which old school cam would you use?
#255936
03/16/09 06:17 PM
03/16/09 06:17 PM
Posts: 862 Iowa State fan
kilroy
Iowa State fan
I rebuilt my 440 over the winter to a 10.5 to 1 motor, and installed eddy rpm heads. I also converted to a 4 speed. 73 charger. Question is I have a .509 mp cam that was out of my previous build or I have a solid lifter .551/296 mp cam. I have all the goods to run either one. I think Im going to install the .551/296 cam unless some one doesnt like it. Anyone like or dislike?
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: which old school cam would you use?
[Re: kilroy]
#255938
03/16/09 07:17 PM
03/16/09 07:17 PM
Posts: 1,263 Southwestern Ontario Canada
racealittle
The .557 is something like a .509 on steroids. I like that cam.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
[Re: racealittle]
#255939
03/16/09 07:19 PM
03/16/09 07:19 PM
Mopar cams certainly are OLD school,there are much better grinds out there now from Lunati,comp ect....
[Re: Rapid340]
#255940
03/16/09 07:22 PM
03/16/09 07:22 PM
Posts: 5,620 long island NY
Ari440
long island NY
my 72 road runner
446 ci , trw 11.1 comp , 557 solid cam , stage six heads , M1 and 750 carb
850 carb and 1.6 rockers to upgrade this combo
1.39 9.85 - 137 mph
[Re: kilroy]
#255942
03/16/09 07:49 PM
03/16/09 07:49 PM
Posts: 5,080 organ
maximum entropy
organ
i did a back to back with those two. first the 557. it ran good. 496 in an a body. then the 509, both with 1.6 rockers. holy smoke! what a difference. the 509 is lopier, and snappier. both were installed according to the mothership's recommendations. the 557 at 108, the 509 straight up. oh, btw, it was a tenth faster, too. and don't let anybody try to dissuade you from using them "because they're old". they still kick [Edited by Moparts - Keep it clean]! and they always will! they don't slow down with age, unlike us.
[Re: kilroy]
#255943
03/16/09 08:22 PM
03/16/09 08:22 PM
Posts: 16,932 NC
440Jim
NC
I like a solid lifter cam for better idle and more rpm capability (if everything else allows it).
The MP 296/0.557" solid lifter cam isn't really very big. Although it will measure about 255-257 degrees at 0.050"; when you account for lash it is in the low 240's for comparison to a hydraulic cam. Since the 292/0.509" hydraulic is about 248 degrees at 0.050", it will act like it has more duration than the 0.557" cam. But typically a hydraulic starts to loose power over 6000 rpm without special attention, and a solid with the correct springs will go to that easy. So for better idle and over 6000 rpm, I vote for the 0.557", especially on 440 CID or less. (a larger displacement will like more duration and will mellow the idle, and like less rpm.
I have the 0.557" in my street 'Cuda and love it. Nice street manners, good power, etc. That motor is a 0.030" over 440 with 10.7 CR, street dominator intake (single plane), 850 carb, 1-7/8 headers.
Post deleted by Defbob
[Re: 440Jim]
#255944
03/16/09 08:46 PM
03/16/09 08:46 PM
#255945
03/16/09 08:58 PM
03/16/09 08:58 PM
Posts: 10,018 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I would run the .557, and experiment with tighter lash settings. It is almost assured it will run faster with tight settings, as your combo will be undercammed. I once ran a .590 with .020 intake, .012 ex settings, (big motor!) and it liked it, your results may vary. I just spotted your eddy heads in the post. Be carefull to not get too tight when cold, might cause problems for you. Settings may open up .006 or so as motor warms.
[Re: kilroy]
#255946
03/16/09 09:09 PM
03/16/09 09:09 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Both are great cams IMO, and both should be about the same in power. The MP .557 with its wider LS will be more street freindly IMO. You cant go wrong with either one IMO with your combo. Use the MP .557 and ship the .MP .509 to me, I need a spare! mike
73 Sport 440, 509 cam w/Eddys 3.91 and 28.1"/27.3 tire. Et. 60 ft. 1.435, 1/8th. 6.61 @ 101.80 mph. 1/4. 10.472 / 127.78 mph. 2950# race/with me,and pump gas.
[Re: gsmopar]
#255948
03/16/09 10:47 PM
03/16/09 10:47 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
My 63 is a mild 440 with the MP .557 cam. It has 10.0 comp and I use the iron 906 heads. I like it because it actually has a nice idle in my car and is not all that nasty of an idle. So it is easy to live with in my street car and still make decent power in a mild bigblock. I agree it sounds milder then the .509 does but I like it because it is a solid and it pulls to 6500 with no trouble. I only shift at 6200 in my 63 but my son pushes his Eddy headed 400 to 6700 in his Dart with the .557. I like it even if it is an old grind. Ron
[Re: Valiant_Showoff]
#255953
03/17/09 07:14 PM
03/17/09 07:14 PM
kilroy
Iowa State fan
Ok, well the two cams are all I have right now so I will run the .557 but if I had any of the other purple shafts which would (or would they?) help this type of engine combo. (I know this is very subjective but give it a whirl). Also, Im running 17/8 headers w/ 3" exhaust, but has anyone tried this cam w/ hi-po manifolds?
[Re: dodgemike]
#255955
03/17/09 07:32 PM
03/17/09 07:32 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
.557, ProSport has seen my junk run.Went low 11,70's on a flatop 360 w/ Eddys. Put the .590 in last year. Need something better now than wore out leaf springs, LOL. If my et matched mt mph, it should run at least 11.50.
Mike how did the 590 compare ET wise to your 557?
