Re: Big block A-body k-frame question: which would you do?
[Re: 1970RT]
#255958
03/16/09 06:52 PM
03/16/09 06:52 PM
Posts: 18,686 Fresno, CA
Jim_Lusk
Fresno, CA
I would not do either one. Go to www.bigblockdart.com and look at the tech pages for building youro own DC k-member. You will have to mod the spool K for the Schumacher mounts anyway. All you will need to buy is a pair of 74-78 pass car big block mounts (probably $50).
[Re: 1970RT]
#255960
03/16/09 10:47 PM
03/16/09 10:47 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
If it were me,I'd use a motor plate and a spacer on the crank pulley and be done with it.
[Re: cogen80]
#255961
03/17/09 12:03 AM
03/17/09 12:03 AM
Jim_Lusk
Fresno, CA
i would just use the schumacher mounts and be done with it. can save some money making a DC k-frame i guess but time is money also. flip a coin i guess.
By the time you get done cutting the driver side saddle of and driling a new hole, thus making installation of the engine more difficult since it will not just drop into the slot anymore you haven't saved yourself any time.....
