Re: 727 park grind
[Re: mopar muscle7271]
#2555363
09/27/18 02:02 AM
09/27/18 02:02 AM
RapidRobert
I'm thinking you need to slightly lengthen the linkage for more pawl engagement into the trans.
Re: 727 park grind
#2555555
09/27/18 02:38 PM
09/27/18 02:38 PM
Posts: 26,470 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Are you at a dead stop when shifting to Park? If the car lurches a little after shifting to Park and the grinding occurs, it's not fully in Park and, as suggested, the linkage is the problem.
Has it always done this or did it just start?
Re: 727 park grind
#2555573
09/27/18 03:06 PM
09/27/18 03:06 PM
Posts: 468 las vegas,nv
mopar muscle7271
Easily triggered
Easily triggered
las vegas,nv
I have the car on jack stands ounce i put the level in park it will grind then the grinding will slowly stop after a minute or so.i had to hurry up and turn it off.so it doesnt ruin something.it just started
Re: 727 park grind
[Re: John_Kunkel]
#2555746
09/27/18 11:19 PM
09/27/18 11:19 PM
mopar muscle7271
Easily triggered
Easily triggered
las vegas,nv
Its not fully in park the back tires turn by hand at the moment.they shouldn't unless its out of park.the lever is in park not the linkage.hopin thats all it is the linkage not further damage.that grindin was bad.could the bands be out of adjustment?
Re: 727 park grind
#2555754
09/27/18 11:23 PM
09/27/18 11:23 PM
Posts: 29,679 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
I have the car on jack stands ounce The wheel do stop when in park.every time i pit in park it will grind.i know it isnt good thats why hurry up and shut it off. Are you using the brake to stop the rear wheels from moving before shifting into Park? If so, your rear brakes may not be working.
Re: 727 park grind
[Re: moparx]
#2555940
09/28/18 12:28 PM
09/28/18 12:28 PM
RapidRobert
Yeah I have been bit by that (when up on stands) cuz your brain automatically thinks that you are "stopped" (& OK to go into park) cuz the car ain't moving.
Re: 727 park grind
#2555966
09/28/18 01:40 PM
09/28/18 01:40 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
step away from the vehicle
Get competent, on site help.
You do not know what you are doing.
one wheel peel will let the wheels turn, on jack stands, when in park. They will turn different directions.
Re: 727 park grind
[Re: Supercuda]
#2556081
09/28/18 08:24 PM
09/28/18 08:24 PM
mopar muscle7271
Easily triggered
Easily triggered
las vegas,nv
I dont need some smart dam remark.i question here.dont tell me to step away from my own car.what a troll
