3.6 pentastar V6 questions #2559220
10/05/18 02:15 AM
10/05/18 02:15 AM
Alberta
N
NEVjr Offline OP
NEVjr  Offline OP
N
Alberta
working on a pentastar v6 swap into my valiant, got a few questions about its internal workings
-If the cam phasor spool valve isnt pulsed after start up, the cams run in the lock pin position, or will they drift?
-How does the oil pump switch from high to low? RPM? engine load?
-do these use throttle delays or limits to prevent detonation?
any other info you can give me would be much appreciated
Re: 3.6 pentastar V6 questions [Re: NEVjr] #2559398
10/05/18 01:50 PM
10/05/18 01:50 PM
moparx Offline
moparx  Offline
i have no help whatsoever for you, but this sounds like an interesting swap ! i would like to hear more about this. trans used, rear gear, floor pan and engine bay tin modifications, etc. here's a BTTT for ya.
beer
Re: 3.6 pentastar V6 questions [Re: NEVjr] #2559544
10/05/18 05:27 PM
10/05/18 05:27 PM
Alberta
N
NEVjr Offline OP
NEVjr  Offline OP
N
Alberta
Thanks, I will keep this updated. The car is a 62 valiant, I plan on using the hemidenny front suspension/k member, I want to run the 8 speed automatic but I will most likley use the 904 in the car atleast to begin with. Rear end is an 8 1/4 from an unknown A-body. This motor should make 300 HP and save a couple hundred pounds over a small block.
Re: 3.6 pentastar V6 questions [Re: NEVjr] #2559557
10/05/18 05:46 PM
10/05/18 05:46 PM
IL
furious70 Offline
furious70  Offline
IL
The TF8 is huge. I measured the one in my 2012 Charger, 30" from bell to rear mount and it's 9" tall at the mount. It doesn't really taper into the tail.
I don't know if the cams work like the hemi or not, but those guys physically block the gear to lock it in. There's a thread near the top of the G3 forum right now.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: 3.6 pentastar V6 questions [Re: NEVjr] #2559685
10/05/18 10:55 PM
10/05/18 10:55 PM
Missouri
randavis Offline
randavis  Offline
Missouri
I think that the oil pressure is switched from high to low when the engine temp reaches a certain point.
I have a 2013 Ram with that engine. I can watch the oil pressure and temperature on my dash screen.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI.
New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
Re: 3.6 pentastar V6 questions [Re: randavis] #2559695
10/05/18 11:15 PM
10/05/18 11:15 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
I've wondered how the 3.6 would do in an early A-body Valiant. work
So a 3.6 has a sb bellhousing pattern? smile
My first car was a '65 and if I find another one, that would be something to consider.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: 3.6 pentastar V6 questions [Re: NEVjr] #2559881
10/06/18 01:50 PM
10/06/18 01:50 PM
Alberta
N
NEVjr Offline OP
NEVjr  Offline OP
N
Alberta
i dont know what bellhousing pattern it has, I have a slant 6 trans and I was just going to make an adapter plate. strangely enough, the 727 was originally called the torqueflite 8 for the 8 cylinder cars it was put in, while the 904 was the torqueflite 6.
I can afford to move the engine forward a fair bit to fit the trans and still have good weight distribution
I think it works similar to the hemi for cam timing, but I dont want to leave the ~50 hp on the table by just welding it up. I want to have it running before I start down the cam tuning rabbit hole. I figure it must be better than the old slant even with poor timing.
@randavis can you tell what temperature? what happens when you rev it while its cold?
another question, anyone know what causes the intake runner valve to switch? this should be rpm dependant i would think
Re: 3.6 pentastar V6 questions [Re: NEVjr] #2559973
10/06/18 05:25 PM
10/06/18 05:25 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I think your better off running a trans intended for that engine either from a 2wd ram or a charger/challenger/300...
Re: 3.6 pentastar V6 questions [Re: NEVjr] #2559976
10/06/18 05:27 PM
10/06/18 05:27 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I guess I should explain my reasoning a tad, there are more gear ratios, a converter is already matched to it so no need to play with converters trying to find one that works just right plus the 3.6 is drive by wire and the 904 needs a throttle cable unless you go full manual.
Re: 3.6 pentastar V6 questions [Re: NEVjr] #2560136
10/06/18 10:48 PM
10/06/18 10:48 PM
Alberta
N
NEVjr Offline OP
NEVjr  Offline OP
N
Alberta
i was hoping to have a mechanical throttle body, unless fly by wire is required to prevent knock. this would allow the 904 kick down to work. eventually I would have a new 8 speed automatic, but setting up a transmission controller is a whole different bag of cats. I would need to fab up an electric button setup for the push button shifter (which i still want to feel like a typewriter) and run that as well. no sense putting in twice the effort to learn it is too much for me to get done.
