Gear drives?
#2561091
10/08/18 09:44 PM
10/08/18 09:44 PM
Posts: 1,032 illinois
bigblk66_coronet
illinois
Looking to switch to a gear drive on my 440. Anyone have any luck with this style gear drive? https://www.jegs.com/i/JEGS/555/20361/10002/-1
66 Dodge Coronet 500
440w/727
11:10 30 over 440 w/292 purple shaft,stock Eddy heads,3:23,full exhaust
Best ET. 12.38 @110 in street trim
Re: Gear drives?
[Re: bigblk66_coronet]
#2561096
10/08/18 09:51 PM
10/08/18 09:51 PM
crabman173
crabman173
Why? It is a HP loss on average--do you just want the noise? If you want the whine then hey go for it! It is very popular--they sell tons of them but if you are after best performance it is not the way to go Bear in mind you may have to grind on the block some depending on which unit you get--and if you were planning an in car install that would make it a no go This is all just my opinion--you want the whine--I say do it
Re: Gear drives?
[Re: ]
#2561100
10/08/18 09:56 PM
10/08/18 09:56 PM
bigblk66_coronet
illinois
Well many many many years ago i used to run a noisey one on my camaro and loved it. i have the motor out installing new gaskets and detailing. Figured id check the chain out and if its bad id put a gear drive in it. I used to run the car and it will run 12.0s but pretty much over the racing. Just want to cruise. I see the Milodon style is totally different than this one.
440w/727
Re: Gear drives?
#2561107
10/08/18 10:07 PM
10/08/18 10:07 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
X2.... The gear drive noise is a product of friction. Not what you typically look for in engine parts, I’d worry about the harmonics creating issues in the valvetrain, but that’s just me. If you’re just looking to turn heads as you cruise, that’ll do the job.
Re: Gear drives?
#2561133
10/08/18 10:55 PM
10/08/18 10:55 PM
Posts: 4,457 Washington
madscientist
Washington
If you are going to run a gear drive (I do, even in my SFT street engine) spend the money and buy the fixed idler style like the Milodon.
They don't make noise, they don't cost HP and they don't break cranks. For all I've heard, there is not ONE test I can find that proves any of that when comparing a chain or a belt to a fixed idler gear drive.
Spend the money, buy the Milodon and forget it.
Re: Gear drives?
#2561340
10/09/18 12:02 PM
10/09/18 12:02 PM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I've used a Pete Jackson (that style) before. There's nothing wrong with them. They will work like everything else. Easy to set up. And I guess the 18 year old in me likes the whine.
2011 Drag Pak Challenger
Re: Gear drives?
#2562063
10/10/18 06:19 PM
10/10/18 06:19 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
We put a Pete Jackson in my sons 413 62 300.It was in at least 15 years and nevar a problem.Was still going good when he sold it.He put lots of highway miles and strip trips also.Probally more than most here.Rocky
Chrysler Firepower
Re: Gear drives?
#2562439
10/11/18 01:44 PM
10/11/18 01:44 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Have the same Milodon drive for 25 years.If set up and clearanced properly it's not much whine.The whine on the blower is not that bad inless the belt is very tight.
Re: Gear drives?
#2562830
10/12/18 11:53 AM
10/12/18 11:53 AM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
I agree with mad scientist. I have a milodon gear drive in my 408 stroker. I can't hear the whine over the exhaust.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: Gear drives?
[Re: mopardude318]
#2562861
10/12/18 12:54 PM
10/12/18 12:54 PM
Posts: 4,683 Wichita
GY3
Wichita
Do the Milodon drives fit under a stock cover?
