Re: What Hemi Block part number for at least 572ci potential?
[Re: Blakcharger440]
#2558405
10/03/18 04:47 PM
10/03/18 04:47 PM
fast68plymouth
So. Burlington, Vt.
Let us know what the expected delivery date is after you order it.
[Re: gsmopar]
#2558420
10/03/18 04:59 PM
10/03/18 04:59 PM
fast68plymouth
So. Burlington, Vt.
Your options are "The Block," Indy, and KB. Go through one of the builders that sponsors this board as all of the above options are going to require machining. Good Luck! And more than likely, a fair amount of lead time.
#2558519
10/03/18 06:57 PM
10/03/18 06:57 PM
Posts: 2,678 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
It will have to be a siamese block. You need the 4.500 bore. Order one from Jegs P5160150AC and wait. Hopefully it will eventually get there.
2011 Drag Pak Challenger
[Re: rickseeman]
#2558856
10/04/18 12:33 PM
10/04/18 12:33 PM
Posts: 1,713 central il.
second 70
central il.
Looking at Jeg's it looks like that block is no where to be found listed but lost in space. but you might be able to get P5160151AC but it's a 4.240 and max bore is .030 over. But you can stroke it to 4.5 and get your 572.
Sorry I screwed up the decimal point max bore is 4.56
[Re: second 70]
#2558865
10/04/18 12:49 PM
10/04/18 12:49 PM
Posts: 1,543 USA
hudsonhornet7x
USA
Looking at Jeg's it looks like that block is no where to be found listed but lost in space. but you might be able to get P5160151AC but it's a 4.240 and max bore is .030 over. But you can stroke it to 4.5 and get your 572. Where did you see that .030 is max bore for that block?
[Re: hudsonhornet7x]
#2558870
10/04/18 01:11 PM
10/04/18 01:11 PM
second 70
central il.
Looking at Jeg's it looks like that block is no where to be found listed but lost in space. but you might be able to get P5160151AC but it's a 4.240 and max bore is .030 over. But you can stroke it to 4.5 and get your 572. Where did you see that .030 is max bore for that block? My bad I had decimal in wrong place. Click on Overview 4.560 max bore good for 4.5 stroke for 588ci.Can be machined for another .250 stroke for a total of 620ci. Mike
#2558973
10/04/18 04:55 PM
10/04/18 04:55 PM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
I'd be calling Todd at Marsh Performance to enquire about a KB block. If the timeline for getting a KB isn't to your liking, ask about an Indy block.
[Re: second 70]
#2559014
10/04/18 07:04 PM
10/04/18 07:04 PM
Posts: 17,914 S.E. Michigan
ZIPPY
S.E. Michigan
Yes, that is the corporate "safe" recommendation there as it's always been for this generation of casting. 4.600+ has been done in the field post sonic test, at least I've seen it done a few times.
Rich H.
Esse Quam Videri
#2559283
10/05/18 09:40 AM
10/05/18 09:40 AM
Posts: 4,585 Motor City
6PKRTSE
Motor City
Mine is at 4.503" currently and still has plenty of meat left.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: an8sec70cuda]
#2559322
10/05/18 11:29 AM
10/05/18 11:29 AM
Posts: 1,581 N/E, Michigan
RATTRAP
N/E, Michigan
I'd be calling Todd at Marsh Performance to enquire about a KB block. If the timeline for getting a KB isn't to your liking, ask about an Indy block. I Agree 100%
[Re: an8sec70cuda]
#2559466
10/05/18 03:24 PM
10/05/18 03:24 PM
Posts: 2,405 Wichita,KS
Blakcharger440
Wichita,KS
I'd be calling Todd at Marsh Performance to enquire about a KB block. If the timeline for getting a KB isn't to your liking, ask about an Indy block. I am not wanting to pay 6K for a block. I am wanting to keep my block purchase at most 3K to 4.5K. I have also read that the Indy blocks are not very good and always need tons of work.
#2559473
10/05/18 03:34 PM
10/05/18 03:34 PM
fast68plymouth
So. Burlington, Vt.
In the current marketplace, for $3-4.5k........ I think you’re going to be looking for a used block.
[Re: fast68plymouth]
#2559591
10/05/18 07:06 PM
10/05/18 07:06 PM
RATTRAP
N/E, Michigan
In the current marketplace, for $3-4.5k........ I think you’re going to be looking for a used block. Yup! And maybe it will come with a window to look thru, So you can see all your moving parts. LOL
#2559628
10/05/18 08:38 PM
10/05/18 08:38 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
I'd be calling Todd at Marsh Performance to enquire about a KB block. If the timeline for getting a KB isn't to your liking, ask about an Indy block. I am not wanting to pay 6K for a block. I am wanting to keep my block purchase at most 3K to 4.5K. I have also read that the Indy blocks are not very good and always need tons of work. Look like you are going Chevy then , I guess ![stirthepot stirthepot](/ubbthreads/images/graemlins/custom/stirthepot.gif) Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
#2559704
10/05/18 11:44 PM
10/05/18 11:44 PM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
I'd be calling Todd at Marsh Performance to enquire about a KB block. If the timeline for getting a KB isn't to your liking, ask about an Indy block. I am not wanting to pay 6K for a block. I am wanting to keep my block purchase at most 3K to 4.5K. I have also read that the Indy blocks are not very good and always need tons of work. I thought the KB block was 7K with the dedicated head studs adding another 1000+ to the total. Not counting whatever else is required in additional machine work.
[Re: rickseeman]
#2560125
10/06/18 10:39 PM
10/06/18 10:39 PM
Blakcharger440
Wichita,KS
It will have to be a siamese block. You need the 4.500 bore. Order one from Jegs P5160150AC and wait. Hopefully it will eventually get there. Do you know if the siamese blocks have problems with cooling when driven on the street or fairly long trips?