Re: 3.6 pentastar V6 questions [Re: NEVjr] #2560140
10/06/18 10:49 PM
10/06/18 10:49 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Just put a stick behind it and not worry about kickdonws or trans controllers.
Don't be the exception.
Re: 3.6 pentastar V6 questions [Re: NEVjr] #2560221
10/07/18 02:21 AM
10/07/18 02:21 AM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
Going to follow this myself. I'd love to put a Pentastar 3.6 in my 97 Dakota
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: 3.6 pentastar V6 questions [Re: Supercuda] #2560357
10/07/18 02:23 PM
10/07/18 02:23 PM
Alberta
N
NEVjr Offline OP
NEVjr  Offline OP
N
Alberta
the 2 questions everyone asks: what year is it? does it have the pushbutton shifter?
its gotta have the pushbutton
Anyone know what RPM the variable runner length valve changes?
Re: 3.6 pentastar V6 questions [Re: NEVjr] #2560472
10/07/18 07:29 PM
10/07/18 07:29 PM
central IL
myduster360 Offline
myduster360  Offline
central IL
Not driving yet but at least it starts
3.6L + T5 5speed
https://www.youtube.com/watch?v=QoAqmv0e5zg&feature=youtu.be
1972 Swinger 3.6L Pentastar
Diablo CMR tuner
Re: 3.6 pentastar V6 questions [Re: NEVjr] #2560483
10/07/18 07:48 PM
10/07/18 07:48 PM
central IL
myduster360 Offline
myduster360  Offline
central IL
Cams run to the lock pin after start up. Not sure how much can be done about changing it at idle. I haven't fabbed up any "manifolds" for my 3.6l so its loud as hell for the 1st 30s and then the cam timing makes an obvious change and the decibel levels slowly drop by 2/3.
I haven't seen any setting the PCM as far as Oil pressure control in HpTuners or Diablo, so unsure about the when but I'd guess RPM and load.
Cam timing is used for psuedo-EGR like affect to combat detonation.
I don't see any Throttle modifiers associated with Knock.
I'm not aware of any Pentastar with a variable intake. I know my Jeep/Ram intake and my Caravan intake do not. im not sure of the 2016 and newer PSU engines
NO the 3.6L doesn't share the bellhousing with much anything but maybe a 3.5L
Diablo CMR tuner
Re: 3.6 pentastar V6 questions [Re: myduster360] #2560522
10/07/18 09:21 PM
10/07/18 09:21 PM
Buford, GA
Buford, GA
Sweet! up Do you have a build page somewhere? If not, I have a ton of questions for you. wink
Tim
'71 Charger 383/727
Re: 3.6 pentastar V6 questions [Re: I_bleed_MOPAR] #2560613
10/08/18 12:06 AM
10/08/18 12:06 AM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Can’t help you any with installation but it’s a great engine. I smoke people all the time in our 2015 Town & Country hehe! Surprising power for this big old heavy van.
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: 3.6 pentastar V6 questions [Re: myduster360] #2560681
10/08/18 03:20 AM
10/08/18 03:20 AM
Alberta
N
NEVjr Offline OP
NEVjr  Offline OP
N
Alberta
atleast as of 2018 they all have an intake runner length valve
what are you using for an ECU? it sounds like you are able to read from it?
fly by wire throttle?
what donor vehicle? what all came from the donor vehicle?
where is the O2 sensor? does your ECU require the after cat sensor?
any other trap, pitfalls, or dragons to be aware of?
Re: 3.6 pentastar V6 questions [Re: NEVjr] #2560846
10/08/18 01:02 PM
10/08/18 01:02 PM
moparx Offline
moparx  Offline
that fits pretty good in there ! what transmission is it hooked to ? the 904 with adapter, right ? if so, do you have any pics of it ? [the adapter]
beer
Re: 3.6 pentastar V6 questions [Re: I_bleed_MOPAR] #2560851
10/08/18 01:09 PM
10/08/18 01:09 PM
central IL
myduster360 Offline
myduster360  Offline
central IL
Tim
Build thread. TONS of 3.6L Swap info
https://www.forabodiesonly.com/mopar/threads/72-dart-swinger-3-6l-pentastar-t5.361683/
Diablo CMR tuner
