Re: Starting line ratios for 1/8 mile
[Re: RustyM]
#2559599
10/05/18 07:17 PM
10/05/18 07:17 PM
Posts: 575 Texas
RustyM
Texas
Agreed Doug. Weather is really a big deal here in Texas and i hope to get a better weather station over the off season. I also agree on getting to below the index- properly. This owner wanted to be at 6.41 and so we set out to help him get there. we got as much data from last year as possible, did as Dewayne suggested and did some dyno work , found where the engine lived, found converter issues- just did a lot of basic problem solving mechanically and then with yalls help we tackled chassis. Once we got car safe/consistently repeating we knew we were gathering data to let us get where he wanted to be. He was pretty happy when we hit 1.41 60ft and the first 6.48 n/a ( if i had time for two more passes, would have gotten .45-46 im sure). So, not far to go, been a step at a time, get him under index and still predictably consistent and, well, thats a win/win deal to me.
I'm just hoping i did my work/math correctly and the .88 gears help as anticipated and don't hurt him instead.
[Re: RustyM]
#2559626
10/05/18 08:33 PM
10/05/18 08:33 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Rusty if you are going to make a big in change rear end ratio remind your driver to be on that 1-2 shift it is going to come at him faster.
"Just a Bracket car dressed up like a streetcar"
[Re: RustyM]
#2559638
10/05/18 08:52 PM
10/05/18 08:52 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I'm curious....... how did 6.41 become the target?
[Re: fast68plymouth]
#2559646
10/05/18 09:21 PM
10/05/18 09:21 PM
Posts: 575 Texas
RustyM
Texas
That was one of his goal with stroking it, then all kinds of problems plagued him . Once car was sorted, landed between two index's and would rather go forward than back. He doesn't mind using a little weight in the car but doesn't want to be throwing 200-300 lbs in and out .
Heads may come to you after the season -1's
Honestly, could have gotten him closer last weekend we just ran out of time , had to dial back and just drive the car.
Car is just super lazy in high gear with the amount of track left, only builds a few hundred rpm back after the shift, never gets up on upper power band. rpm graph just slightly above flat and hitting stripe at 55-5700, needs to be 6100 -6400 min.
I could be wrong but, if I can trim a little more off 60/330 and have him up on motor before stripe- car should finish well.
Tell me if you think im wrong. My concerns are: sticking the tire now. Using up all the shock . we are on 130# springs ( ladder bar car) , he had 200, car didnt like it, we tried 150# and it was better but still had min. weight transfer, used very little shock so, picking up front ties and just dropping them, went to 130# , using shocks much better, carrying fronts a little.
So, my thought, based on the math and what the car has been doing: But some more gear in it, if we can stick the tire , use all the shock, have a little more control on shock rebound , tire speed quicker, ups the stall 200, get in second and third quicker and be up on the head flow across the stripe.
Am i wrong?
[Re: RustyM]
#2559662
10/05/18 09:50 PM
10/05/18 09:50 PM
Thumperdart
State of confusion
Am i wrong? Let's put a Dommy on that puppy...........
[Re: RustyM]
#2560109
10/06/18 10:02 PM
10/06/18 10:02 PM
Posts: 10,037 Frostbitefalls MN (Rocky&Bullw...
gregsdart
How much drop in rpm on the shifts? Sounds like you may need more stall. My converter is probably too tight yet, at 6200 after the shift of 7450 on the 1/2 , and 7350 on the 2/3 shift. My peak hp is 6900, peak torque about 5100. I go through the traps at 7400 in the 1/4.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: RustyM]
#2560752
10/08/18 10:47 AM
10/08/18 10:47 AM
Posts: 13,417 Marion, South Carolina [><]
an8sec70cuda
IMO, the combo laid out in the original thread should not have any trouble hooking w/ whatever SLR you throw in it.
[Re: rickseeman]
#2560910
10/08/18 03:09 PM
10/08/18 03:09 PM
Posts: 43,368 Bend,OR USA
Cab_Burge
Who wrote this book and how much DRAG racing have they done?
[Re: RustyM]
#2560969
10/08/18 04:43 PM
10/08/18 04:43 PM
Posts: 4,213 New York
polyspheric
New York
Never mind, it's a good book
Boffin Emeritus
[Re: Cab_Burge]
#2561010
10/08/18 06:23 PM
10/08/18 06:23 PM
Posts: 2,692 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Who wrote this book and how much DRAG racing have they done? I think his name is Dick Miller. He has raced a long time and it is a good book.
2011 Drag Pak Challenger
[Re: RustyM]
#2561147
10/08/18 11:15 PM
10/08/18 11:15 PM
Posts: 637 Sao Paulo, Brazil
dart_73_br
Sao Paulo, Brazil
The book says it´s the maximum SLR. My car has a 2 points higher SLR than maximum accordinly to the book and my tires are spinning too much. Does it means if I decrease the SLR it would hook better and and improve 60"?
1973 Brasilian Dart E100, boosted 390"
