Re: CHANGE BUSHINGS IN LOWER CONTROL ARMS.. WHO CAN HELP.
[Re: PhillyRag]
#2557435
10/02/18 08:11 AM
10/02/18 08:11 AM
Posts: 1,553 Sweden
71redcuda
Sweden
I want to use stock.. yes im.asking someone within US to change them for me.. without damage the arms.
[Re: 71redcuda]
#2557510
10/02/18 11:06 AM
10/02/18 11:06 AM
Posts: 12,216 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
If you have the LCAs over there already, you shouldn't have to send them back to the US to have the bushings changed. It doesn't take any special tools. Just a press and some experience. If you have someone there that can do this kind of stuff, you should be able to hook up with someone here for the details. I, for one, would be glad to share the info. I just changed a pair last week for a buddy. Not that big a deal once you do a set or two.
Use the Moog bushings, but be careful of counterfeits. The ones I changed last week had only been in for a couple of years. But the rubber was completely shot and the outer shell had even began to split at a seam. And they were supposed to be Moog, too.
Master, again and still
[Re: 71redcuda]
#2557585
10/02/18 12:10 PM
10/02/18 12:10 PM
Posts: 2,833 Connecticut
FurryStump
Connecticut
Where are the arms? Opps to slowwwwwe
[Re: 71redcuda]
#2557616
10/02/18 01:04 PM
10/02/18 01:04 PM
Posts: 5,363 Rancho Cordova, California (Sa...
hemi71x
https://www.forabodiesonly.com/mopar/thr...dy-cars.413288/I do that type of work. Check out the link at the top of the page, from another Mopar forum, to what i do. I can do just bushing labor, or if you want them all looking pretty, and detailed too. Labor charged accordingly. Sending them overseas, is going to cost lotsa $$$$$$$$. Be aware of that. I have sent all over the globe to customers.
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: SIKPUP]
#2558731
10/04/18 02:00 AM
10/04/18 02:00 AM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
[Re: 71redcuda]
#2558943
10/04/18 03:55 PM
10/04/18 03:55 PM
Posts: 9,863 MI, usa
dvw
MI, usa
Easiest way. Press the shaft and inner sleeve out from the rear. Tear the rubber out if it remains. Weld a 1/8" thick washer to the remaining outer shell of the bushing. Do not weld to the control arm itself. Then press the outer shell forward by pressing against the washer from the rear. Removing the outer shell by this method is far neater than trying to chisel it out. Chiseling it out will mar it up. Chisel the inner sleeve off the stud. If its subborn slice the sleeve slightly front to back with a cut off wheel. Press the bushing in from the front. Support the inner sleeve from the rear and press the stud in from the front. It's actully pretty easy. Doug
Edit; if I was smarter I would have realized that the you tube video listed above also has a removal video below it showing the same thing. Anyway it works well, lol
[Re: 71redcuda]
#2559288
10/05/18 09:56 AM
10/05/18 09:56 AM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
I just completed ours on our 1974 Satellite.
I sliced the lip of the outer sleeve in several places, took my torches heated the sleeve red hot. Drove a screwdriver down behind the sleeve to make some room. I then heated it red hot again and pried the sleeve further out. Grabbed channel locks and pulled it out. This is third time I have done this and by far, this was the easiest.
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
[Re: 71redcuda]
#2560409
10/07/18 04:43 PM
10/07/18 04:43 PM
Posts: 12,238 Looking for a way out of Middl...
IMGTX
I can come over to Sweden and do them for you if you like. It's not a hard job so I will do it for just airfare and a room to stay in. It may take a week.... No two weeks over there.
