Page 2 of 3 1 2 3
Re: What Hemi Block part number for at least 572ci potential? [Re: Blakcharger440] #2560611
10/08/18 12:03 AM
10/08/18 12:03 AM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
Looks like a megablock from the 40th week of 2006. Motor Castings foundry.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F113294814297
Re: What Hemi Block part number for at least 572ci potential? [Re: fast68plymouth] #2560758
10/08/18 10:57 AM
10/08/18 10:57 AM
an8sec70cuda Offline
Originally Posted By fast68plymouth
In the current marketplace, for $3-4.5k........ I think you’re going to be looking for a used block.
iagree If you can even find a brand new cast iron block, you'll likely pay $4500+ for it. Then it'll need basic machine work plus work to fix issues if needed.
Your best bet is to find a used block that's already been run and go from there. Good luck.
I'd run an Indy aluminum block before any of the cast iron blocks out there...JMO. For the cost of any of them, I'd go aluminum for the ability to repair just about anything on it later down the road.
The Siamese bore blocks don't have cooling issues.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: What Hemi Block part number for at least 572ci potential? [Re: Blakcharger440] #2560798
10/08/18 12:04 PM
10/08/18 12:04 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Originally Posted By Blakcharger440
Originally Posted By rickseeman
It will have to be a siamese block. You need the 4.500 bore. Order one from Jegs P5160150AC and wait. Hopefully it will eventually get there.
Do you know if the siamese blocks have problems with cooling when driven on the street or fairly long trips?
You won't have a cooling problem. The siamese blocks have been around for a long time.
2011 Drag Pak Challenger
Re: What Hemi Block part number for at least 572ci potential? [Re: Blakcharger440] #2560802
10/08/18 12:10 PM
10/08/18 12:10 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I doubt you’re going to be able to accommodate 572”+ without a Siamese block.
Re: What Hemi Block part number for at least 572ci potential? [Re: ZIPPY] #2560827
10/08/18 12:40 PM
10/08/18 12:40 PM
central il.
second 70 Offline
second 70  Offline
central il.
There's 2 mega blocks on ebay 1 water block and 1 siamese MCF casting both have Mcf casting ground off on top right side. Beware might be rejected blocks my old block is not ground.
Re: What Hemi Block part number for at least 572ci potential? [Re: Blakcharger440] #2560936
10/08/18 03:48 PM
10/08/18 03:48 PM
S.E. Michigan
S.E. Michigan
Yeah that is unusual to see half the foundry mark removed like that, have to wonder if that was deliberate or what happened. Unfortunately Motor Castings was taken over by Dalton awhile back so I don't think we're going to get a straight answer.
Re: What Hemi Block part number for at least 572ci potential? [Re: Blakcharger440] #2560955
10/08/18 04:27 PM
10/08/18 04:27 PM
Fl
Superlead Offline
Superlead  Offline
Fl
I think the partial removal of the Motor Castings foundry mark is the result of removing the wedge motor mounts.
Re: What Hemi Block part number for at least 572ci potential? [Re: Superlead] #2560958
10/08/18 04:30 PM
10/08/18 04:30 PM
S.E. Michigan
S.E. Michigan
Good thought Mike, could be that.
Rich
Re: What Hemi Block part number for at least 572ci potential? [Re: Superlead] #2560978
10/08/18 05:09 PM
10/08/18 05:09 PM
central il.
second 70 Offline
second 70  Offline
central il.
[quote=Superlead]I think the partial removal of the Motor Castings foundry mark is the result of removing the wedge motor mounts.
Could be but if that was the case I would guess the 2 to right of it on 1 block or the 3 to the right of the foundry on the other block would also have been ground down?
Also the one has no lifter bores.
Re: What Hemi Block part number for at least 572ci potential? [Re: Blakcharger440] #2560992
10/08/18 05:44 PM
10/08/18 05:44 PM
So. Burlington, Vt.
So. Burlington, Vt.
Looks to me like the “2” has been kissed by the cutter.
Re: What Hemi Block part number for at least 572ci potential? [Re: Blakcharger440] #2561011
10/08/18 06:24 PM
10/08/18 06:24 PM
Fl
Superlead Offline
Superlead  Offline
Fl
For a few years, Mopar offered some Hemi blocks without lifter bores.
Re: What Hemi Block part number for at least 572ci potential? [Re: Blakcharger440] #2561050
10/08/18 08:06 PM
10/08/18 08:06 PM
S.E. Michigan
S.E. Michigan
Yep. As noticed...the one I linked to on ebay above is without lifter bores + without pushrod holes. Really not for the @home builder LOL. Although there are plenty of shops that could handle it and get it ready.
