anyone using a holley HP or dominator system
#2556386
09/29/18 08:39 PM
09/29/18 08:39 PM
Posts: 342 dracut mass usa
sparcy
dracut mass usa
I have a 2012 5.7 for my 69 charger. looking at the HOLLEY HP system but it will be supercharged so leaning towards the dominator. after talking to Holley tech, anyone using one of them.
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
Re: anyone using a holley HP or dominator system
[Re: sparcy]
#2557953
10/02/18 09:46 PM
10/02/18 09:46 PM
Posts: 729 Lebanon,IN
mr2performance
Lebanon,IN
I'd go with the hp, we use and sell them all of the time. Mike
MR2PERFORMANCE RACE CARS
765 483 9371
[Re: sparcy]
#2558749
10/04/18 04:33 AM
10/04/18 04:33 AM
Posts: 43,227 Bend,OR USA
Cab_Burge
I used a Holley Dominator EFI with dual 1150 CFM 4150 type throttle bodies on a gen 2 pump gas street Hemi 572 C.I. for a local street show and drive 1970 Challenger, I was told by Rich at Fastamn EFI that unit was capable of being used in the future for a boosted application, if the customer wanted to do that. Can you say twin turbos Not so on the other Holley EFI units last year when I bought it Sometimes it pays to buy more than you need just in case
[Re: sparcy]
#2558779
10/04/18 09:24 AM
10/04/18 09:24 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
use the HP at work for many boosted/NA combos at work. Unless you need drive-by-wire or a ton of I/O, the HP should work well.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: sparcy]
#2558966
10/04/18 04:44 PM
10/04/18 04:44 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Another option is megasquirt ms3 gold, around 1300 for everything including the harness/ecu and fully tune able for boost.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: sparcy]
#2558981
10/04/18 05:28 PM
10/04/18 05:28 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
The EFI Source MS3 Gold Box is a good value, a friend bought a car from a member here that had that setup. He did have an issue with the coil driver and EFI source was quick to help diagnose and test to help him find the issue.
68 Barracuda Formula S 340
[Re: sparcy]
#2561491
10/09/18 05:10 PM
10/09/18 05:10 PM
Posts: 112 Michigan
ghinmi
I have Holley HP on my turbocharged 5.7 Eagle hemi. 2.5 years so far, 22k miles, two Drag Weeks, etc. Not a single hiccup. Running mid 10s in a 4000 lb Jeep.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street. 9.97 @ 140 slicks, 10.74 in autox trim
[Re: ghinmi]
#2561496
10/09/18 05:24 PM
10/09/18 05:24 PM
Silver70
Rust Belt, SW PA
I have Holley HP on my turbocharged 5.7 Eagle hemi. 2.5 years so far, 22k miles, two Drag Weeks, etc. Not a single hiccup. Running mid 10s in a 4000 lb Jeep. Haven't see you post here in a while, saw the live feed and looked like the jeep was running pretty good.
[Re: sparcy]
#2561956
10/10/18 03:07 PM
10/10/18 03:07 PM
Posts: 112 Michigan
ghinmi
Thanks! She was running pretty good considering the mediocre weather. I was being pretty soft on the launches because of how far away from home I was. Hopefully get a chance in the coming weeks to see what it'll run all-out.
[Re: sparcy]
#2562157
10/10/18 09:58 PM
10/10/18 09:58 PM
sparcy
dracut mass usa
thanks street car 5.7 whipple going to need trans controller
