Page 1 of 3 1 2 3
What Hemi Block part number for at least 572ci potential? #2558388
10/03/18 04:30 PM
10/03/18 04:30 PM
Wichita,KS
Blakcharger440 Offline OP
Wichita,KS
I am wanting to order a Hemi block this week for a engine that can be taken to 572 cubic inch at the least.
Would it be best to get something that has finished piston bores and finished lifter bores?
Would it be best to get a siamese block? I would still want to drive the car on the street and strip.
Anybody have an idea of what part number I will need?
Re: What Hemi Block part number for at least 572ci potential? [Re: Blakcharger440] #2558405
10/03/18 04:47 PM
10/03/18 04:47 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Let us know what the expected delivery date is after you order it.
Re: What Hemi Block part number for at least 572ci potential? [Re: Blakcharger440] #2558412
10/03/18 04:49 PM
10/03/18 04:49 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Your options are "The Block," Indy, and KB. Go through one of the builders that sponsors this board as all of the above options are going to require machining. Good Luck!
Re: What Hemi Block part number for at least 572ci potential? [Re: gsmopar] #2558420
10/03/18 04:59 PM
10/03/18 04:59 PM
So. Burlington, Vt.
So. Burlington, Vt.
And more than likely, a fair amount of lead time.
Re: What Hemi Block part number for at least 572ci potential? [Re: Blakcharger440] #2558470
10/03/18 05:50 PM
10/03/18 05:50 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Here are the old Mopar numbers.
Mind you these are made from a special material: Unobtainium
P5155072AB 4.25 finish
P5153862AB 4.500 finish
P5153942AB 4.24 rough
Although there have been reports of J-- machine in Michigan shipping a handful recently, I have reason to believe these were very old Dalton castings that have been sitting around...Dalton hasn't made any in years....
Recent posts indicate new part numbers, which is how it is supposed to be done when there are big changes (supply chain being one).
the P516-AC numbers are going to be the most recent.
Re: What Hemi Block part number for at least 572ci potential? [Re: Blakcharger440] #2558519
10/03/18 06:57 PM
10/03/18 06:57 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
It will have to be a siamese block. You need the 4.500 bore. Order one from Jegs P5160150AC and wait. Hopefully it will eventually get there.
2011 Drag Pak Challenger
Re: What Hemi Block part number for at least 572ci potential? [Re: rickseeman] #2558856
10/04/18 12:33 PM
10/04/18 12:33 PM
central il.
second 70 Offline
second 70  Offline
central il.
Looking at Jeg's it looks like that block is no where to be found listed but lost in space. but you might be able to get P5160151AC but it's a 4.240 and max bore is .030 over. But you can stroke it to 4.5 and get your 572.
Sorry I screwed up the decimal point max bore is 4.56
Re: What Hemi Block part number for at least 572ci potential? [Re: second 70] #2558865
10/04/18 12:49 PM
10/04/18 12:49 PM
USA
hudsonhornet7x Offline
USA
Where did you see that .030 is max bore for that block?
Re: What Hemi Block part number for at least 572ci potential? [Re: hudsonhornet7x] #2558870
10/04/18 01:11 PM
10/04/18 01:11 PM
central il.
second 70 Offline
second 70  Offline
central il.
My bad I had decimal in wrong place.
Click on Overview 4.560 max bore good for 4.5 stroke for 588ci.Can be machined for another .250 stroke for a total of 620ci.
Mike
Re: What Hemi Block part number for at least 572ci potential? [Re: second 70] #2558938
10/04/18 03:47 PM
10/04/18 03:47 PM
Wichita,KS
Wichita,KS
Awesome I will call them about P5160151AC. I hope that is finish piston bores and lifter bores.
Re: What Hemi Block part number for at least 572ci potential? [Re: Blakcharger440] #2558973
10/04/18 04:55 PM
10/04/18 04:55 PM
an8sec70cuda Offline
I'd be calling Todd at Marsh Performance to enquire about a KB block. If the timeline for getting a KB isn't to your liking, ask about an Indy block.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: What Hemi Block part number for at least 572ci potential? [Re: second 70] #2559014
10/04/18 07:04 PM
10/04/18 07:04 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Yes, that is the corporate "safe" recommendation there as it's always been for this generation of casting.
4.600+ has been done in the field post sonic test, at least I've seen it done a few times.
Rich H.
Esse Quam Videri
Re: What Hemi Block part number for at least 572ci potential? [Re: Blakcharger440] #2559283
10/05/18 09:40 AM
10/05/18 09:40 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Mine is at 4.503" currently and still has plenty of meat left.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: What Hemi Block part number for at least 572ci potential? [Re: an8sec70cuda] #2559322
10/05/18 11:29 AM
10/05/18 11:29 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
I Agree 100%
Re: What Hemi Block part number for at least 572ci potential? [Re: an8sec70cuda] #2559466
10/05/18 03:24 PM
10/05/18 03:24 PM
Wichita,KS
Wichita,KS
I am not wanting to pay 6K for a block. I am wanting to keep my block purchase at most 3K to 4.5K.
I have also read that the Indy blocks are not very good and always need tons of work.
Re: What Hemi Block part number for at least 572ci potential? [Re: Blakcharger440] #2559473
10/05/18 03:34 PM
10/05/18 03:34 PM
So. Burlington, Vt.
So. Burlington, Vt.
In the current marketplace, for $3-4.5k........ I think you’re going to be looking for a used block.
Re: What Hemi Block part number for at least 572ci potential? [Re: fast68plymouth] #2559591
10/05/18 07:06 PM
10/05/18 07:06 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Yup! And maybe it will come with a window to look thru, So you can see all your moving parts. LOL
Re: What Hemi Block part number for at least 572ci potential? [Re: Blakcharger440] #2559628
10/05/18 08:38 PM
10/05/18 08:38 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Look like you are going Chevy then , I guess
whistling stirthepot
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: What Hemi Block part number for at least 572ci potential? [Re: Blakcharger440] #2559704
10/05/18 11:44 PM
10/05/18 11:44 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
I thought the KB block was 7K with the dedicated head studs adding another 1000+ to the total. Not counting whatever else is required in additional machine work.
Re: What Hemi Block part number for at least 572ci potential? [Re: rickseeman] #2560125
10/06/18 10:39 PM
10/06/18 10:39 PM
Wichita,KS
Wichita,KS
Do you know if the siamese blocks have problems with cooling when driven on the street or fairly long trips?
Page 1 of 3 1 2 3