I'm not sure if I am remembering right but, on another motor castings block that I have seen I don't recall the foundry mark being touched when the wedge mounting "ears" were chopped off. But I also think that one is different because it is a water block so, apples and oranges/maybe foundry mark in a different location(?). I know where it is located and will take a look if I get a chance.
Lots of history and details to learn about these.
Which can either be helpful, or just trivia lol.
Re: What Hemi Block part number for at least 572ci potential? [Re: Blakcharger440] #2561080
10/08/18 09:22 PM
10/08/18 09:22 PM
New York
polyspheric Offline
polyspheric  Offline
New York
and they will send their children to college from that one job.
Curious: why such a specific number?
Boffin Emeritus
Re: What Hemi Block part number for at least 572ci potential? [Re: ZIPPY] #2561082
10/08/18 09:24 PM
10/08/18 09:24 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Definitely helpful as I only seen one block on eBay
Trying to hold out for a wedge block before I go ahead and start the process of building a motor
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: What Hemi Block part number for at least 572ci potential? [Re: polyspheric] #2561141
10/08/18 11:08 PM
10/08/18 11:08 PM
S.E. Michigan
S.E. Michigan
My youngest recently asked "you run Premium (gas) in this car?"
I said "yep."
He said "isn't that kind of expensive?"
I said "well Sam, Sometimes, if you want to dance, you've got to pay the fiddler."
wink
Big laughs from all ensued.
The same seller of the block also has some damaged super stock heads, I can only imagine the fiddler's bill for those! but, it looks like he chased the rainbow pretty darned hard. Maybe it was worth it, or not...it's all relative...
Re: What Hemi Block part number for at least 572ci potential? [Re: ZIPPY] #2561367
10/09/18 12:51 PM
10/09/18 12:51 PM
central il.
second 70 Offline
second 70  Offline
central il.
I agree a lot to learn. I have a hemi water block with wedge mounts. 2468330 M MCF block cast #6K29 top pad is stamped HW1194. Whats confusing is I don't believe you could get a siamese hemi block with wedge mounts so why would they have them? The siamese blocks are a total different casting than a water block. They have Mopar cast on the side where the water block doesn't.
Re: What Hemi Block part number for at least 572ci potential? [Re: second 70] #2561563
10/09/18 07:41 PM
10/09/18 07:41 PM
S.E. Michigan
S.E. Michigan
Wedge and Hemi use a common casting. All of them came out of the mold with wedge and hemi mounts cast in, and then the wedge mounts were chopped off for dedicated hemi applications + the hemi motor mount pad was drilled for hemi mounts + the other differences are also machined in.
This is true of all 3...the old water block, the old siamese megablock, and the newer so-called World block. They were all cast with both types of mounts, then final machining took care of the rest.
Likewise, the wedge versions will have some of the unique hemi motor mount pad but it won't be finish drilled and tapped (unless somebody smoked their lunch that day). World Wedge had a portion of the hemi mount chopped off on one side (if I remember correctly the left side) in machining but hemi artifacts are clearly visible.
Re: What Hemi Block part number for at least 572ci potential? [Re: Blakcharger440] #2561567
10/09/18 07:52 PM
10/09/18 07:52 PM
S.E. Michigan
S.E. Michigan
Oh, forgot... 6K29 is a Cummins Recon machining center code.
Wish I knew what it means, but I have no idea. During my time at mp the Cummins rep (although a nice fellow) would never directly decode those numbers for me, and the engineer I had to go through (although also a nice fellow) treated those codes as if they were proprietary information.
My stance: When a vendor is coding YOUR product, you have every right to it. So, where's the magic decoder ring?
His stance: that's their information, why should I care, all I really care about is the part number.
Try as I might to learn the logic behind the codes, it wasn't ever made available.
Re: What Hemi Block part number for at least 572ci potential? [Re: ZIPPY] #2561876
10/10/18 12:23 PM
10/10/18 12:23 PM
central il.
second 70 Offline
second 70  Offline
central il.
Zippy thanks for the info. I guess all that's important is it's been a good block for over 10 years without any problems no matter what the secret code means. Lol Mike
Re: What Hemi Block part number for at least 572ci potential? [Re: Blakcharger440] #2561899
10/10/18 01:07 PM
10/10/18 01:07 PM
S.E. Michigan
S.E. Michigan
You bet, Mike. There are plenty out there who know more than I do, and when they speak up (however rarely) I'm all ears. It's an old product with history, that went through alot of changes, I just try to share what I know in hopes it makes a difference.
Page 2 of 3 1 2 3
