408 SB or 406 BB #2558605
10/03/18 10:17 PM
10/03/18 10:17 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Easy build, 408 360 stroker or .030 400 BB. Equally prepped Eddy heads, 850 carb and bracket FT cam- 550 generally I/E. What combo gives me best HP, TQ and longevity? 3200 lbs or less body. Thanks
Re: 408 SB or 406 BB [Re: A/MP] #2558639
10/03/18 10:45 PM
10/03/18 10:45 PM
Washington
madscientist Offline
Washington
Bigger bore is more power.
It's that's simple.
Re: 408 SB or 406 BB [Re: A/MP] #2558642
10/03/18 10:53 PM
10/03/18 10:53 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The BB has crappy valve placement so it can not take advantage of the big bore like it should, it also weighs #100 more plus asuming an auto trans you have to run the 727 instead of the 904 you can run with a 408 for more weight savings less drag and better 1st gear ratio option and is harder to do plugs and such, I would go SB 408.
Re: 408 SB or 406 BB [Re: A/MP] #2558649
10/03/18 11:01 PM
10/03/18 11:01 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Small block all day long. Wouldn't fool with a big block under 500". As mentioned, extra weight, less desirable trans choices.
Re: 408 SB or 406 BB [Re: A/MP] #2558661
10/03/18 11:37 PM
10/03/18 11:37 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
A small block will be much lighter a 904 transmission will be lighter as well not to mention a lot easier to turn.. a small block with a 4in arm makes tons of torque.... like4like my money would be on the small block with a 4in arm drumhit
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: 408 SB or 406 BB [Re: A/MP] #2558669
10/03/18 11:53 PM
10/03/18 11:53 PM
gregsdart Offline
gregsdart  Offline
It might come down to what you have to start with. I haven't built one yet, but here is a combo i think would work well, and cheap, too!
One option is a 400 block, 4.375 bore, offset grind a 383 crank to 3.54 stroke, use 7.10 bb chev h beam rods, shelf stock 1.12 compression height pistons for 426 cheap cubes. Add a .590 MP cam, 2 inch x 40 inch headers. Should make 575 to 600 hp, cheaply.
Re: 408 SB or 406 BB [Re: gregsdart] #2558687
10/04/18 12:26 AM
10/04/18 12:26 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
If these posts would start out saying how quick you would like to go you would get better info. At 3000 pounds if you are happy running high 9's or slower on a budget small block. Low 9's or quicker big block. Small blocks are so much easier to work on for clearance reasons.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 408 SB or 406 BB [Re: A/MP] #2558691
10/04/18 12:33 AM
10/04/18 12:33 AM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
10.0 in the heat coast summer, so 9.50-9.7.
Re: 408 SB or 406 BB [Re: A/MP] #2558706
10/04/18 01:05 AM
10/04/18 01:05 AM
PA.
"Little"John
"Little"John
PA.
3200? Weight or less
Fuel?
Track average adjusted alt? Info available online
Street and strip or strip only?
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: 408 SB or 406 BB [Re: pittsburghracer] #2558720
10/04/18 01:34 AM
10/04/18 01:34 AM
my vote: SB/904
Re: 408 SB or 406 BB [Re: A/MP] #2558754
10/04/18 05:25 AM
10/04/18 05:25 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Well we have a 406 (.030 over 400) in my sons Dart. Its a mild street car that has the 383 forged crank in it. Has RPM heads and 10.5 comp , MP .557 cam and 3.91 gears. 727 with Dynamic 9.5 converter. Runs the Performer RPM intake and 750 DP. Has CPPA headers and 3" exh. Its not lightened any and with his 180 in it the car weighs 3640 lbs. Its run 11.41 @ 117 in full street trim driven to the track. Its one of them we had it so we built it builds. Its not the greatest combo but it runs nice for what it is and is a nice driving car. Here he is at the track. Ron
Re: 408 SB or 406 BB [Re: A/MP] #2558790
10/04/18 09:55 AM
10/04/18 09:55 AM
Keymar, MD
DusterKid Online content
DusterKid  Online Content
Keymar, MD
What car is the engine going in? I'm guessing an A body? If so I'd go for the 408 as a SB is WAY easier to work on than a BB in a A body. I have both, BB car is quicker, but more of a pain to work on.
Re: 408 SB or 406 BB [Re: A/MP] #2558846
10/04/18 12:17 PM
10/04/18 12:17 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
9.5-9.7@3200lbs??
675-700hp....... with a car that is somewhat sorted out.
Re: 408 SB or 406 BB [Re: A/MP] #2558903
10/04/18 02:22 PM
10/04/18 02:22 PM
gregsdart Offline
gregsdart  Offline
One thing to consider is, do you want to reach a certain goal and stay there, or are you someone that wants to go faster as time goes by? If faster is the goal, then focus your sites further down the road.
The two most important rules to follow:
1 weight reduction is cheaper than horsepower
2cubic inches rule
How you put your program together now will have immense effect on your situation down the road.
In my case, another year off racing, and a different course on my engine program and i would be running very low eights instead of 8.90s
Re: 408 SB or 406 BB [Re: A/MP] #2558961
10/04/18 04:25 PM
10/04/18 04:25 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
How come your limiting the BB to a stock stroke 400? Is it for a cu in limited class? I’m guessing a stroker BB isn’t anymore expensive than a stroker SB. If you’re willing to spend the $$$ on the SB why not the BB? For the hp you’ll need a 4.25” arm in a 400 block will get you there easier.
For that level of HP a BB (stroker or not) would probably be happier/easier, but I have no doubt either combo could hit the number
Re: 408 SB or 406 BB [Re: A/MP] #2558992
10/04/18 06:14 PM
10/04/18 06:14 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I'm a big block guy and I say Small Block 408 will be lighter and make the same power.
Depends on the heads for each combo.
Re: 408 SB or 406 BB [Re: A/MP] #2559193
10/05/18 01:16 AM
10/05/18 01:16 AM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
I have 408 parts on the shelf and a 400 block with Eddy heads from a RB.Time to try something different or build a 408 with modified W2 heads.Don't know if the 400 will give me anything more than what I have with my present 408 combo, 10.60/122.
Re: 408 SB or 406 BB [Re: DusterKid] #2559258
10/05/18 05:24 AM
10/05/18 05:24 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree with that DusterKid. I tell my son the bigblock A-body is a young mans car since its hard to work on in some area's and the bigblock B-body is an old mans car since it has more room. As for the most part my 63 Sport Fury has more room to work on it then my sons 400 Dart does. Ron
Re: 408 SB or 406 BB [Re: 383man] #2559272
10/05/18 08:45 AM
10/05/18 08:45 AM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
I'm gonna roll with Dusterkid and 383man on this one, I've built and owned multiple bb abodies with both underchassis and fender well Headers, fenderwells are nice for maintenance but unsightly for street exhaust and TTI underchassis are nice Headers to look at but jeez...so...if it's a coin toss on 408 vs 406 I'm going small block, which exactly the decision I made on the 67 Dart I'm building.
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: 408 SB or 406 BB [Re: A/MP] #2559678
10/05/18 10:43 PM
10/05/18 10:43 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Having owned a 9.9 big block, and currently a 9.5 small block..... the lil block is more fun!!
