Re: E-Body Rear sway bar bushing replacement- factory bar
[Re: challenger70]
#2559578
10/05/18 06:39 PM
10/05/18 06:39 PM
Posts: 350 Mequon, WI
gzig5
Mequon, WI
Roseville Moparts has the end link bushings for the rear. Only place I've found the rears and good folks to work with. http://www.rosevillemoparts.com/product_...roducts_id/8483If you contact Dave he may be able to help with the main ones. Need to convince a vendor to release a serviceable bracket and bushings for the frame mount. I'm going to modify mine or start from scratch. Probably weld a flat head bolt in on the bracket to act as a stud. Other option is to go with a bigger aftermarket bar but I don't think there is much wrong with the stock size and I'm too cheap to throw away good parts.
