbureted, and has the wrong intake manifold to make 500 real hp.
But if your heart is set on all those parts and there's no ET goal or anything like that, give it a whirl, you may end up liking it just fine and the exact number won't matter as much as feeling happy with it and knowing it's your ideas.
Ignoring all that kind of stuff, 1 7/8 with a 3" collector, 3" headpipes into mufflers/2.5" tailpipes is plenty adequate and gives a little room to grow if you decide to go with more cam and so on later, to satisfy the need for speed.
Mine went 119 with that combination minus tailpipes. And I bet the tailpipes would have just made it quieter inside.
Being a believer in making the exhaust whatever size the collector is has led me to 3.5" exhaust, which I don't actually recommend to anyone. I had fun fabricating it, though, and the car sounds really unique. But like underdrive pulleys, which I also use, I always tell everyone else not to.
Rich H.
Esse Quam Videri
Re: Exhaust size [Re: 70charger512] #2561723
10/10/18 01:07 AM
10/10/18 01:07 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Re: Exhaust size [Re: dannysbee] #2561744
10/10/18 01:47 AM
10/10/18 01:47 AM
My old pump gas Duster ran 10.00 a bunch of times at 134.6 MPH through the full length to the rear bumper 3.0 inch exhaust system with 2.0 primary pipes and 3.5 inch collectors shruggy
My 440 powered Dart picked up .84 ET and 8.3 MPH in the 1/4 mile by removing the 2.5 inch exhaust system with 2.5 inch Corviar turbo muffs from the headers to the side pipes exiting at the front of the rear tires work shruggy
Size can and does matter on exhaust systems when it comes to Hi Po applications that are sort of half fast shruggy
My next pump gas 3/4 fast street car will have either a 3.5 or 4.0 exhaust system on it with either 2 1/8 to 2 1/4 step headers or 2 1/4 primary pipes into the 4.0 inch collector up devil
Re: Exhaust size [Re: 70charger512] #2561786
10/10/18 07:30 AM
10/10/18 07:30 AM
gregsdart Offline
gregsdart  Offline
The most overlooked part of the exhaust system are mufflers. It takes 2.2 cfm of flow per hp for a no loss system, and that is part of the equation for zero loss. A 2 cfm per hp system costs you a 2 percent power loss, and the loss goes up fast from there. There is a very good chapter in David Vizards' book How to build Horsepower, new edition. To make the motor act like it has open exhaust, a termination chamber the same cubic inch as the cylinders(for a motor of 446 cubes, 223 cubic inch chamber right after each collector, no reducer, bell shaped exit) then big enough pipes and mufflers to match the power. For mufflers, to get addiquet flow you might have to use a larger entry and exit and reducers to get enough flow, like 3 inch on each end of the muffler, 2.5 inch pipes in and out.
Re: Exhaust size [Re: 70charger512] #2561843
10/10/18 11:35 AM
10/10/18 11:35 AM
an8sec70cuda Offline
Like I said on the other post, go w/ 3" exhaust and some good mufflers like Dynomax UltraFlow or Hooker Max Flow.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Exhaust size [Re: ZIPPY] #2561853
10/10/18 11:47 AM
10/10/18 11:47 AM
NC
#1 Thread Starter
#1 Thread Starter
NC
500+ to the crank. I based it off a build that made 537, with a very similar cam.
Re: Exhaust size [Re: 70charger512] #2561889
10/10/18 12:49 PM
10/10/18 12:49 PM
Was this 537 hp build from a magazine?
CHIP
Re: Exhaust size [Re: an8sec70cuda] #2562021
10/10/18 04:59 PM
10/10/18 04:59 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Here is a good example:
https://www.hotrod.com/articles/how-you-can-build-a-stout-537hp-street-440/
Even Steve Dulcich couldn't make a 537HP 440 without a single plane intake, larger 4150 carburetor, and significantly more aggressive camshaft than the 268/276 grind posted previously.
Not saying any of this to be contradictory, in fact I am all for supporting your idea, creating your own combo and trying it....but expectations should probably be managed.
I am familiar with the combo. The engine you've described will be very tame and easily able to be driven every day, there is cetainly nothing 'wrong' with it. A buddy/coworker/former team lead ran the same cam and heads + a 6 pack manifold in his challenger, he liked it. But...ol' Pizzino had a bunch more horsepower than you will have, due to his intake manifold/carb choice alone. It was a fun street engine.
Re: Exhaust size [Re: ZIPPY] #2562026
10/10/18 05:06 PM
10/10/18 05:06 PM
But that was 537 HP on Westech's Dyno. laugh2 So closer to 500 hp on an accurate one. Woulda made 600+ on Koffel's.
CHIP
Re: Exhaust size [Re: an8sec70cuda] #2562058
10/10/18 06:07 PM
10/10/18 06:07 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
laugh
Re: Exhaust size [Re: 70charger512] #2562269
10/11/18 01:54 AM
10/11/18 01:54 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Don’t know what that article engine had, but dulcich says to run aluminum heads ootb. Might be a limiting factor in his builds. He actually took a shot at machine shops offering services to clean up new parts.
Seems every head thread shows just a little work can wake up most any head you buy.
I want my fair share
